gregkinney
  1. Thanks for your help @Brian H . Not sure if it's pure sine wave, pretty sure it is not. Everything is dual band. End result is: FilterLinc plugged into the wall, UPS plugged into FilterLinc, then I pluggeed the On/Off module into the UPS and all is working well.
  2. I have an Insteon On/Off module that I use to operate a plug-in fan while I sleep. I have a UPS that I use for power outages also plugged in to the wall in the bedroom. I want my fan to stay on if the power goes out while I sleep, so I want the On/Off module plugged in to the UPS. Is this the correct usage for a FilterLinc? If so, how do I lay it out? Is it: On/Off ---> FilterLinc ---> UPS? On/Off ---> UPS ---> FilterLinc? Or other?
  3. Sorry, that's the end of my small amount of expertise. Hopefully someone better chimes in.
  4. Did you save the variables and save the programs after you changed them?
  5. So before you added the "And $State_5 is 1" line, this program did correctly work each time that motion was sensed, correct? The only change you made was adding the line "And $State_5 is 1"? And if the answer to the above question is yes, can you confim that the current value of $State_5 is 1?
  6. Another approach would be using a variable. Add a second program: If control switch fast on and not fast off Then set variable to 1 Else set variable to 0 And then in your current motion program, you would add one line: And if variable is 1 Just make sure that if you want the motion to always be on unless you toggle it off, that you set the starting value for the variable to 1.
  7. The updated version would be a plain on/off switch 2477S: https://shop.insteon.com/products/on-off-switch. You can create the timer function in an ISY program.
  8. Why has this post made me so happy? I followed it so I could see what was happening. I feel like for this new user it's like the scene in the Wizard of Oz where Dorothy opens the door and it goes from black and white to color.
  9. I can't specifically address your 4 questions, but wanted to share my experience with Keen vents (similar to Flair). My goal was to even out the temperatures. I have an upstairs area with 4 bedrooms and a hallway. I spent maybe $1500 on Keen vents. I did not experience any significant changes - maybe 1 degree better balanced with still major temperature differences from room to room. I pulled the Keen vents and went to an electronic damper system. It was less expensive than Keen with professional install - I think around $1k. All rooms are completely even in temperature now, all of the time. www.zoningsupply.com. Before the electronic dampers, I went with manual dampers so I could manually control the amount of air going to each vent. This worked perfectly in the moment, but it just required manual adjustment from season to season so I eventually upgraded to electronic. But even the manual dampers were so much better than the vents. The vents just really didn't work. It makes sense once you look into it. When you close a vent, instead of redirecting the air, it just increases the static pressure. Before you spend $2,500, I would consider testing it by manually closing some of your vents to see what happens.
  10. Ok I'll get off my high link high horse! That's all I have to offer, hopefully @IndyMike can help you like he helped me.
  11. How many Insteon devices do you have? And how many scenes do you have? And of those scenes, how many of them are large? Such as a whole home scene?
  12. @sbooke I just went through this exact same issue. My ISY also said I had 44, or 28, or 109 links. I deleted the motion sensor and related program, deleted a very large scene to reduce the link count to see if it was too many links, then added back the motion sensor. Tried a program and all worked well.
  13. Problem solved. I deleted some large scenes and now the MS2 is working via program. So very frustrating. Wish there was a better way to figure out link count. Can't wait for the new PLM. Thank you all for the help.
  14. Ok I re-read your post. I went to re-write the program to say if dimmer is switched on, then turn on study cans. When I logged back into the admin, the dimmer was gone. So I added it again, wrote the program, and it did nothing. Guessing these two things point to link limit. Now how to reduce links...
  15. Is there any way for me to determine whether I am over link limit besides the count? I'll try again first thing tomorrow morning if not but I am losing faith in that method. I remember doing it years ago and it wasn't difficult. The numbers were not all over the place like they are now. I am using Aeotec Multisensor 7. My experience has been great. They were easy to add. I've been using them for lux for a couple years and they have performed well. In my tests for motion, so far they have been instant and accurate.
