Dr. Q
Joined
Last visited
Currently
Viewing Topic: Using a PLM that's already linked to Insteon
Thanks folks. @paulbates , that explains why HA could see the links by just plugging in the PLM. Looks like I have a project ahead of me. It would benefit me to take note of the Insteon addresses in the HA integration so I don’t have to pull the FanLincs down. The Insteon integration in HA is pretty bare bones (no dim/brighten signals, can’t programmatically change button light levels), so I’m going to try running eisy from HA through the IoX integration. The Hue node server is the best way I’ve found to control Hue lights with Insteon dimmers.
I have a 2413U PLM that I was using with Indigo, and I wish to come back to IoX/eisy. The PLM is already linked to all the Insteon stuff so I want to do this without having to re-link it all. I plugged it into the eisy and did Tools/Diagnostics/List PLM Link Table and everything seems to be there but I don't know how to see the devices in the sidebar in IoX.
Dr. Q started following UDI EISY Update 2025 , Using a PLM that's already linked to Insteon and Upading an old eisy
Upading an old eisy
After a decade of being an Indigo user, I'd like to switch back to my old Gen 1 eisy. I have it up and running, but I need to update the ancient firmware, 5.8.0, and pg3x 3.2.17. Michel's post of 3/12, under Important Notes, says do NOT upgrade if the version is less than 5.9.1, as it may brick the eisy. The rest of the instructions are unclear as to whether they are the solution to updating, or if I'm SOL and need to update my hardware. If backups are the issue, the only thing I have showing in the AC are the Hue and Twinkly NS I installed 10 years ago (a pleasant surprise), I haven't connected the Insteon modem yet. No programs, so there's nothing really to back up. Should I just click 'Update Firmware' and hope for the best? Chuck Edit: I think I found the answer:
Getting rid of Java? Hmm, I may have to rethink my game plan. I switched to Indigo from ISY a few years ago because I’m a Mac guy, but I missed some advantages that the ISY had. But not Java. However, I did purchase an EISY last year with the intention to switch back. I chickened out when I considered the pain of re-linking all the Insteon/Z-wave/Hue devices to the new system. There are still some integrations that I would need to be equivalent to my current system, such as using UniFi Protect cameras as motion sensors. Home Assistant might close that gap. I’ll be watching this space. Chuck
Has Anyone Remote Mounted the ZMatter Antenna Assembly and PLM using USB-Ethernet Converters?
@mbking, the link you provided above takes me to a HDMI extender. I did some digging and found what I think is appropriate. I don’t know how to post Amazon links, but it’s a AV Access USB Extender w/Power Over Cable (There’s an 8% off coupon for it now). I ordered one and I’ll report back on it. But I can’t get eisy to see the Z-matter dongle unless it’s plugged directly into the eisy. I was using a 6 foot USB extension cord, so it may have to do with voltage drop. In which case the Power Over Cable feature might overcome that. I’ll have to try it and see. ‘Stay tuned…
Support thread for: PG3x v3.1.36 (July 11, 2023)
As a follow up to my original post, I ended up doing a factory reset of the eisy and started over again, which was fine since I was starting from scratch anyway. Both eisy fw and PG3X are updated now.
Yep, tried sneaker-net reboot (pulling the power) as well. I'll try it again for longer; if that doesn't do it, I'll write up a ticket. Thanks, @Geddy.
@Michel Kohanim Not true, PG3X shows in the upper left corner. I also can’t seem to get the fw up to 5.6.3. I should point out that this is a brand new eisy and setting it up as a blank slate, IOW, I’m not transferring from an ISY994. I also have a Z-Matter dongle plugged in, but the z-wave menu in the AC shows “Z-wave dongle not responding “. I have the z-wave box in the configuration tab checked.
I’ve never been able to get past 3.1.31, running IoX 5.6.2. Tried all the tricks. I’m not afraid of SSH, is there anything I can try?
I have the same scenario and I am watching this thread. Keep us posted on how it goes.
Moving back from Indigo
Glad to hear from another Indigo user. I also like the server/client approach to administration and would like to see UD ditch Java and go with a web based method, but it is what it is. I picked up a couple of USB PLMs just before Smarthome shut down, so I’ll start with a fresh one. I’m trying to find a way to print a list of all my devices from Indigo so I don’t forget any, and go around the house and re-link it all. The FanLincs are going to be a pain, but worth it. Thanks for the good wishes.
Mr. Bill had it right, I thought there might be a way to transfer the PLM memory to the eisy but I guess not. Ugh! In which case I might as well go ahead and get the Zwave-Matter dongle too, even though Matter doesn’t matter to me (heh). My wife will be out of town next weekend, might be a good time to make the switch. In the meantime, I‘ve been playing around with the eisy, once I figured out to turn the VPN off on the Ubiquiti network. I have some Twinkly lights, so I installed the NS and got it working, even with the gen 1 lights. Nice. Ultimately, I think it will be worth the trouble to start over, as lilyoyo says. My problem with Indigo has always been the lack of an equivalent version of ISY scenes. Also, the Trigger/Schedule-Conditional-Action cadence used in Indigo makes things that are simple to do in ISY needlessly complicated and repetitive. For example, to turn a light on or off in ISY requires one If-Then-Else cadence; Indigo requires two cadences, one for on and one for off. I’ve been keeping an eye on UD since I moved on, and have seen a lot of advancements. I need to control Hue lights with Insteon dimmers, use UniFi Protect cameras for motion sensors, bring some of it into HomeKit and integrate all that with zwave sensors. It looks like eisy in combination with Home Assistant will get me there. Good thing I enjoy screwing around with this stuff 🤪 ‘Thanks for the info and listening to my rant.
I moved from ISY 994 to Indigo a few years ago, and now I’m looking to move back. I have a eisy on the network and operating. Since I already have a USB PLM linked to everything and an Aeotec G5 zwave stick also linked, can I just plug them in and pick up from there without running around resetting all my devices?
hinge pin zw door sensor
I have two of these and would love to use them on my two new exterior doors instead of drilling holes in the frame. I’ll keep watching this thread for updates. Sent from my iPad using Tapatalk
IOLink 2450
I have to pipe in here and mention that I’ve decided to move my security type devices to HomeKit, which involved swapping out a Schlage 469 for a Sense (Bluetooth instead of Z-wave) and picking up a Insignia (yes, That Insignia) Wi-Fi Garage Door Controller for Apple HomeKit, $70 at Best Buy. If you have an Apple ecosystem, this is hard to beat; the only cloud here starts with an “i” and it doesn’t come with an app, you use the Home app. The Insteon Garage Door Kit was my rationale for starting this expensive hobby in the first place, after going away on a Christmas weekend and finding I’d left the door open. While I’ve never had some of the problems others have had, I’ve never really trusted the thing and I’m glad to get rid of it. Chuck Sent from my iPad using Tapatalk
