Everything posted by andrewherman
Update packages for eisy-ui use
I think I am bricked as well. Was on 6.0.4, hit upgrade, waited, then it said reboot, I did. Now no access. Also my last backup is from 5.8.4 - hopefully this will be able to be used. Submitted ticktet. Any advice?
EISY and Ring
Yup, time for a ticket. Thanks for your help.
EISY and Ring
On my PG3x dashboard, it shows ring as disconnected. Does this mean disconnected from Ring or from the eisy? According to my ring account, ISY home automation access has been granted. Version 1.2.1. In eisy, tried opening plugin, install all nodes for ring, and nothing happens. Any thoughts would be appreciated.
EISY and Ring
Actually, after checking, I'm on pg3x. I have re-authenticated, but node still says disconnected. Ring is also not loading into the eisy. It appears that I'm not "talking" to ring. Connection to Alexa is working find. All was OK till today's upgrade. Thanks.
EISY and Ring
I will try rebooting the eisy and the pg3. Thanks.
EISY and Ring
If you mean in PG3 dashboard, I've already tried this, along with deleting and re-adding. Thanks.
EISY and Ring
So, have not touched my EISY in maybe 6 or 10 months. Logged in and suggested upgrade. All went OK, however my interface to Ring is no longer working. Deleted and reinstalled in Polyglot, but not showing in EISY interface or dashboard. Also notification controller is showing as disconnected. I have tried restarting PG3. Please note that my connection to Alexa is working fine. Been a while since I have worked in this system. Maybe I shouldn't have updated. Any suggestions would be appreciated. Thanks.
New Ring Node
Found the authentication... All good. Thanks.
New Ring Node
Trying to set up the new Ring Node Server. So, I set up in PG3, made sure in portal the "tools" I had three "yes" items. Then, in the AC, I added all nodes, but nothing showed up. However, I just thought, no where did it ask me to sign in to my Ring account. Did I miss something? Thanks, Andrew
PLM Replacement
Thanks, I'll give the factory reset a try. I appreciate the help. Now if I could only get some ivory replacement switches, all would be good.
PLM Replacement
All the wireless devices updated fine. For some reason, 2 8 button keypads are still giving the 1101 error. I've ordered 2 new ones, will see what happens. Thanks.
PLM Replacement
I will give this a try. I thought all the wireless devices were updated. Thanks.
PLM Replacement
Received my new PLM from Insteon. Followed procedures indicated and most of the switches did fine. While the 8 button wall switches appear to be online, they still have the "write" green squiggly indicator. I've tried manually writing and restoring to the device, but no luck. Any ideas would be appreicated. Thanks.
Lamp dimmer problems
It is not all the devices. I will try to restore and see what happens. Some are older devices. Thanks....
Thanks. Also noticed this when accessing one of the lamp modules from UD Mobile. I appreciate the help.
Now using eisy, no issues with software, etc. However, for the last couple of weeks, my lamplinc dimmers have been intermittently unresponsive. Running 5.5.9. Scheduling, all other items, seem OK. Now my PLM is about 8-10 years old? Could it be getting weak? I've tried replacing the lamplincs with new, still have the same issue. Hopefully, new PLM will be in stock soon. Any ideas appreciated. Thanks, Andrew
Motion Program Help
Actually, I sometimes forget to turn off the bathroom light, so if no motion for a while, please turn off light. Hope that helps.
Motion Program Help
It is the II. Thanks. I will make the change. Looks like that will work.
Motion Program Help
EISY 5.5.5 Motion program help. So I have a motion sensor in my bathroom. Goal is to turn off light after five minutes of inactivity, unless activity is sensed again. Bath Motion - [ID 0025][Parent 0001] If 'Master Bath / Andrew Vanity' Status is not Off And 'AA-Insteon Motion Sensors / Motion Sensor Bathroom / Bath Motion' is switched Off Then Wait 4 minutes and 25 seconds Set 'Master Bath / Andrew Vanity' Off Else - No Actions - (To add one, press 'Action') problem with above is turns off lights even if I walk back into bathroom. I can't seem to think through programming to not run if motion is starting during "wait" period. Any ideas would be appreciated. Thanks, Andrew
Pentair Screenlogic
Has anyone written or considered writing a node server for Pentair Screenlogic? Would be great to use Eisy/Isy for various pool controls. Thanks.
How do I add z-wave to eisy?
Is the Zooz 700 dongle plug and play? Thanks.
[Merged Threads] Polisy upgrade 5.4.3 to 5.4.4
I did open a ticket. Reinstalled old ISY and it picked up and ran like a champ. At least I have most of the functionality running. Thanks for your help.
when I try to add in the finder: Socket Open Failed java.net.ConnectException: Connection refused: no futher information XM: Parse Error http://ip:8080/desc
I will give this a try and see what happens. Maybe I corrupted the update? How can I reinstall? I do have a backup. Thanks.
Found the new IP. However, can't get Iox finder to locate, even manually input in finder. Also, log in to polisy, says ISY is there but no luck getting in on finder. Maybe upgrade failed?? Thanks.
