Alexa no longer responding to state variable motion.
I gave up and used "Virtual Buttons" Node Server in PG3X
Venstar CT not getting commands through Portal
@garybixler there is an alexa skill that works great without UDI. Thats my MO but Venstar plugin for UDI control
Why am I getting this "New Insteon Device" box?
I previously had that issue Power cycle EiSY fixed it
Isy constantly connects and disconnects from interne
i have had the exact same issue in two locations both with unifi In both cases it was caused by slow internet connections run a speed test on the lan leg the isy is on
Insteon Low Volt Controller and Garage Door
correct basically the iolinc closes the same contacts as pressing wall button. you have to connect to the pads that the switch closes, not the normal wires that go to opener
works if you solder the contacts to the wall panel to the pads for the push button
eisy R2 UPS Power supply questions
@Guy Lavoie thanks for the link. I haved looked at UDI sales a couple of time for spare supplies.
Switch triggering a state variable to activate alexa
I tried to make this work months ago and never got the alexa spoken to work There is a PG3X node server called "Virtual Button" that accomplished it for me
ESY and Alexa Echo Studio
I Installed a new Echo-11 last week and it asked if I wanted Alexa+ I clicked no and I am on non + running fine
Problems replacing zMatter dongle
I moved an instance 2 weeks ago from a polisy to a eisy (internal zmatter to different usb zmater) 2 weeks ago and the restore fuction worked - no issues. I did have to do a reboot after installing the usb to get the zmatter as showing active. did you open s usb to confirm the antenna wires are connected ?
any chance you have the antennas swapped ?
EISY Polyglot 3x - Error during login attempt
try admin / admin
ISY skill will soon no longer work at all on Alexa+
@bmercier ??
Expanded Matter Support ?
Does anyone know what the expanded Matter support is that is mentioned in the Black Friday sale email ? Is something other than a switch supported now ? Upgrade to eisy r2 and get 13% off, plus 1 FREE year of ISY Portal! Try our web-based eisy UI (no Java), HomeKit integration, expanded Matter support
bgrubb1 started following Expanded Matter Support ?
Can I still upgrade from ISY994i to eisy r2?
There is a Node server that you can load on PG3X on the eIsy to make it control the vista 20 panel Called Envisalink-HW you add the Envisalink module to the panel and it acts like a keypad.
bgrubb1
Joined
Last visited
