October 6Oct 6 I have Wake On Lan ver 1.0.3 installed on my eisy; it's been running fine for a couple of years. Today I performed the "Migrate from PG3" on all of my PG3 nodeservers/plugins. All of the plugins migrated, except for Wake On Lan, which reported: "Migration failed: No valid license found for Wake-On-Lan null edition."Details in PG3>Dashboard>Wake On Lan shows: Wake-On-Lan(2) Current Status: Connected Current Version: 1.0.3 [Production]I have stopped and restarted the plugin. Anything I can do to allow this plugin to migrate? Thanks.
October 17Oct 17 Author Solution After updating eisy to the 10/16 releases, and migrating Wake On Lan again, that plugin is once again functional.
October 18Oct 18 @wrj0 After updating and migrating to Eisy-UI, I have a Wake-On-Lan in my "eisy Plugins".When I want to add a WOL line in a program, when I select Command, that plugin does not appear.However, if I select Network Command, it does. Unfortunately, it pulls the information from the WOL in the Admin Console - not the plugin.Any thoughts?Thanks,Ross
October 18Oct 18 Author @Ross Need to select the name set in the Wake On Lan plugin, that you want to wake.In the Wake On Lan plugin, my first Configuration Parameter (name) is U59LAN1.The second field in the Configuration Parameter is the MAC/ip, e.g.,:7C:83:34:xx:yy:zz/192.168.x.yMy test program:WakeU59 - [ID 01BF][Parent 0080][Not Enabled] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'Plugins / U59LAN1' Send WOL Else - No Actions - (To add one, press 'Action') #Disabled
Run manually as needed
