tjkintz
Members-
Posts
93 -
Joined
Last visited
Everything posted by tjkintz
The following are my experiences until I finally gave up. Admin console sees eisy but type and version are blank. No popup for admin console, polyglot, etc. Router shows 2 IP leases with same mac address, oldest one had partial information, so I deleted it. Admin console does not find another one, so I manually added it. It then shows type, version and popup works. Admin console has unknown location. Set it in configuration and AC shows it below the buttons but sunset and sunrise are both 12:00 AM. In configuration, option to set daylight savings time is grayed out. Returning to configuration, still shows “Change Location (unknown location)”. Clicking Zigbee or Z-wave in the menu gives me “Zmatter Zigbee not responding”. I verified the antennas are correctly attached. Configuration shows Matter support Off, Zigbee and Z-Wave support Auto. Turned on all three but still not responding. UD Portal does not see eisy, says it is offline. It does see my Polisy in another location. Clicking Portals in AC shows nothing. Restated IoX. Location is unknown again but Matter, Zigbee and Z-Wave settings are still set to on. Still get the Zigbee not responding message. Rebooted eisy, no change. Configuration, Network settings are basically empty and automatic (DHCP) is grayed out. However, Help-About shows a valid My URL but shows Internet Access disabled. Since my whole goal was to add some Zigbee devices, I am dead in the water at this point.
I have an eisy that I have not used in months. I now want to use it so powered it on, upgraded and am now running 6.0.0 but I do not seen any mention of that version in the forum. I am having issues with zigbee, updating my location, connecting to UD portal, etc., but first want to know if I am running the right software.
EISY - Wifi Connection not getting Static Assignment from DHCP
tjkintz replied to woodfieldp's topic in eisy
The router will make a static DHCP assignment based on the mac address. There are two mac addresses, wired and wireless. Once you have gotten an ip address via wireless, make that assignment static in the router. -
I have moved my eisy from a wired connection and trying to set up a wifi connection. I am running into the same issue and error message and I too have tried many times. Looking at other related threads, I never see eisi broadcasting an SSID and looking at my router, I never see any attempt by eisy to associate with an AP. I am using a Mikrotik AX access point with WPA2 only. In one thread Michael said to double click the power button twice. Everything else says double click it once. I've tried both.
Regarding zigbee frequencies, they differ from country to country but I configured the module for Portugal which is where I am. Having said that, I see no way to know or configure what frequency the switch uses.
All, thanks for the responses. My initial installation was really a test setting for zigbee and to see if my led lights were dimmable. They aren't! The distance from the eisy to the switches is less than 10' so it isn't the mesh network, and eisy finds the switches, just cannot do anything useful with them. Moes says a Tuya or their gateway is needed but I wanted them to work with eisy so haven't gotten one of those. I'll submit a support ticket but it will probably end up being a failed experiment.
I am new to zigbee but trying to setup smart lighting in Europe where Insteon does not work easily. As a test I bought a Moes zigbee dimmer switch. Eisy finds it and interviews it but the only command eisy shows is Query. Moes expects me to be using their gateway but I hoped any zigbee gateway would work. Any ideas how to make the switch do something useful? Any better zigbee options for europe?
You were close. I couldn't stop the NS because it wasn't running. I couldn't start it without a license. The NS store said my Polisy was not registered with Portal, even though Portal said it was connected. I could not buy another license or activate a trial. Within PG3, I restarted PG3 and all problems went away. I could then reinstall the NS and update it to the new version.
Update. Following your experience, I gave the Polisy a rest. After powering it back on, I had a valid UUID again and the Portal said it was online. It still could not talk to the PLM and said its status was offline. I then did a "Restart IoX" in the Configuration-System tab. It then started talking to the PLM. One would think that all the Polsy reboots and power cycles I did would have restarted IoX. After all that, I now have YoLink NS issues in that it says I do not have a license. Sigh!
I just have a pure Polisy with no additional boards or z-anything. I would have stuck to the ISY, but I acquired some YoLink devices and needed the YoLink node server. For now, I have lost YoLink.
I am sort of in the same boat. Last evening, according to the last log entries, IoP just stopped working. I can get in via AC but there is no status for any nodes. It goes into the "system busy" loop, sometimes endlessly. It also shows a UUID of 0...1. ISY Portal shows it offline. I have power cycled, updated packages, rebooted, but I am still dead in the water. The PLM doesn't show any activity while the system is busy, but it does show activity from manual Insteon activity. I do not have a backup PLM, but I reinstalled my old ISY and it talks to the PLM fine. From what I can tell, it is IoX 5.4.5 on a Polisy.
I had a similar problem after moving to Polisy/IoP but do not know if the move was the cause. All I can say is that I never had the problem with my old iSY. All my audio and network equipment is in a homerun wired closet. I noticed I was getting flooded with X10 traffic, even though I have no X10 devices. I was able to isolate most of the problems to my audio amplifier. If I unplugged it, most of the problems went away. Luckily, I was able to relocate the Polisy and PLM to a closet far away. All my X10 messages went away. All I can guess is the Polisy is very susceptible to electrical noise.
A bit off topic but actually, the two are quite similar in that the router update is a complete software replacement for the router, fixing bugs and adding new features, etc. The change log is frequently pages long. All that is retained is the configuration, firewall rules, scripts, etc. They do have three update trees to choose from: beta, stable and legacy. And yes, things have gone sideways when I updated from the beta tree so now I automatically update from the stable tree. Because they have a scripting language, I have written scripts to make me aware the router was updated.
Re: "If something isn't clear about that, please let me know what you think would make it better." The problem for me is that I only look at the forum when I am trying to solve a problem. In other words, I rarely look at the forum. As a result, I have no way of knowing there is an update or how to install it. Polisy (PG3 and IoP) is the only device or software I own that doesn't have an easy way of being notified of an available update, along with a script-like upgrade procedure. I regularly run Admin Console, so every time I log in, it would be nice to be notified of new system software, along with some sort of "Click here" button to automatically install the update. Taking it a further step, having a configurable option to automatically look for and apply updates would make it even better. The closest analogy to Polisy is my router in that they do not require regular human interaction, so it is challenging to keep them up to date. With my router, I can manually tell it to look for updates, but it supports a scripting language so every day it automatically looks for updates and applies them if available. That is the type of thing that would really help Polisy, a simple way to manually look for and apply updates, and an automatic way to do it without human intervention.
Bob, The following are two snips from the PG3 purchases screen. The first shows I have a license and the second is what I see when I click (Re)install.
I got things working! The reason you saw one thing and I saw another is the way we went about it. You seem to have gone to the production store and clicked on left YoLInk button. I am pretty sure that was not a live button for me. I somehow got into a state where IoP could not communicate with any Insteon devices. I updated Java, cleared the cache, power cycled the Polisy and PLM. IoP could then communicate with the devices, but the NS still didn't work. I went back to the production store and noticed the live YoLInk button, clicked and then saw what you saw. I was then able to install into slot 1 and everything worked. Whatever method I was using, I could no longer find it. It is impossible to tell which of the things I tried were the key. The purchases section still says I don't have a valid license.
The only way I could find to update PG3 was with the PG3-System-Restart PG3. (Like I said, how to update PG3 is far from intuitive.) I would assume that would reboot PG3. Before finding that I had tried IoP-Configuration-Upgrade Packages but that didn't seem to do anything. I do not understand " if you do not start AC - could you erase the node in PG3" Does AC = Admin Console? I do not see any way to delete "the node" in PG3. I presume you do not mean YO node and must mean NS slot but again I do not see a way to do that. To add to the confusion, I just encountered an issue I had seen earlier but had gone away. I went to PG3, Node Server Purchases. It shows the YO NS and it has a (Re)install button. When I click that I am told I do not have a valid license and it wants me to purchase it again.
I stumbled around and got PG3 updated to 3.1.13 (far from intuitive how!). I still cannot install the NS into slot 1 because it doesn't list it as a choice. Automatic update fails like it did before. Latest PG3 log follows. 11/2/2022, 12:06:53 [pg3] info: startNs:: YoLink 11/2/2022, 12:06:53 [pg3] info: startNs:: YoLink is valid 11/2/2022, 12:06:53 [pg3] info: checkLicense:: YoLink Valid perpetual license found. 11/2/2022, 12:06:53 [pg3] info: UPGRADE AVAILABLE for YoLink from 0.5.21 to 0.6.1 11/2/2022, 12:06:53 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 12:06:53 [pg3] error: YoLink automatic update failed 11/2/2022, 12:07:13 [pg3] info: [YoLink(1)]: Restarting Node server 11/2/2022, 12:07:13 [pg3] warn: [YoLink(1)]: Was not running. Starting... 11/2/2022, 12:07:16 [pg3] info: startNs:: YoLink 11/2/2022, 12:07:16 [pg3] info: startNs:: YoLink is valid 11/2/2022, 12:07:17 [pg3] info: checkLicense:: YoLink Valid perpetual license found. 11/2/2022, 12:07:17 [pg3] info: UPGRADE AVAILABLE for YoLink from 0.5.21 to 0.6.1 11/2/2022, 12:07:17 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 12:07:17 [pg3] error: YoLink automatic update failed 11/2/2022, 12:07:47 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_abRDK 11/2/2022, 12:07:47 [pg3] error: MQTTS: clientError: pg3frontend_abRDK keep alive timeout 11/2/2022, 12:07:47 [pg3] info: MQTTS: Client Disconnected: pg3frontend_abRDK 11/2/2022, 12:07:47 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_vBMOo 11/2/2022, 12:07:47 [pg3] error: MQTTS: clientError: pg3frontend_vBMOo keep alive timeout 11/2/2022, 12:07:47 [pg3] info: MQTTS: Client Disconnected: pg3frontend_vBMOo 11/2/2022, 12:07:53 [pg3] info: MQTTS: Client Connected: pg3frontend_abRDK 11/2/2022, 12:07:53 [pg3] info: MQTTS: Client Connected: pg3frontend_vBMOo
How do I do that?
Re: PG3 log, it is below. The last entry in the NS log was around 8:38. 11/2/2022, 08:37:41 [pg3] info: [00:0d:b9:5e:e1:4c_1] setup reporting command DON 11/2/2022, 08:37:41 [pg3] debug: Scheduling http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DON to group commandGroup 11/2/2022, 08:37:41 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:e1:4c] :: [200] :: 6.236948ms - http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DON 11/2/2022, 08:37:41 [pg3] debug: MQTT Results: [ns/command/00:0d:b9:5e:e1:4c,1] :: {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:37:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:37:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"shortPoll":{}} 11/2/2022, 08:38:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:41 [pg3] debug: [MESSAGE_PUBLISHED] Client 00:0d:b9:5e:e1:4c_1 has published message on udi/pg3/ns/command/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:41 [pg3] info: [00:0d:b9:5e:e1:4c_1] setup reporting command DOF 11/2/2022, 08:38:41 [pg3] debug: Scheduling http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DOF to group commandGroup 11/2/2022, 08:38:41 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:e1:4c] :: [200] :: 5.594039ms - http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DOF 11/2/2022, 08:38:41 [pg3] debug: MQTT Results: [ns/command/00:0d:b9:5e:e1:4c,1] :: {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:38:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:38:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:50 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:38:50 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":1666454312735,"timeModified":1667159593079,"version":"0.5.21","branch":"main","url":"https://github.com/Panda88CO/udi-yolink","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Beta","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:38:50 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":1666454312735,"timeModified":1667159593079,"version":"0.5.21","branch":"main","url":"https://github.com/Panda88CO/udi-yolink","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Beta","dbVersion":1,"notices":{},"nodes":[{"id":"813b4952-e08d-4fe0-83c7-88adde7d8266","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","name":"Margie Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f77c","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219974598,"timeModified":1659219974598,"dbVersion":1,"drivers":[{"id":"601a4002-db02-462b-b13f-1e07b548f93e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"GV8","value":"1","uom":25,"timeAdded":1659219974841,"timeModified":1667376142394,"dbVersion":1},{"id":"ae83f913-873b-42cc-9be0-c077c6dd3ac5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"ST","value":"1","uom":25,"timeAdded":1659219974854,"timeModified":1667376142460,"dbVersion":1}]},{"id":"c52edaf1-0cf2-46af-83ba-c905e55d8615","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","name":"Tom Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f924","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219980275,"timeModified":1659219980275,"dbVersion":1,"drivers":[{"id":"2d60d34a-cf4b-4907-8a4f-020537fb0405","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"GV8","value":"1","uom":25,"timeAdded":1659219980513,"timeModified":1667376144140,"dbVersion":1},{"id":"ead3fea4-2a4a-4d51-98e6-a57394657850","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"ST","value":"1","uom":25,"timeAdded":1659219980528,"timeModified":1667376144245,"dbVersion":1}]},{"id":"f059b078-e78e-475b-8efe-0562e4d7e86e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","name":"Tom Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fd0a","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219981905,"timeModified":1659219981905,"dbVersion":1,"drivers":[{"id":"1daac6db-30b4-4aca-b002-72fe09151c72","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV0","value":"0","uom":25,"timeAdded":1659219982156,"timeModified":1667399621568,"dbVersion":1},{"id":"fc13a4c5-dd1a-4305-bac2-4b0c55731a8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV1","value":"4","uom":25,"timeAdded":1659219982168,"timeModified":1667399621763,"dbVersion":1},{"id":"6ef1f2b5-acb5-4bcd-a417-10fd20d66350","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV8","value":"1","uom":25,"timeAdded":1659219982180,"timeModified":1667399621861,"dbVersion":1},{"id":"22fc6eaa-2155-4a52-b9de-01d037904601","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"ST","value":"1","uom":25,"timeAdded":1659219982193,"timeModified":1667376144642,"dbVersion":1}]},{"id":"c3ab3751-e116-4a92-8c10-bda2bcb7f7b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","name":"Margie Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fdb4","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219975781,"timeModified":1659219975781,"dbVersion":1,"drivers":[{"id":"fc8a3293-30cc-48db-ab5a-a0b6cd299b28","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV0","value":"0","uom":25,"timeAdded":1659219976036,"timeModified":1667397534012,"dbVersion":1},{"id":"83279de0-998a-449e-a145-e54c0348a5b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV1","value":"4","uom":25,"timeAdded":1659219976048,"timeModified":1667397534160,"dbVersion":1},{"id":"e0d5500f-b840-4627-829e-b1a9adc79ae0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV8","value":"1","uom":25,"timeAdded":1659219976062,"timeModified":1667397534240,"dbVersion":1},{"id":"fe877359-d308-41fc-adad-a23bf191370e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"ST","value":"1","uom":25,"timeAdded":1659219976074,"timeModified":1667376142901,"dbVersion":1}]},{"id":"1b197090-0486-43b6-9075-d5c957952cf0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","name":"Hot water circulate","nodeDefId":"yooutlet","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004424e","private":null,"isPrimary":1,"enabled":1,"timeAdded":1665181551200,"timeModified":1665181551200,"dbVersion":1,"drivers":[{"id":"951c1ea4-a045-4b8f-bfd1-6ab36922424a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV0","value":"1","uom":25,"timeAdded":1665181551466,"timeModified":1667399561462,"dbVersion":1},{"id":"79d2b2e8-bacb-4b5f-a58c-3463b4c5f6d6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV1","value":"0","uom":57,"timeAdded":1665181551481,"timeModified":1667376140591,"dbVersion":1},{"id":"688ad939-7601-46d2-a882-4333d828144b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV2","value":"0","uom":57,"timeAdded":1665181551496,"timeModified":1667376140677,"dbVersion":1},{"id":"cdddf672-7264-4068-9b5a-57039311a69a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV3","value":"0","uom":30,"timeAdded":1665181551509,"timeModified":1667399561684,"dbVersion":1},{"id":"f0ae2242-248e-453f-af1f-7cc15b0494ca","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV4","value":"0","uom":33,"timeAdded":1665181551522,"timeModified":1667399561797,"dbVersion":1},{"id":"eaede574-1d2b-4764-9135-780228d5dc44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV8","value":"1","uom":25,"timeAdded":1665181551534,"timeModified":1667399561586,"dbVersion":1},{"id":"5fc65bf9-cd13-4cda-9a27-9e33c9ad13d8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"ST","value":"1","uom":25,"timeAdded":1665181551545,"timeModified":1667376141268,"dbVersion":1}]},{"id":"50708041-836e-446e-b186-e77f09e32298","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","name":"Cantina heater","nodeDefId":"yomultiout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219969777,"timeModified":1659219969777,"dbVersion":1,"drivers":[{"id":"80039714-76ce-4f95-af07-259d9292385b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"GV8","value":"1","uom":25,"timeAdded":1659219970045,"timeModified":1667376140255,"dbVersion":1},{"id":"aff68dda-aaca-4ddf-99fd-6dd12f34d340","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"ST","value":"1","uom":25,"timeAdded":1659219970063,"timeModified":1667376140386,"dbVersion":1}]},{"id":"b32773ae-4261-4d5d-b907-a706f882dc47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","name":"Outlet-1","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610466136,"timeModified":1661610466136,"dbVersion":1,"drivers":[{"id":"ff95de04-309c-4b49-9333-324702a2959a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV0","value":"0","uom":25,"timeAdded":1661610466465,"timeModified":1667398661282,"dbVersion":1},{"id":"5271dbf3-38ef-4288-b019-358cd131d4e7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV1","value":"0","uom":57,"timeAdded":1661610466479,"timeModified":1667376146838,"dbVersion":1},{"id":"ce32098c-dbb3-4345-96d0-17fe146ec4d0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV2","value":"0","uom":57,"timeAdded":1661610466494,"timeModified":1667376146944,"dbVersion":1},{"id":"95bbc59b-4bd5-48a6-b6b1-480ef8539624","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV4","value":"0","uom":25,"timeAdded":1661610466507,"timeModified":1667376147041,"dbVersion":1},{"id":"a0dd50e0-d8ea-4573-84ca-a219e1f29d47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"ST","value":"1","uom":25,"timeAdded":1661610466522,"timeModified":1667376147157,"dbVersion":1}]},{"id":"9ece1aee-81c3-4689-a621-9842a5a2bd8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","name":"Outlet-2","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610468648,"timeModified":1661610468648,"dbVersion":1,"drivers":[{"id":"7f4417dc-ecd8-4057-8f65-ebc5529f4c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV0","value":"0","uom":25,"timeAdded":1661610468967,"timeModified":1667398661546,"dbVersion":1},{"id":"1c99ee1d-b334-4138-88d4-53210ae0899e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV1","value":"0","uom":57,"timeAdded":1661610468980,"timeModified":1667376147342,"dbVersion":1},{"id":"dafe14ea-587a-4013-a1cd-cc39e7d11c6c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV2","value":"0","uom":57,"timeAdded":1661610468994,"timeModified":1667376147443,"dbVersion":1},{"id":"5614172a-68ee-480f-92cb-c647aeb561aa","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV4","value":"1","uom":25,"timeAdded":1661610469006,"timeModified":1667376147544,"dbVersion":1},{"id":"3d3ad022-377a-4c27-a26c-326b3c9c6391","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"ST","value":"1","uom":25,"timeAdded":1661610469020,"timeModified":1667376147644,"dbVersion":1}]},{"id":"6d2c24c0-54fe-406c-960c-9af185ac102e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","name":"Cistern pump temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9b8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044460744,"timeModified":1666044460744,"dbVersion":1,"drivers":[{"id":"e59a40db-d946-4802-bc27-8ec558c8ed37","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044461244,"timeModified":1667397701830,"dbVersion":1},{"id":"7c000b9e-9df0-4b03-864b-243ce746b4a9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044461204,"timeModified":1667397701531,"dbVersion":1},{"id":"c41c2574-02ac-4f4d-b2e4-08970162b709","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLITEMP","value":"43.3","uom":17,"timeAdded":1666044461161,"timeModified":1667397701209,"dbVersion":1},{"id":"e93b7605-c0bd-47df-bb2e-f8eeef41ef46","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044461175,"timeModified":1667397701321,"dbVersion":1},{"id":"baf6fc89-6e74-4322-b806-132344159166","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044461188,"timeModified":1667397701425,"dbVersion":1},{"id":"31d9fd7e-7609-46b7-9d58-ea94bc1522dd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044461217,"timeModified":1667397701631,"dbVersion":1},{"id":"fa5df1f6-f050-4cbf-a670-a62331810eac","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044461231,"timeModified":1667397701726,"dbVersion":1},{"id":"403d579f-158a-40a7-9126-e87cfe4e0d5f","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044461255,"timeModified":1667397701922,"dbVersion":1},{"id":"db83a019-fdf2-4c89-9d2e-b080a4e014f9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044461269,"timeModified":1667397702025,"dbVersion":1},{"id":"f04d3341-5cfb-4bc6-bea9-ccd78551dafc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"ST","value":"1","uom":25,"timeAdded":1666044461282,"timeModified":1667376145643,"dbVersion":1}]},{"id":"47cf499d-343c-46b9-bb6c-63f9c1e5567e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","name":"Workshop temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9d8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044484166,"timeModified":1666044484166,"dbVersion":1,"drivers":[{"id":"576ebccd-6325-408a-9cce-4e7dd035da8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044484504,"timeModified":1667397942078,"dbVersion":1},{"id":"92c738e7-1714-4b18-9e3a-473b90ef2e56","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044484464,"timeModified":1667397941770,"dbVersion":1},{"id":"69a2ff26-72fc-4579-9187-885c2cebede9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLITEMP","value":"63.9","uom":17,"timeAdded":1666044484425,"timeModified":1667397941480,"dbVersion":1},{"id":"def96c62-1535-40a1-b8dd-d8be5b661b63","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044484439,"timeModified":1667397941578,"dbVersion":1},{"id":"b1c1cb55-2699-47d3-a20f-b39477a684de","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044484452,"timeModified":1667397941678,"dbVersion":1},{"id":"f5603084-7dc8-466f-ab99-986b36fe4425","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044484478,"timeModified":1667397941866,"dbVersion":1},{"id":"689b0176-c49b-4a20-be56-361b1bc46e78","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044484491,"timeModified":1667397941981,"dbVersion":1},{"id":"bb49d897-1bcc-4ba5-beb0-1dfda07aebdf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044484517,"timeModified":1667397942166,"dbVersion":1},{"id":"81d8f982-2122-4ab8-97c4-d9df87f19f82","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044484532,"timeModified":1667397942271,"dbVersion":1},{"id":"811a70d1-5ca7-4fd9-bd6c-c043bb70e980","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"ST","value":"1","uom":25,"timeAdded":1666044484545,"timeModified":1667376149643,"dbVersion":1}]},{"id":"612dc403-b3a7-42d3-b8ae-5f8bf377d0e3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","name":"Fountain input temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004caa9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463004,"timeModified":1666044463004,"dbVersion":1,"drivers":[{"id":"fe90f228-c9e6-441e-a4e2-f0a749787fb4","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463453,"timeModified":1667397522702,"dbVersion":1},{"id":"7f6b61c4-f789-4c03-b39e-2196f9a9abd7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463416,"timeModified":1667397522388,"dbVersion":1},{"id":"1cbff7a0-7dbf-45e8-8d9f-80c01b79d183","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLITEMP","value":"49.1","uom":17,"timeAdded":1666044463374,"timeModified":1667397522090,"dbVersion":1},{"id":"b7967d77-2db7-4847-83a9-a1cd0165900b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463389,"timeModified":1667397522200,"dbVersion":1},{"id":"e2fc26b7-c1d5-4e99-8d65-735a0bc11fc6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463403,"timeModified":1667397522293,"dbVersion":1},{"id":"3bcd9776-c11e-4412-b5d0-c37bc3e578f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463429,"timeModified":1667397522486,"dbVersion":1},{"id":"485e1816-133e-41f8-904a-81150bf07c50","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463442,"timeModified":1667397522596,"dbVersion":1},{"id":"181aa642-3113-40ff-8ec1-324347a72d02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463467,"timeModified":1667397522789,"dbVersion":1},{"id":"c285e167-0c43-420e-9944-81a5f4b23a3e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463479,"timeModified":1667397522891,"dbVersion":1},{"id":"92cf14d1-7bf6-4f08-8745-e5ecbe531802","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"ST","value":"1","uom":25,"timeAdded":1666044463492,"timeModified":1667376146643,"dbVersion":1}]},{"id":"3de77d62-9fdd-436e-b99c-cdd090dc0de3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","name":"Fountain output temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004cce6","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463309,"timeModified":1666044463309,"dbVersion":1,"drivers":[{"id":"b32e2aa0-82c2-44d9-84d8-fa23eafe7da5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463845,"timeModified":1667397524435,"dbVersion":1},{"id":"b8ace59c-8862-4cea-b086-49e4e8f30546","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463802,"timeModified":1667397524136,"dbVersion":1},{"id":"541b7da6-b8be-480e-ae79-ce537a4b3e93","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLITEMP","value":"49.8","uom":17,"timeAdded":1666044463762,"timeModified":1667397523845,"dbVersion":1},{"id":"541c287a-867d-4f76-989f-9e25426e5908","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463775,"timeModified":1667397523941,"dbVersion":1},{"id":"076a03f8-5612-4f1e-9f8e-7262427e3be7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463787,"timeModified":1667397524036,"dbVersion":1},{"id":"6196b0f6-a3e6-44a8-9ca8-245b8785794b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463816,"timeModified":1667397524247,"dbVersion":1},{"id":"d178aacd-0259-491e-a1d6-0b3ed355d4f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463831,"timeModified":1667397524342,"dbVersion":1},{"id":"7339d955-73c4-452d-9b2c-f91f493cf418","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463858,"timeModified":1667397524539,"dbVersion":1},{"id":"9366bb13-5d8f-4805-a265-f85a80d0cb58","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463872,"timeModified":1667397524641,"dbVersion":1},{"id":"3ec971a6-b75c-4403-b1bd-bf85181ff873","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"ST","value":"1","uom":25,"timeAdded":1666044463885,"timeModified":1667376148643,"dbVersion":1}]},{"id":"84765453-a4e9-4b55-a97d-7d2c0419f632","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","name":"Motion Sensor 2","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038bb9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219978109,"timeModified":1659219978109,"dbVersion":1,"drivers":[{"id":"83be7f03-907e-4c2f-818e-aeb790fa5579","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV0","value":"0","uom":25,"timeAdded":1659219978360,"timeModified":1667399381497,"dbVersion":1},{"id":"cdc38e06-a589-457c-8e42-016558b6d552","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV1","value":"4","uom":25,"timeAdded":1659219978373,"timeModified":1667399381657,"dbVersion":1},{"id":"04e9bf2c-d1ff-44d2-a7e4-e1eea73ddedb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV8","value":"1","uom":25,"timeAdded":1659219978386,"timeModified":1667399381768,"dbVersion":1},{"id":"89c54f89-b850-48b3-a539-8083310e9481","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"ST","value":"1","uom":25,"timeAdded":1659219978400,"timeModified":1667376143653,"dbVersion":1}]},{"id":"39a2d5cf-47b7-4ad3-b9b3-eb9c54fa0973","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","name":"Motion Sensor 3","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c01","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219979221,"timeModified":1659219979221,"dbVersion":1,"drivers":[{"id":"a3186ee5-5720-4bb9-88a2-6c1b39c60d70","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV0","value":"0","uom":25,"timeAdded":1659219979473,"timeModified":1667397538194,"dbVersion":1},{"id":"d4aa3ce2-0044-4f51-8b0d-6dcd775e814c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV1","value":"4","uom":25,"timeAdded":1659219979485,"timeModified":1667397538285,"dbVersion":1},{"id":"e500e1b4-fc43-4463-b8f2-33c9a5953edb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV8","value":"1","uom":25,"timeAdded":1659219979498,"timeModified":1667397538389,"dbVersion":1},{"id":"d2a83b20-053f-493d-b2c9-05a85b720809","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"ST","value":"1","uom":25,"timeAdded":1659219979509,"timeModified":1667376144040,"dbVersion":1}]},{"id":"b62973cf-64cb-4b2c-b4e3-38fc77ef3422","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","name":"Motion Sensor 1","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c02","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219977070,"timeModified":1659219977070,"dbVersion":1,"drivers":[{"id":"9bac53bf-3292-41c6-8fdf-cbf1c771eef6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV0","value":"0","uom":25,"timeAdded":1659219977320,"timeModified":1667397540208,"dbVersion":1},{"id":"fdb609fe-8fb8-4927-b4d0-d6a0006683dc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV1","value":"3","uom":25,"timeAdded":1659219977333,"timeModified":1667397540350,"dbVersion":1},{"id":"9b343a78-3275-4d4d-8744-b0079214ecce","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV8","value":"1","uom":25,"timeAdded":1659219977346,"timeModified":1667397540449,"dbVersion":1},{"id":"e8f5f98f-90e0-4bb1-a106-98ac861f85c3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"ST","value":"1","uom":25,"timeAdded":1659219977359,"timeModified":1667376143268,"dbVersion":1}]},{"id":"eeb02526-c938-4f36-a165-9375aa365c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","name":"Leak Sensor workshop","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c020006096f","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219973217,"timeModified":1659219973217,"dbVersion":1,"drivers":[{"id":"f6e1954a-b11e-44a6-8cbd-ff6b8b958b02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV0","value":"0","uom":25,"timeAdded":1659219973477,"timeModified":1667399296057,"dbVersion":1},{"id":"15d843b7-4c31-4191-b2f3-07787a378c19","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV1","value":"4","uom":25,"timeAdded":1659219973490,"timeModified":1667399296167,"dbVersion":1},{"id":"1cfe2ec4-98b8-4508-b2ce-2d5aedc91763","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV8","value":"1","uom":25,"timeAdded":1659219973503,"timeModified":1667399296254,"dbVersion":1},{"id":"c9ad6248-b2c6-4549-afbb-5fd5dafd0b44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"ST","value":"1","uom":25,"timeAdded":1659219973515,"timeModified":1667376142269,"dbVersion":1}]},{"id":"7f75a877-cbdf-4757-ac7f-51546d947f7b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","name":"Leak Sensor mechanical","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200062dc7","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219972135,"timeModified":1659219972135,"dbVersion":1,"drivers":[{"id":"4dab0393-4983-409c-9ea6-88cc7a71c67a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV0","value":"0","uom":25,"timeAdded":1659219972388,"timeModified":1667397581732,"dbVersion":1},{"id":"1a8e4797-6f40-4d5c-ad1d-3082bb283711","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV1","value":"4","uom":25,"timeAdded":1659219972402,"timeModified":1667397581857,"dbVersion":1},{"id":"f48ade65-06a3-4f51-9b2c-cd746d2cb927","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV8","value":"1","uom":25,"timeAdded":1659219972417,"timeModified":1667397581952,"dbVersion":1},{"id":"6aa5bea0-a8ea-442b-81a1-0aba21bd3845","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"ST","value":"1","uom":25,"timeAdded":1659219972430,"timeModified":1667376141908,"dbVersion":1}]},{"id":"09f24158-a0e8-4df1-8876-834ee222fbfc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","name":"Leak Sensor laundry","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200063e2d","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219971048,"timeModified":1659219971048,"dbVersion":1,"drivers":[{"id":"c0ac137c-91dd-4803-b7fb-fbefe08782a5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV0","value":"0","uom":25,"timeAdded":1659219971294,"timeModified":1667397527863,"dbVersion":1},{"id":"a0763505-4d58-4561-a881-161aa3926995","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV1","value":"4","uom":25,"timeAdded":1659219971307,"timeModified":1667397528042,"dbVersion":1},{"id":"44fab85e-1ba7-4937-83ad-825aea509aa1","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV8","value":"1","uom":25,"timeAdded":1659219971319,"timeModified":1667397528136,"dbVersion":1},{"id":"4f145713-2c94-4a40-8b6b-2b19ad489de7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"ST","value":"1","uom":25,"timeAdded":1659219971335,"timeModified":1667376141506,"dbVersion":1}]},{"id":"ff66ae77-aca3-49ea-b433-36ec9abe5cbd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","name":"YoLinkSetup","nodeDefId":"setup","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"setup","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219635531,"timeModified":1659219635531,"dbVersion":1,"drivers":[{"id":"a70e282a-e740-4523-855c-c41a01cbc884","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","driver":"ST","value":"1","uom":25,"timeAdded":1659219635789,"timeModified":1667376140104,"dbVersion":1}]}]}} 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved oauth 11/2/2022, 08:38:55 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1},{"id":"73af4323-2592-49b1-bef8-ee3b5a08e8bf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"oauth","value":"","dbVersion":1}]} 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:38:55 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1}]} 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:59 [pg3] info: [YoLink(1)]: Restarting Node server 11/2/2022, 08:38:59 [pg3] info: [YoLink(1)]: Stopping Node server 11/2/2022, 08:38:59 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"stop":{}} 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:59 [pg3] info: MQTTS: Client Disconnected: 00:0d:b9:5e:e1:4c_1 11/2/2022, 08:38:59 [pg3] debug: Client 00:0d:b9:5e:e1:4c_1 unsubscribed from udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:38:59 [pg3] debug: UpdateConnected: current status = {"connected":0} 11/2/2022, 08:38:59 [pg3] debug: ****** No connection status node/driver defined. 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:02 [pg3] info: YoLink stopped 11/2/2022, 08:39:02 [pg3] info: Waiting for YoLink to go away 11/2/2022, 08:39:02 [pg3] debug: [YoLink(1)] :: Exit cause code: null - signal: SIGTERM 11/2/2022, 08:39:02 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:06 [pg3] info: startNs:: YoLink 11/2/2022, 08:39:06 [pg3] info: startNs:: YoLink is valid 11/2/2022, 08:39:06 [pg3] info: UPGRADE AVAILABLE from 0.5.21 to 0.6.1 11/2/2022, 08:39:06 [pg3] debug: Deploy YoLink in /var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:39:06 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 08:39:06 [pg3] error: YoLink automatic update failed 11/2/2022, 08:39:06 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"restartNs":{"success":false,"error":"automatic update failed"}} 11/2/2022, 08:39:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:19 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:39:19 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:39:19 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/node servers/admin to broker pg3_broker 11/2/2022, 08:39:30 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:39:30 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:39:30 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:39:42 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"notices":{},"nodes":[{"id":"813b4952-e08d-4fe0-83c7-88adde7d8266","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","name":"Margie Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f77c","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219974598,"timeModified":1659219974598,"dbVersion":1,"drivers":[{"id":"601a4002-db02-462b-b13f-1e07b548f93e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"GV8","value":"1","uom":25,"timeAdded":1659219974841,"timeModified":1667376142394,"dbVersion":1},{"id":"ae83f913-873b-42cc-9be0-c077c6dd3ac5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"ST","value":"1","uom":25,"timeAdded":1659219974854,"timeModified":1667376142460,"dbVersion":1}]},{"id":"c52edaf1-0cf2-46af-83ba-c905e55d8615","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","name":"Tom Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f924","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219980275,"timeModified":1659219980275,"dbVersion":1,"drivers":[{"id":"2d60d34a-cf4b-4907-8a4f-020537fb0405","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"GV8","value":"1","uom":25,"timeAdded":1659219980513,"timeModified":1667376144140,"dbVersion":1},{"id":"ead3fea4-2a4a-4d51-98e6-a57394657850","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"ST","value":"1","uom":25,"timeAdded":1659219980528,"timeModified":1667376144245,"dbVersion":1}]},{"id":"f059b078-e78e-475b-8efe-0562e4d7e86e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","name":"Tom Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fd0a","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219981905,"timeModified":1659219981905,"dbVersion":1,"drivers":[{"id":"1daac6db-30b4-4aca-b002-72fe09151c72","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV0","value":"0","uom":25,"timeAdded":1659219982156,"timeModified":1667399621568,"dbVersion":1},{"id":"fc13a4c5-dd1a-4305-bac2-4b0c55731a8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV1","value":"4","uom":25,"timeAdded":1659219982168,"timeModified":1667399621763,"dbVersion":1},{"id":"6ef1f2b5-acb5-4bcd-a417-10fd20d66350","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV8","value":"1","uom":25,"timeAdded":1659219982180,"timeModified":1667399621861,"dbVersion":1},{"id":"22fc6eaa-2155-4a52-b9de-01d037904601","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"ST","value":"1","uom":25,"timeAdded":1659219982193,"timeModified":1667376144642,"dbVersion":1}]},{"id":"c3ab3751-e116-4a92-8c10-bda2bcb7f7b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","name":"Margie Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fdb4","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219975781,"timeModified":1659219975781,"dbVersion":1,"drivers":[{"id":"fc8a3293-30cc-48db-ab5a-a0b6cd299b28","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV0","value":"0","uom":25,"timeAdded":1659219976036,"timeModified":1667397534012,"dbVersion":1},{"id":"83279de0-998a-449e-a145-e54c0348a5b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV1","value":"4","uom":25,"timeAdded":1659219976048,"timeModified":1667397534160,"dbVersion":1},{"id":"e0d5500f-b840-4627-829e-b1a9adc79ae0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV8","value":"1","uom":25,"timeAdded":1659219976062,"timeModified":1667397534240,"dbVersion":1},{"id":"fe877359-d308-41fc-adad-a23bf191370e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"ST","value":"1","uom":25,"timeAdded":1659219976074,"timeModified":1667376142901,"dbVersion":1}]},{"id":"1b197090-0486-43b6-9075-d5c957952cf0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","name":"Hot water circulate","nodeDefId":"yooutlet","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004424e","private":null,"isPrimary":1,"enabled":1,"timeAdded":1665181551200,"timeModified":1665181551200,"dbVersion":1,"drivers":[{"id":"951c1ea4-a045-4b8f-bfd1-6ab36922424a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV0","value":"1","uom":25,"timeAdded":1665181551466,"timeModified":1667399561462,"dbVersion":1},{"id":"79d2b2e8-bacb-4b5f-a58c-3463b4c5f6d6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV1","value":"0","uom":57,"timeAdded":1665181551481,"timeModified":1667376140591,"dbVersion":1},{"id":"688ad939-7601-46d2-a882-4333d828144b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV2","value":"0","uom":57,"timeAdded":1665181551496,"timeModified":1667376140677,"dbVersion":1},{"id":"cdddf672-7264-4068-9b5a-57039311a69a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV3","value":"0","uom":30,"timeAdded":1665181551509,"timeModified":1667399561684,"dbVersion":1},{"id":"f0ae2242-248e-453f-af1f-7cc15b0494ca","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV4","value":"0","uom":33,"timeAdded":1665181551522,"timeModified":1667399561797,"dbVersion":1},{"id":"eaede574-1d2b-4764-9135-780228d5dc44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV8","value":"1","uom":25,"timeAdded":1665181551534,"timeModified":1667399561586,"dbVersion":1},{"id":"5fc65bf9-cd13-4cda-9a27-9e33c9ad13d8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"ST","value":"1","uom":25,"timeAdded":1665181551545,"timeModified":1667376141268,"dbVersion":1}]},{"id":"50708041-836e-446e-b186-e77f09e32298","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","name":"Cantina heater","nodeDefId":"yomultiout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219969777,"timeModified":1659219969777,"dbVersion":1,"drivers":[{"id":"80039714-76ce-4f95-af07-259d9292385b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"GV8","value":"1","uom":25,"timeAdded":1659219970045,"timeModified":1667376140255,"dbVersion":1},{"id":"aff68dda-aaca-4ddf-99fd-6dd12f34d340","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"ST","value":"1","uom":25,"timeAdded":1659219970063,"timeModified":1667376140386,"dbVersion":1}]},{"id":"b32773ae-4261-4d5d-b907-a706f882dc47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","name":"Outlet-1","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610466136,"timeModified":1661610466136,"dbVersion":1,"drivers":[{"id":"ff95de04-309c-4b49-9333-324702a2959a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV0","value":"0","uom":25,"timeAdded":1661610466465,"timeModified":1667398661282,"dbVersion":1},{"id":"5271dbf3-38ef-4288-b019-358cd131d4e7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV1","value":"0","uom":57,"timeAdded":1661610466479,"timeModified":1667376146838,"dbVersion":1},{"id":"ce32098c-dbb3-4345-96d0-17fe146ec4d0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV2","value":"0","uom":57,"timeAdded":1661610466494,"timeModified":1667376146944,"dbVersion":1},{"id":"95bbc59b-4bd5-48a6-b6b1-480ef8539624","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV4","value":"0","uom":25,"timeAdded":1661610466507,"timeModified":1667376147041,"dbVersion":1},{"id":"a0dd50e0-d8ea-4573-84ca-a219e1f29d47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"ST","value":"1","uom":25,"timeAdded":1661610466522,"timeModified":1667376147157,"dbVersion":1}]},{"id":"9ece1aee-81c3-4689-a621-9842a5a2bd8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","name":"Outlet-2","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610468648,"timeModified":1661610468648,"dbVersion":1,"drivers":[{"id":"7f4417dc-ecd8-4057-8f65-ebc5529f4c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV0","value":"0","uom":25,"timeAdded":1661610468967,"timeModified":1667398661546,"dbVersion":1},{"id":"1c99ee1d-b334-4138-88d4-53210ae0899e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV1","value":"0","uom":57,"timeAdded":1661610468980,"timeModified":1667376147342,"dbVersion":1},{"id":"dafe14ea-587a-4013-a1cd-cc39e7d11c6c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV2","value":"0","uom":57,"timeAdded":1661610468994,"timeModified":1667376147443,"dbVersion":1},{"id":"5614172a-68ee-480f-92cb-c647aeb561aa","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV4","value":"1","uom":25,"timeAdded":1661610469006,"timeModified":1667376147544,"dbVersion":1},{"id":"3d3ad022-377a-4c27-a26c-326b3c9c6391","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"ST","value":"1","uom":25,"timeAdded":1661610469020,"timeModified":1667376147644,"dbVersion":1}]},{"id":"6d2c24c0-54fe-406c-960c-9af185ac102e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","name":"Cistern pump temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9b8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044460744,"timeModified":1666044460744,"dbVersion":1,"drivers":[{"id":"e59a40db-d946-4802-bc27-8ec558c8ed37","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044461244,"timeModified":1667397701830,"dbVersion":1},{"id":"7c000b9e-9df0-4b03-864b-243ce746b4a9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044461204,"timeModified":1667397701531,"dbVersion":1},{"id":"c41c2574-02ac-4f4d-b2e4-08970162b709","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLITEMP","value":"43.3","uom":17,"timeAdded":1666044461161,"timeModified":1667397701209,"dbVersion":1},{"id":"e93b7605-c0bd-47df-bb2e-f8eeef41ef46","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044461175,"timeModified":1667397701321,"dbVersion":1},{"id":"baf6fc89-6e74-4322-b806-132344159166","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044461188,"timeModified":1667397701425,"dbVersion":1},{"id":"31d9fd7e-7609-46b7-9d58-ea94bc1522dd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044461217,"timeModified":1667397701631,"dbVersion":1},{"id":"fa5df1f6-f050-4cbf-a670-a62331810eac","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044461231,"timeModified":1667397701726,"dbVersion":1},{"id":"403d579f-158a-40a7-9126-e87cfe4e0d5f","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044461255,"timeModified":1667397701922,"dbVersion":1},{"id":"db83a019-fdf2-4c89-9d2e-b080a4e014f9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044461269,"timeModified":1667397702025,"dbVersion":1},{"id":"f04d3341-5cfb-4bc6-bea9-ccd78551dafc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"ST","value":"1","uom":25,"timeAdded":1666044461282,"timeModified":1667376145643,"dbVersion":1}]},{"id":"47cf499d-343c-46b9-bb6c-63f9c1e5567e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","name":"Workshop temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9d8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044484166,"timeModified":1666044484166,"dbVersion":1,"drivers":[{"id":"576ebccd-6325-408a-9cce-4e7dd035da8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044484504,"timeModified":1667397942078,"dbVersion":1},{"id":"92c738e7-1714-4b18-9e3a-473b90ef2e56","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044484464,"timeModified":1667397941770,"dbVersion":1},{"id":"69a2ff26-72fc-4579-9187-885c2cebede9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLITEMP","value":"63.9","uom":17,"timeAdded":1666044484425,"timeModified":1667397941480,"dbVersion":1},{"id":"def96c62-1535-40a1-b8dd-d8be5b661b63","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044484439,"timeModified":1667397941578,"dbVersion":1},{"id":"b1c1cb55-2699-47d3-a20f-b39477a684de","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044484452,"timeModified":1667397941678,"dbVersion":1},{"id":"f5603084-7dc8-466f-ab99-986b36fe4425","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044484478,"timeModified":1667397941866,"dbVersion":1},{"id":"689b0176-c49b-4a20-be56-361b1bc46e78","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044484491,"timeModified":1667397941981,"dbVersion":1},{"id":"bb49d897-1bcc-4ba5-beb0-1dfda07aebdf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044484517,"timeModified":1667397942166,"dbVersion":1},{"id":"81d8f982-2122-4ab8-97c4-d9df87f19f82","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044484532,"timeModified":1667397942271,"dbVersion":1},{"id":"811a70d1-5ca7-4fd9-bd6c-c043bb70e980","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"ST","value":"1","uom":25,"timeAdded":1666044484545,"timeModified":1667376149643,"dbVersion":1}]},{"id":"612dc403-b3a7-42d3-b8ae-5f8bf377d0e3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","name":"Fountain input temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004caa9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463004,"timeModified":1666044463004,"dbVersion":1,"drivers":[{"id":"fe90f228-c9e6-441e-a4e2-f0a749787fb4","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463453,"timeModified":1667397522702,"dbVersion":1},{"id":"7f6b61c4-f789-4c03-b39e-2196f9a9abd7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463416,"timeModified":1667397522388,"dbVersion":1},{"id":"1cbff7a0-7dbf-45e8-8d9f-80c01b79d183","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLITEMP","value":"49.1","uom":17,"timeAdded":1666044463374,"timeModified":1667397522090,"dbVersion":1},{"id":"b7967d77-2db7-4847-83a9-a1cd0165900b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463389,"timeModified":1667397522200,"dbVersion":1},{"id":"e2fc26b7-c1d5-4e99-8d65-735a0bc11fc6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463403,"timeModified":1667397522293,"dbVersion":1},{"id":"3bcd9776-c11e-4412-b5d0-c37bc3e578f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463429,"timeModified":1667397522486,"dbVersion":1},{"id":"485e1816-133e-41f8-904a-81150bf07c50","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463442,"timeModified":1667397522596,"dbVersion":1},{"id":"181aa642-3113-40ff-8ec1-324347a72d02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463467,"timeModified":1667397522789,"dbVersion":1},{"id":"c285e167-0c43-420e-9944-81a5f4b23a3e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463479,"timeModified":1667397522891,"dbVersion":1},{"id":"92cf14d1-7bf6-4f08-8745-e5ecbe531802","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"ST","value":"1","uom":25,"timeAdded":1666044463492,"timeModified":1667376146643,"dbVersion":1}]},{"id":"3de77d62-9fdd-436e-b99c-cdd090dc0de3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","name":"Fountain output temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004cce6","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463309,"timeModified":1666044463309,"dbVersion":1,"drivers":[{"id":"b32e2aa0-82c2-44d9-84d8-fa23eafe7da5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463845,"timeModified":1667397524435,"dbVersion":1},{"id":"b8ace59c-8862-4cea-b086-49e4e8f30546","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463802,"timeModified":1667397524136,"dbVersion":1},{"id":"541b7da6-b8be-480e-ae79-ce537a4b3e93","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLITEMP","value":"49.8","uom":17,"timeAdded":1666044463762,"timeModified":1667397523845,"dbVersion":1},{"id":"541c287a-867d-4f76-989f-9e25426e5908","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463775,"timeModified":1667397523941,"dbVersion":1},{"id":"076a03f8-5612-4f1e-9f8e-7262427e3be7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463787,"timeModified":1667397524036,"dbVersion":1},{"id":"6196b0f6-a3e6-44a8-9ca8-245b8785794b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463816,"timeModified":1667397524247,"dbVersion":1},{"id":"d178aacd-0259-491e-a1d6-0b3ed355d4f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463831,"timeModified":1667397524342,"dbVersion":1},{"id":"7339d955-73c4-452d-9b2c-f91f493cf418","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463858,"timeModified":1667397524539,"dbVersion":1},{"id":"9366bb13-5d8f-4805-a265-f85a80d0cb58","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463872,"timeModified":1667397524641,"dbVersion":1},{"id":"3ec971a6-b75c-4403-b1bd-bf85181ff873","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"ST","value":"1","uom":25,"timeAdded":1666044463885,"timeModified":1667376148643,"dbVersion":1}]},{"id":"84765453-a4e9-4b55-a97d-7d2c0419f632","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","name":"Motion Sensor 2","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038bb9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219978109,"timeModified":1659219978109,"dbVersion":1,"drivers":[{"id":"83be7f03-907e-4c2f-818e-aeb790fa5579","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV0","value":"0","uom":25,"timeAdded":1659219978360,"timeModified":1667399381497,"dbVersion":1},{"id":"cdc38e06-a589-457c-8e42-016558b6d552","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV1","value":"4","uom":25,"timeAdded":1659219978373,"timeModified":1667399381657,"dbVersion":1},{"id":"04e9bf2c-d1ff-44d2-a7e4-e1eea73ddedb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV8","value":"1","uom":25,"timeAdded":1659219978386,"timeModified":1667399381768,"dbVersion":1},{"id":"89c54f89-b850-48b3-a539-8083310e9481","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"ST","value":"1","uom":25,"timeAdded":1659219978400,"timeModified":1667376143653,"dbVersion":1}]},{"id":"39a2d5cf-47b7-4ad3-b9b3-eb9c54fa0973","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","name":"Motion Sensor 3","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c01","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219979221,"timeModified":1659219979221,"dbVersion":1,"drivers":[{"id":"a3186ee5-5720-4bb9-88a2-6c1b39c60d70","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV0","value":"0","uom":25,"timeAdded":1659219979473,"timeModified":1667397538194,"dbVersion":1},{"id":"d4aa3ce2-0044-4f51-8b0d-6dcd775e814c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV1","value":"4","uom":25,"timeAdded":1659219979485,"timeModified":1667397538285,"dbVersion":1},{"id":"e500e1b4-fc43-4463-b8f2-33c9a5953edb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV8","value":"1","uom":25,"timeAdded":1659219979498,"timeModified":1667397538389,"dbVersion":1},{"id":"d2a83b20-053f-493d-b2c9-05a85b720809","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"ST","value":"1","uom":25,"timeAdded":1659219979509,"timeModified":1667376144040,"dbVersion":1}]},{"id":"b62973cf-64cb-4b2c-b4e3-38fc77ef3422","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","name":"Motion Sensor 1","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c02","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219977070,"timeModified":1659219977070,"dbVersion":1,"drivers":[{"id":"9bac53bf-3292-41c6-8fdf-cbf1c771eef6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV0","value":"0","uom":25,"timeAdded":1659219977320,"timeModified":1667397540208,"dbVersion":1},{"id":"fdb609fe-8fb8-4927-b4d0-d6a0006683dc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV1","value":"3","uom":25,"timeAdded":1659219977333,"timeModified":1667397540350,"dbVersion":1},{"id":"9b343a78-3275-4d4d-8744-b0079214ecce","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV8","value":"1","uom":25,"timeAdded":1659219977346,"timeModified":1667397540449,"dbVersion":1},{"id":"e8f5f98f-90e0-4bb1-a106-98ac861f85c3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"ST","value":"1","uom":25,"timeAdded":1659219977359,"timeModified":1667376143268,"dbVersion":1}]},{"id":"eeb02526-c938-4f36-a165-9375aa365c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","name":"Leak Sensor workshop","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c020006096f","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219973217,"timeModified":1659219973217,"dbVersion":1,"drivers":[{"id":"f6e1954a-b11e-44a6-8cbd-ff6b8b958b02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV0","value":"0","uom":25,"timeAdded":1659219973477,"timeModified":1667399296057,"dbVersion":1},{"id":"15d843b7-4c31-4191-b2f3-07787a378c19","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV1","value":"4","uom":25,"timeAdded":1659219973490,"timeModified":1667399296167,"dbVersion":1},{"id":"1cfe2ec4-98b8-4508-b2ce-2d5aedc91763","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV8","value":"1","uom":25,"timeAdded":1659219973503,"timeModified":1667399296254,"dbVersion":1},{"id":"c9ad6248-b2c6-4549-afbb-5fd5dafd0b44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"ST","value":"1","uom":25,"timeAdded":1659219973515,"timeModified":1667376142269,"dbVersion":1}]},{"id":"7f75a877-cbdf-4757-ac7f-51546d947f7b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","name":"Leak Sensor mechanical","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200062dc7","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219972135,"timeModified":1659219972135,"dbVersion":1,"drivers":[{"id":"4dab0393-4983-409c-9ea6-88cc7a71c67a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV0","value":"0","uom":25,"timeAdded":1659219972388,"timeModified":1667397581732,"dbVersion":1},{"id":"1a8e4797-6f40-4d5c-ad1d-3082bb283711","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV1","value":"4","uom":25,"timeAdded":1659219972402,"timeModified":1667397581857,"dbVersion":1},{"id":"f48ade65-06a3-4f51-9b2c-cd746d2cb927","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV8","value":"1","uom":25,"timeAdded":1659219972417,"timeModified":1667397581952,"dbVersion":1},{"id":"6aa5bea0-a8ea-442b-81a1-0aba21bd3845","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"ST","value":"1","uom":25,"timeAdded":1659219972430,"timeModified":1667376141908,"dbVersion":1}]},{"id":"09f24158-a0e8-4df1-8876-834ee222fbfc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","name":"Leak Sensor laundry","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200063e2d","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219971048,"timeModified":1659219971048,"dbVersion":1,"drivers":[{"id":"c0ac137c-91dd-4803-b7fb-fbefe08782a5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV0","value":"0","uom":25,"timeAdded":1659219971294,"timeModified":1667397527863,"dbVersion":1},{"id":"a0763505-4d58-4561-a881-161aa3926995","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV1","value":"4","uom":25,"timeAdded":1659219971307,"timeModified":1667397528042,"dbVersion":1},{"id":"44fab85e-1ba7-4937-83ad-825aea509aa1","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV8","value":"1","uom":25,"timeAdded":1659219971319,"timeModified":1667397528136,"dbVersion":1},{"id":"4f145713-2c94-4a40-8b6b-2b19ad489de7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"ST","value":"1","uom":25,"timeAdded":1659219971335,"timeModified":1667376141506,"dbVersion":1}]},{"id":"ff66ae77-aca3-49ea-b433-36ec9abe5cbd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","name":"YoLinkSetup","nodeDefId":"setup","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"setup","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219635531,"timeModified":1659219635531,"dbVersion":1,"drivers":[{"id":"a70e282a-e740-4523-855c-c41a01cbc884","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","driver":"ST","value":"1","uom":25,"timeAdded":1659219635789,"timeModified":1667376140104,"dbVersion":1}]}]}} 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved oauth 11/2/2022, 08:39:42 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1},{"id":"73af4323-2592-49b1-bef8-ee3b5a08e8bf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"oauth","value":"","dbVersion":1}]} 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:55 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:39:55 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:39:55 [pg3] debug: Sending logfile to frontend :: /var/polyglot/pg3/logs/pg3-current.log 11/2/2022, 08:39:55 [pg3] debug: Client pg3frontend_vBMOo subscribed to udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/main 11/2/2022, 08:39:55 [pg3] debug: Starting log stream for pg3frontend_vBMOo :: /var/polyglot/pg3/logs/pg3-current.log 11/2/2022, 08:40:37 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/main 11/2/2022, 08:40:37 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:40:37 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:40:37 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:40:37 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:40:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:40:39 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"notices":{},"nodes":[{"id":"813b4952-e08d-4fe0-83c7-88adde7d8266","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","name":"Margie Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f77c","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219974598,"timeModified":1659219974598,"dbVersion":1,"drivers":[{"id":"601a4002-db02-462b-b13f-1e07b548f93e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"GV8","value":"1","uom":25,"timeAdded":1659219974841,"timeModified":1667376142394,"dbVersion":1},{"id":"ae83f913-873b-42cc-9be0-c077c6dd3ac5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"ST","value":"1","uom":25,"timeAdded":1659219974854,"timeModified":1667376142460,"dbVersion":1}]},{"id":"c52edaf1-0cf2-46af-83ba-c905e55d8615","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","name":"Tom Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f924","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219980275,"timeModified":1659219980275,"dbVersion":1,"drivers":[{"id":"2d60d34a-cf4b-4907-8a4f-020537fb0405","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"GV8","value":"1","uom":25,"timeAdded":1659219980513,"timeModified":1667376144140,"dbVersion":1},{"id":"ead3fea4-2a4a-4d51-98e6-a57394657850","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"ST","value":"1","uom":25,"timeAdded":1659219980528,"timeModified":1667376144245,"dbVersion":1}]},{"id":"f059b078-e78e-475b-8efe-0562e4d7e86e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","name":"Tom Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fd0a","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219981905,"timeModified":1659219981905,"dbVersion":1,"drivers":[{"id":"1daac6db-30b4-4aca-b002-72fe09151c72","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV0","value":"0","uom":25,"timeAdded":1659219982156,"timeModified":1667399621568,"dbVersion":1},{"id":"fc13a4c5-dd1a-4305-bac2-4b0c55731a8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV1","value":"4","uom":25,"timeAdded":1659219982168,"timeModified":1667399621763,"dbVersion":1},{"id":"6ef1f2b5-acb5-4bcd-a417-10fd20d66350","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV8","value":"1","uom":25,"timeAdded":1659219982180,"timeModified":1667399621861,"dbVersion":1},{"id":"22fc6eaa-2155-4a52-b9de-01d037904601","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"ST","value":"1","uom":25,"timeAdded":1659219982193,"timeModified":1667376144642,"dbVersion":1}]},{"id":"c3ab3751-e116-4a92-8c10-bda2bcb7f7b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","name":"Margie Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fdb4","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219975781,"timeModified":1659219975781,"dbVersion":1,"drivers":[{"id":"fc8a3293-30cc-48db-ab5a-a0b6cd299b28","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV0","value":"0","uom":25,"timeAdded":1659219976036,"timeModified":1667397534012,"dbVersion":1},{"id":"83279de0-998a-449e-a145-e54c0348a5b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV1","value":"4","uom":25,"timeAdded":1659219976048,"timeModified":1667397534160,"dbVersion":1},{"id":"e0d5500f-b840-4627-829e-b1a9adc79ae0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV8","value":"1","uom":25,"timeAdded":1659219976062,"timeModified":1667397534240,"dbVersion":1},{"id":"fe877359-d308-41fc-adad-a23bf191370e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"ST","value":"1","uom":25,"timeAdded":1659219976074,"timeModified":1667376142901,"dbVersion":1}]},{"id":"1b197090-0486-43b6-9075-d5c957952cf0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","name":"Hot water circulate","nodeDefId":"yooutlet","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004424e","private":null,"isPrimary":1,"enabled":1,"timeAdded":1665181551200,"timeModified":1665181551200,"dbVersion":1,"drivers":[{"id":"951c1ea4-a045-4b8f-bfd1-6ab36922424a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV0","value":"1","uom":25,"timeAdded":1665181551466,"timeModified":1667399561462,"dbVersion":1},{"id":"79d2b2e8-bacb-4b5f-a58c-3463b4c5f6d6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV1","value":"0","uom":57,"timeAdded":1665181551481,"timeModified":1667376140591,"dbVersion":1},{"id":"688ad939-7601-46d2-a882-4333d828144b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV2","value":"0","uom":57,"timeAdded":1665181551496,"timeModified":1667376140677,"dbVersion":1},{"id":"cdddf672-7264-4068-9b5a-57039311a69a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV3","value":"0","uom":30,"timeAdded":1665181551509,"timeModified":1667399561684,"dbVersion":1},{"id":"f0ae2242-248e-453f-af1f-7cc15b0494ca","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV4","value":"0","uom":33,"timeAdded":1665181551522,"timeModified":1667399561797,"dbVersion":1},{"id":"eaede574-1d2b-4764-9135-780228d5dc44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV8","value":"1","uom":25,"timeAdded":1665181551534,"timeModified":1667399561586,"dbVersion":1},{"id":"5fc65bf9-cd13-4cda-9a27-9e33c9ad13d8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"ST","value":"1","uom":25,"timeAdded":1665181551545,"timeModified":1667376141268,"dbVersion":1}]},{"id":"50708041-836e-446e-b186-e77f09e32298","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","name":"Cantina heater","nodeDefId":"yomultiout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219969777,"timeModified":1659219969777,"dbVersion":1,"drivers":[{"id":"80039714-76ce-4f95-af07-259d9292385b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"GV8","value":"1","uom":25,"timeAdded":1659219970045,"timeModified":1667376140255,"dbVersion":1},{"id":"aff68dda-aaca-4ddf-99fd-6dd12f34d340","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"ST","value":"1","uom":25,"timeAdded":1659219970063,"timeModified":1667376140386,"dbVersion":1}]},{"id":"b32773ae-4261-4d5d-b907-a706f882dc47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","name":"Outlet-1","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610466136,"timeModified":1661610466136,"dbVersion":1,"drivers":[{"id":"ff95de04-309c-4b49-9333-324702a2959a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV0","value":"0","uom":25,"timeAdded":1661610466465,"timeModified":1667398661282,"dbVersion":1},{"id":"5271dbf3-38ef-4288-b019-358cd131d4e7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV1","value":"0","uom":57,"timeAdded":1661610466479,"timeModified":1667376146838,"dbVersion":1},{"id":"ce32098c-dbb3-4345-96d0-17fe146ec4d0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV2","value":"0","uom":57,"timeAdded":1661610466494,"timeModified":1667376146944,"dbVersion":1},{"id":"95bbc59b-4bd5-48a6-b6b1-480ef8539624","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV4","value":"0","uom":25,"timeAdded":1661610466507,"timeModified":1667376147041,"dbVersion":1},{"id":"a0dd50e0-d8ea-4573-84ca-a219e1f29d47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"ST","value":"1","uom":25,"timeAdded":1661610466522,"timeModified":1667376147157,"dbVersion":1}]},{"id":"9ece1aee-81c3-4689-a621-9842a5a2bd8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","name":"Outlet-2","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610468648,"timeModified":1661610468648,"dbVersion":1,"drivers":[{"id":"7f4417dc-ecd8-4057-8f65-ebc5529f4c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV0","value":"0","uom":25,"timeAdded":1661610468967,"timeModified":1667398661546,"dbVersion":1},{"id":"1c99ee1d-b334-4138-88d4-53210ae0899e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV1","value":"0","uom":57,"timeAdded":1661610468980,"timeModified":1667376147342,"dbVersion":1},{"id":"dafe14ea-587a-4013-a1cd-cc39e7d11c6c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV2","value":"0","uom":57,"timeAdded":1661610468994,"timeModified":1667376147443,"dbVersion":1},{"id":"5614172a-68ee-480f-92cb-c647aeb561aa","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV4","value":"1","uom":25,"timeAdded":1661610469006,"timeModified":1667376147544,"dbVersion":1},{"id":"3d3ad022-377a-4c27-a26c-326b3c9c6391","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"ST","value":"1","uom":25,"timeAdded":1661610469020,"timeModified":1667376147644,"dbVersion":1}]},{"id":"6d2c24c0-54fe-406c-960c-9af185ac102e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","name":"Cistern pump temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9b8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044460744,"timeModified":1666044460744,"dbVersion":1,"drivers":[{"id":"e59a40db-d946-4802-bc27-8ec558c8ed37","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044461244,"timeModified":1667397701830,"dbVersion":1},{"id":"7c000b9e-9df0-4b03-864b-243ce746b4a9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044461204,"timeModified":1667397701531,"dbVersion":1},{"id":"c41c2574-02ac-4f4d-b2e4-08970162b709","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLITEMP","value":"43.3","uom":17,"timeAdded":1666044461161,"timeModified":1667397701209,"dbVersion":1},{"id":"e93b7605-c0bd-47df-bb2e-f8eeef41ef46","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044461175,"timeModified":1667397701321,"dbVersion":1},{"id":"baf6fc89-6e74-4322-b806-132344159166","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044461188,"timeModified":1667397701425,"dbVersion":1},{"id":"31d9fd7e-7609-46b7-9d58-ea94bc1522dd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044461217,"timeModified":1667397701631,"dbVersion":1},{"id":"fa5df1f6-f050-4cbf-a670-a62331810eac","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044461231,"timeModified":1667397701726,"dbVersion":1},{"id":"403d579f-158a-40a7-9126-e87cfe4e0d5f","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044461255,"timeModified":1667397701922,"dbVersion":1},{"id":"db83a019-fdf2-4c89-9d2e-b080a4e014f9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044461269,"timeModified":1667397702025,"dbVersion":1},{"id":"f04d3341-5cfb-4bc6-bea9-ccd78551dafc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"ST","value":"1","uom":25,"timeAdded":1666044461282,"timeModified":1667376145643,"dbVersion":1}]},{"id":"47cf499d-343c-46b9-bb6c-63f9c1e5567e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","name":"Workshop temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9d8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044484166,"timeModified":1666044484166,"dbVersion":1,"drivers":[{"id":"576ebccd-6325-408a-9cce-4e7dd035da8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044484504,"timeModified":1667397942078,"dbVersion":1},{"id":"92c738e7-1714-4b18-9e3a-473b90ef2e56","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044484464,"timeModified":1667397941770,"dbVersion":1},{"id":"69a2ff26-72fc-4579-9187-885c2cebede9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLITEMP","value":"63.9","uom":17,"timeAdded":1666044484425,"timeModified":1667397941480,"dbVersion":1},{"id":"def96c62-1535-40a1-b8dd-d8be5b661b63","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044484439,"timeModified":1667397941578,"dbVersion":1},{"id":"b1c1cb55-2699-47d3-a20f-b39477a684de","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044484452,"timeModified":1667397941678,"dbVersion":1},{"id":"f5603084-7dc8-466f-ab99-986b36fe4425","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044484478,"timeModified":1667397941866,"dbVersion":1},{"id":"689b0176-c49b-4a20-be56-361b1bc46e78","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044484491,"timeModified":1667397941981,"dbVersion":1},{"id":"bb49d897-1bcc-4ba5-beb0-1dfda07aebdf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044484517,"timeModified":1667397942166,"dbVersion":1},{"id":"81d8f982-2122-4ab8-97c4-d9df87f19f82","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044484532,"timeModified":1667397942271,"dbVersion":1},{"id":"811a70d1-5ca7-4fd9-bd6c-c043bb70e980","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"ST","value":"1","uom":25,"timeAdded":1666044484545,"timeModified":1667376149643,"dbVersion":1}]},{"id":"612dc403-b3a7-42d3-b8ae-5f8bf377d0e3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","name":"Fountain input temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004caa9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463004,"timeModified":1666044463004,"dbVersion":1,"drivers":[{"id":"fe90f228-c9e6-441e-a4e2-f0a749787fb4","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463453,"timeModified":1667397522702,"dbVersion":1},{"id":"7f6b61c4-f789-4c03-b39e-2196f9a9abd7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463416,"timeModified":1667397522388,"dbVersion":1},{"id":"1cbff7a0-7dbf-45e8-8d9f-80c01b79d183","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLITEMP","value":"49.1","uom":17,"timeAdded":1666044463374,"timeModified":1667397522090,"dbVersion":1},{"id":"b7967d77-2db7-4847-83a9-a1cd0165900b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463389,"timeModified":1667397522200,"dbVersion":1},{"id":"e2fc26b7-c1d5-4e99-8d65-735a0bc11fc6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463403,"timeModified":1667397522293,"dbVersion":1},{"id":"3bcd9776-c11e-4412-b5d0-c37bc3e578f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463429,"timeModified":1667397522486,"dbVersion":1},{"id":"485e1816-133e-41f8-904a-81150bf07c50","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463442,"timeModified":1667397522596,"dbVersion":1},{"id":"181aa642-3113-40ff-8ec1-324347a72d02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463467,"timeModified":1667397522789,"dbVersion":1},{"id":"c285e167-0c43-420e-9944-81a5f4b23a3e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463479,"timeModified":1667397522891,"dbVersion":1},{"id":"92cf14d1-7bf6-4f08-8745-e5ecbe531802","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"ST","value":"1","uom":25,"timeAdded":1666044463492,"timeModified":1667376146643,"dbVersion":1}]},{"id":"3de77d62-9fdd-436e-b99c-cdd090dc0de3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","name":"Fountain output temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004cce6","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463309,"timeModified":1666044463309,"dbVersion":1,"drivers":[{"id":"b32e2aa0-82c2-44d9-84d8-fa23eafe7da5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463845,"timeModified":1667397524435,"dbVersion":1},{"id":"b8ace59c-8862-4cea-b086-49e4e8f30546","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463802,"timeModified":1667397524136,"dbVersion":1},{"id":"541b7da6-b8be-480e-ae79-ce537a4b3e93","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLITEMP","value":"49.8","uom":17,"timeAdded":1666044463762,"timeModified":1667397523845,"dbVersion":1},{"id":"541c287a-867d-4f76-989f-9e25426e5908","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463775,"timeModified":1667397523941,"dbVersion":1},{"id":"076a03f8-5612-4f1e-9f8e-7262427e3be7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463787,"timeModified":1667397524036,"dbVersion":1},{"id":"6196b0f6-a3e6-44a8-9ca8-245b8785794b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463816,"timeModified":1667397524247,"dbVersion":1},{"id":"d178aacd-0259-491e-a1d6-0b3ed355d4f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463831,"timeModified":1667397524342,"dbVersion":1},{"id":"7339d955-73c4-452d-9b2c-f91f493cf418","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463858,"timeModified":1667397524539,"dbVersion":1},{"id":"9366bb13-5d8f-4805-a265-f85a80d0cb58","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463872,"timeModified":1667397524641,"dbVersion":1},{"id":"3ec971a6-b75c-4403-b1bd-bf85181ff873","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"ST","value":"1","uom":25,"timeAdded":1666044463885,"timeModified":1667376148643,"dbVersion":1}]},{"id":"84765453-a4e9-4b55-a97d-7d2c0419f632","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","name":"Motion Sensor 2","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038bb9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219978109,"timeModified":1659219978109,"dbVersion":1,"drivers":[{"id":"83be7f03-907e-4c2f-818e-aeb790fa5579","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV0","value":"0","uom":25,"timeAdded":1659219978360,"timeModified":1667399381497,"dbVersion":1},{"id":"cdc38e06-a589-457c-8e42-016558b6d552","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV1","value":"4","uom":25,"timeAdded":1659219978373,"timeModified":1667399381657,"dbVersion":1},{"id":"04e9bf2c-d1ff-44d2-a7e4-e1eea73ddedb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV8","value":"1","uom":25,"timeAdded":1659219978386,"timeModified":1667399381768,"dbVersion":1},{"id":"89c54f89-b850-48b3-a539-8083310e9481","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"ST","value":"1","uom":25,"timeAdded":1659219978400,"timeModified":1667376143653,"dbVersion":1}]},{"id":"39a2d5cf-47b7-4ad3-b9b3-eb9c54fa0973","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","name":"Motion Sensor 3","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c01","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219979221,"timeModified":1659219979221,"dbVersion":1,"drivers":[{"id":"a3186ee5-5720-4bb9-88a2-6c1b39c60d70","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV0","value":"0","uom":25,"timeAdded":1659219979473,"timeModified":1667397538194,"dbVersion":1},{"id":"d4aa3ce2-0044-4f51-8b0d-6dcd775e814c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV1","value":"4","uom":25,"timeAdded":1659219979485,"timeModified":1667397538285,"dbVersion":1},{"id":"e500e1b4-fc43-4463-b8f2-33c9a5953edb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV8","value":"1","uom":25,"timeAdded":1659219979498,"timeModified":1667397538389,"dbVersion":1},{"id":"d2a83b20-053f-493d-b2c9-05a85b720809","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"ST","value":"1","uom":25,"timeAdded":1659219979509,"timeModified":1667376144040,"dbVersion":1}]},{"id":"b62973cf-64cb-4b2c-b4e3-38fc77ef3422","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","name":"Motion Sensor 1","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c02","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219977070,"timeModified":1659219977070,"dbVersion":1,"drivers":[{"id":"9bac53bf-3292-41c6-8fdf-cbf1c771eef6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV0","value":"0","uom":25,"timeAdded":1659219977320,"timeModified":1667397540208,"dbVersion":1},{"id":"fdb609fe-8fb8-4927-b4d0-d6a0006683dc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV1","value":"3","uom":25,"timeAdded":1659219977333,"timeModified":1667397540350,"dbVersion":1},{"id":"9b343a78-3275-4d4d-8744-b0079214ecce","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV8","value":"1","uom":25,"timeAdded":1659219977346,"timeModified":1667397540449,"dbVersion":1},{"id":"e8f5f98f-90e0-4bb1-a106-98ac861f85c3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"ST","value":"1","uom":25,"timeAdded":1659219977359,"timeModified":1667376143268,"dbVersion":1}]},{"id":"eeb02526-c938-4f36-a165-9375aa365c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","name":"Leak Sensor workshop","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c020006096f","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219973217,"timeModified":1659219973217,"dbVersion":1,"drivers":[{"id":"f6e1954a-b11e-44a6-8cbd-ff6b8b958b02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV0","value":"0","uom":25,"timeAdded":1659219973477,"timeModified":1667399296057,"dbVersion":1},{"id":"15d843b7-4c31-4191-b2f3-07787a378c19","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV1","value":"4","uom":25,"timeAdded":1659219973490,"timeModified":1667399296167,"dbVersion":1},{"id":"1cfe2ec4-98b8-4508-b2ce-2d5aedc91763","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV8","value":"1","uom":25,"timeAdded":1659219973503,"timeModified":1667399296254,"dbVersion":1},{"id":"c9ad6248-b2c6-4549-afbb-5fd5dafd0b44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"ST","value":"1","uom":25,"timeAdded":1659219973515,"timeModified":1667376142269,"dbVersion":1}]},{"id":"7f75a877-cbdf-4757-ac7f-51546d947f7b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","name":"Leak Sensor mechanical","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200062dc7","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219972135,"timeModified":1659219972135,"dbVersion":1,"drivers":[{"id":"4dab0393-4983-409c-9ea6-88cc7a71c67a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV0","value":"0","uom":25,"timeAdded":1659219972388,"timeModified":1667397581732,"dbVersion":1},{"id":"1a8e4797-6f40-4d5c-ad1d-3082bb283711","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV1","value":"4","uom":25,"timeAdded":1659219972402,"timeModified":1667397581857,"dbVersion":1},{"id":"f48ade65-06a3-4f51-9b2c-cd746d2cb927","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV8","value":"1","uom":25,"timeAdded":1659219972417,"timeModified":1667397581952,"dbVersion":1},{"id":"6aa5bea0-a8ea-442b-81a1-0aba21bd3845","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"ST","value":"1","uom":25,"timeAdded":1659219972430,"timeModified":1667376141908,"dbVersion":1}]},{"id":"09f24158-a0e8-4df1-8876-834ee222fbfc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","name":"Leak Sensor laundry","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200063e2d","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219971048,"timeModified":1659219971048,"dbVersion":1,"drivers":[{"id":"c0ac137c-91dd-4803-b7fb-fbefe08782a5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV0","value":"0","uom":25,"timeAdded":1659219971294,"timeModified":1667397527863,"dbVersion":1},{"id":"a0763505-4d58-4561-a881-161aa3926995","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV1","value":"4","uom":25,"timeAdded":1659219971307,"timeModified":1667397528042,"dbVersion":1},{"id":"44fab85e-1ba7-4937-83ad-825aea509aa1","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV8","value":"1","uom":25,"timeAdded":1659219971319,"timeModified":1667397528136,"dbVersion":1},{"id":"4f145713-2c94-4a40-8b6b-2b19ad489de7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"ST","value":"1","uom":25,"timeAdded":1659219971335,"timeModified":1667376141506,"dbVersion":1}]},{"id":"ff66ae77-aca3-49ea-b433-36ec9abe5cbd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","name":"YoLinkSetup","nodeDefId":"setup","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"setup","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219635531,"timeModified":1659219635531,"dbVersion":1,"drivers":[{"id":"a70e282a-e740-4523-855c-c41a01cbc884","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","driver":"ST","value":"1","uom":25,"timeAdded":1659219635789,"timeModified":1667376140104,"dbVersion":1}]}]}} 11/2/2022, 08:40:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved oauth 11/2/2022, 08:40:40 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1},{"id":"73af4323-2592-49b1-bef8-ee3b5a08e8bf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"oauth","value":"","dbVersion":1}]} 11/2/2022, 08:40:40 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:40:41 [pg3] info: startNs:: YoLink 11/2/2022, 08:40:41 [pg3] info: startNs:: YoLink is valid 11/2/2022, 08:40:41 [pg3] info: UPGRADE AVAILABLE from 0.5.21 to 0.6.1 11/2/2022, 08:40:41 [pg3] debug: Deploy YoLink in /var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:40:41 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 08:40:41 [pg3] error: YoLink automatic update failed 11/2/2022, 08:40:41 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"startNs":{"success":false,"error":"automatic update failed"}} 11/2/2022, 08:40:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:59 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:40:59 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:41:00 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/node servers/admin to broker pg3_broker 11/2/2022, 08:41:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:41:55 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667400041699,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:41:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:41:58 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:41:58 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:41:58 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667400041699,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"
No, I do not see that. I just have a dropdown to select a slot and it starts with 2. I am running PG3 3/0/63.
I have purchased the NS and am left with two choices. From the NS production store, I can install it but slot 1 is not available because that is where the YO NS is already installed. From the Polisy dashboard I can stop, start or restart but get the message Automatic Upgrade failed. The one thing I do not want to do is delete the NS and install it because in the past, that has totally broken anywhere in IoP where I reference a YO node, which is a lot of places. So, how do I get the purchased NS to upgrade the NS in slot 1?
I would think that would test everything but once we get the new code, I will test it through a router and cable modem reboot, power interruptions of the network infrastructure and the Polisy. BTW, have you found a fix to get the outdoor power strip online in IoP?
