Everything posted by wrj0
Run Times Off by 2 Hours
On my eisy, I had to perform the timezone change to another zone and change back. Rebooting or power cycling, did not correct the program logging time problem.
Bingo! That did the trick. Thanks @bmercier Why is it that the simplest solutions often seem to escape me? 🙂
My Last Run Time and Last Finish Time for programs that run on a schedule or event are showing as 2 hours later than the actual time that the program ran (showing as 2 hours into the future). The programs run on the correct scheduled time or event, but are shown in the summary view as 2 hours into the future. Manually running one of those programs with the 2 hours later time shown in the Summary View, result in the correct time being shown in the eisy Programs Summary view. The System>Configuration current time and location are set and correct. UDM shows the correct time for those programs that show as running 2 hours later in the eisy programs summary view. The eisy was power cycled yesterday. How have I managed to hose this? eisy-ui 1.4.6 IoX 6.1.2_10 UDX 5.1.0 PG3x 3.4.28 mosquitto 2.0.18 mDNSResponder 2881.100.56.0.1 libwebsockets 4.3.3
Add another plugin problem Wireless sensors
Yep, thanks. Nodes did indeed have the same address as before. And just changing a character in the Comment section, updating and saving, restored the programs into operation without the "Not Loaded" status. All good now.
Tags missing in Wireless Tags plugin
Wireless tags appeared after updating eisy.ui to ver 1.4.6. More in this post.
After updating eisy.ui to the recent ver 1.4.6, I found a new entry for my WirelessTags plugin, that included the Monitor Tags button. Enabling that allowed the plugin to find and display my tags and their status. Additionally, the update allowed my Zibgee service to once again find and access my Hue bulbs. Nice! Now, to update all of my Wireless Tag programs to eliminate the "Not Loaded" status.
This issue was previously reported in this link Perhaps it's time to tag @Jimbo.Automates
Since migrating PG3 nodeservers to the eisy.ui plugins, my Wireless Tag devices have not reported to the eisy plugin. The Tag Manager is present and appears to be authorized: When the Wireless Tab nodeserver was installed in PG3, there was a Monitor Tag function that had to be enabled so the tags would show up in IoX. I don't find a similar ability in the eisy plugin. Suggestions, please.
WOL Migration Failed
@Ross Need to select the name set in the Wake On Lan plugin, that you want to wake. In the Wake On Lan plugin, my first Configuration Parameter (name) is U59LAN1. The second field in the Configuration Parameter is the MAC/ip, e.g.,: 7C:83:34:xx:yy:zz/192.168.x.y My test program: WakeU59 - [ID 01BF][Parent 0080][Not Enabled] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'Plugins / U59LAN1' Send WOL Else - No Actions - (To add one, press 'Action') #Disabled
Run manually as needed
After updating eisy to the 10/16 releases, and migrating Wake On Lan again, that plugin is once again functional.
- WOL Migration Failed
I have Wake On Lan ver 1.0.3 installed on my eisy; it's been running fine for a couple of years. Today I performed the "Migrate from PG3" on all of my PG3 nodeservers/plugins. All of the plugins migrated, except for Wake On Lan, which reported: "Migration failed: No valid license found for Wake-On-Lan null edition." Details in PG3>Dashboard>Wake On Lan shows: Wake-On-Lan(2) Current Status: Connected Current Version: 1.0.3 [Production] I have stopped and restarted the plugin. Anything I can do to allow this plugin to migrate? Thanks.
eisy.local Backup error "Plugin data files"
Since the eisy.local page shows "Plugins (Beta)" I had not previously performed the migration from PG3X to eisy. Opening "Plugins beta" showed a tab "Migrate PG3 plugins." After performing that migration, Backup now shows a Green check next to Plugin Data Files. Thanks all for your feedback, comments and suggestions. What an amazing, helpful forum!
Not sure migration is my problem; eisy migration from PG3 to PG3X was performed in 2023.
Seeing an error when creating a Backup using eisy.local > System > Backup & Recovery. Only noticed this after doing the recent Beta update. loX 6.1.2_7 UDX 5.0.0_4 PG3X 3.4.25 eisy Ul 1.3.9 The backup completes but shows this error: What am I missing or doing wrong?
New Version
@Panda88 Thanks for implementing tokens so we don't have to enter that pesky 2FA after each reboot. Nice work.
ST-Inventory Status: Disconnected
Updated ST-Inventory today from v1.0.12 to 1.0.13. Plugin status now shows: Disconnected. Rebooted eisy running v6.1.1. Allowed time for both short & long poll times to pass. Allow ISY Access by Plugin is Enabled. ST-Inventory status continues to show: Current Status: Disconnected Current Version: 1.0.13 / Standard [Production] Suggestions on how to resolve will be appreciated.
IoX 6.1.1 let's discuss it!
My first eisy upgraded without any issues, following the upgrade procedure. The second eisy completed the upgrade, but after two reboots, eisy.ui was reported as not found. After performing 6x presses of the multifunction button to shut down the eisy, pulling and reconnecting power, the eisy booted fine and eisy.ui is now accessible.
Blink quit working???
Update to 0.6.19 worked fine. Received 2FA on first restart. Thanks @Panda88
New version just downloaded on iOS Sync errors
Same kind of problems here syncing. UDM 4.45.24, isy-6.0.5_10 Think I'll wait for the permanent solution before syncing via cell service.
Remote eisy-ui
My eisy upgrade via the AC from isy-6.0.5_1 proceeded without any problems. sysconfig.txt now shows: eisyui-1.0.1 pg3x-3.4.17 And my.isy.io shows and opens the new eisy-ui option. Nice work UDI.
Trying to add a Matter device
I also had trouble adding the Cync bulb directly to UDM. So, first added it to the Apple Home app which allowed the bulb to be added to UDM without any trouble. After scanning the Matter code for the Cync bulb into the Home app, select 'Turn On Paring Mode' and Copy the provided pairing setup code. Then open UDM, in Settings -> Matter, Select Add Matter Device with Setup Code and paste the copied code into UDM. UDM added the Cync bulb that functions fine in IoX.
eisy R2 UPS Power supply questions
My two Talentcell UPS also failed in just under two years. Lousy battery connections that are welded in place. IMG_5020 2.HEIC
Unable to Login
Blink 0.6.6 is working fine with my eisy. Thanks for the update.
Unable to Login
@Panda88 0.6.5 is working great! Thanks for the fast response and your effort to fix the new authorization issue. Well done.
