PapaBear
Everything posted by PapaBear
  1. Thanks
  2. I successfully upgraded to eisy-ui. Now I have a few basic questions 1-How to I edit my programs 2-How do I access eisy-ui on my iphone
  3. Thanks for all the advice. I tried the technique oberkc recommended (hadn't done it that way before). It didn't work either. Also, this is a brand new MSII right out of the box. Also dleted java cache. Now when i launch IoX I get these windows:
  4. I cleared the event viewer and used auto discover as you suggested It looked like it would add the MSII Then it quickly timed out... My MSII is sitting on my desk 15" from my PLM
  5. Double checked the address. Had it correctly.
  6. I did a factory reset. I tried manually adding using both 2844-222 device types [10.16] [10.18] Still no luck. Same error message.
  7. I plugged a usb cable in for power to eliminate a bad battery. The motion sensor is a few feet from my PLM. I held the set button until i heard one beep and got a slow flash. Still got the same error message.
  8. Model 2844-222 When I try to add I get this message: Cannot add device Cannot determine insteon engine
  9. Thanks IndyMike. Your wisdom helped me get thins working right.
  10. Thanks for the sound advice. If I execute a program from my ISY will interrogate group members via a group cleanup command? Also, is there a process I can run to find bad links or device communication issues? Thanks
  11. When I activate a scene from an Insteon switch, it works perfectly. When I ask Alexa to execute only some of the actions in the scene ate executed
  12. I opened a ticket. Thanks for your help.
  13. When I ping my eisy the message returned is Destination host unreachable I an running windows 11 64 bit. I loaded Java 64 bit. Was that the right version to load?
  14. PapaBear posted a topic in IoX Support
    I logged in for the first time in months. It suggested I update. I backed up and then tried the update. It got stuck with my trying to log back in. Now when I do the launcher there is no option to select my control console. The options are blank. What should I do to recover??
  15. Per my support ticket, I used the Upgrade packages button in the config tab and all is now working fine.
  16. I tried your suggestion and it didn't work. I will open a support ticket. The backup process gets to the point where a zip folder is created. The folder is empty.
  17. When I try to back up I get this message: Could not parse the configuration file
  18. This all makes sense. Thank you all for the solution but also for the explanation. I will add wait lines.
  19. In the program below, some of the lines do not always execute. There doesn't seem to be a pattern to the failures. What have I done wrong? Sunrise - [ID 0006][Parent 0001] If Time is Sunrise Then Set 'Liv Foyer Lib Prch / Landscape lights' Fast Off Set 'Liv Foyer Lib Prch / KP Liv Rm.Porch Plugs' Off Set 'Liv Foyer Lib Prch / Powder rm bulb' Off Set 'Garage Deck / Deck Stained Glass' Off Set 'Second flr Attic / Attic Star' Fast Off Set 'Second flr Attic / Mstr bdrm lamps' Off Set 'Liv Foyer Lib Prch / SW side dr sconce' Off Else - No Actions - (To add one, press 'Action')
  20. Thanks. The wiki info worked and I have notifications running.
  21. I found the section of the cookbook and followed the directions to set up SMTP for Google. When I hit test I get this error message which is not listed in the cookbook section about gmail errors: Mail Server Error [[SMTP_ERRORS--1]]
  22. You guys are very helpful. I want to set up notifications. Can you direct me to documentation to help with this?
  23. I'm really not that bored. Trying to figure out why an insteon switch makes incandescent light flicker randomly. Figured it might be from comm traffic so I have put the PLM on my desk where I can see it. No activity on the Event Viewer at level 3.
  24. Thank you both. Got it. Next question. Why does my PLM LED blink when there is no Insteon communication traffic that I am originating? Query All - [ID 0002][Parent 0001] If Time is 4:35:00PM Then Set 'ISY' Query Else - No Actions - (To add one, press 'Action') Factory Query Program
  25. <?xml version="1.0" ?><triggers><d2d><trigger><id>4</id><name>Query All Copy</name><parent>1</parent><if><and /><schedule><at><time>41040</time></at></schedule></if><then><comment> Warning: Unrecognized Action (program may not run)&#x0A;&lt;cmd NODE=&quot;00:21:b9:02:31:79&quot; ID=&quot;QUERY&quot;/&gt; &#x0A;</comment></then><else></else><comment>Factory Query Program</comment></trigger></d2d></triggers>
