Polisy Pro Migration WITH 700 ZWave to Eisy Lite
Orest, Upgraded yesterday. Backed up polisy and PG3. Put the new eisy on the network with no plm or zwave dongles, upgraded it and restored only the polisy backup. Made sure in the configuration tab that Insteon and zwave were on. It was functioning fine both from the Java app and eisy-ui. I then shut it down using the front panel button. Powered down polisy. Moved the zooz zwave stick and plm from the polisy to the eisy. Powered eisy back on. Very happy- both Insteon and zwave worked perfectly without any adjustments. And that is with very finicky zwave locks. Pg3 and node servers took several hours of reloading, reinstalling and configuration. Did the restore from backup. None of the custom configuration parameters are restored with the backup. You have to essentially setup each node server from scratch. Once running, the nodes lined up correctly with programs. Java console functions well as does the new eisy-gui. Let me know how your upgrade goes.
I didn’t get a chance to attempt the migration yet. My feeling is that since the zwave stick records the zwave associations internally, it should maintain connections when it’s moved. I’m hoping the zwave nodes are in the general backup and simply resume working. i think you should be okay after December with the Java front end- it’s not being turned off.
Polisy Pro Migration to eisy lite-Feedback Requested
Hopefully will get some time this weekend to attempt the migration from polisy to eisy and just moving the zooz dongle is all I need to do.
The zwave devices show up as ZW. I’m not looking to migrate to a new zwave device. Simply want to unplug the zooz dongle from the polisy and plug it into the eisy. Not sure of the steps involved to have it be recognized and hopefully use what’s in the backup I restore from the polisy. In the original post, there is a step to enable Insteon support after restoring the backup. Is there a similar step for zwave?
Thanks Javi. There is no option to backup zwave if using a zwave stick. I am on IoX 5.9.1. I’m assuming it is included automatically in the polisy backup. i am thinking that a number of users on zwave will be going through a similar conversion given that the zmatter board is not available. I purchased the eisy to not go through the hassle of upgrading the polisy and have a safe fallback in case of issues. Having to reset the zwave stick would be painful as would require rebuilding my zwave network.
My polisy has a zooz zwave stick. The wiki does not explain how to transfer that to the eisy. It only describes transferring to a zmatter stick, not moving existing zwave hardware. Will the polisy backup (there is no separate zwave backup when using a zooz stick) restore full zwave configuration to the eisy by simply plugging in the zooz stick.
Ecobee not communicating
My SmartThings integration to ecobee is still working.
I am seeing the same problem with my ecobee nodes
Line-in?
A few years ago, I configured network resources to directly communicate with Sonos and control line-in. Was a bit complex to setup, and used some pre-existing network resource files from the wiki. https://wiki.universal-devices.com/ISY-994i_Series_INSTEON:Networking:Network_Resources It still functions correctly with no issues.
Can’t Syncronize UDM
Thanks so much. That worked.
I am trying to syncronize udm as I added some new devices. Keep getting an error popup and it fails. My polisy is on v5.9.1. Anyone else have this issue? Below image pops up immediately after starting Sync
Display node on elk not populating with name
I have a similar issue except my polisy is on 5.9.1 (did no upgrade to 6 yet). The default ElK commands display numbers instead of the labels. On the default ELK tile, the Commands for Set Armed Status displays a list of numbers. Makes it almost impossible to manage arming and disarming from the phone -
Support Thread: IoX v5.9.1 (2/10/25)
I also had an early-release Polisy. It required some UD support sessions to get it running initially - I had waited a couple of years from when I purchased it to actually turning it on. I was fully up to date (5.8.4 and 13.2) when I attempted the upgrade. It totally bricked. Used the usb adaptor to reflash the ssd which brought it back to limping mode. Required a few hours of Michel’s magic to get it fully running and upgraded.
Polisy will not boot.
Good luck with the SSD drive. Michel worked his magic tonight and got my polisy back in the game.
