PapaBear
  • Posts
    64
Everything posted by PapaBear
  1. Per my support ticket, I used the Upgrade packages button in the config tab and all is now working fine.
  2. I tried your suggestion and it didn't work. I will open a support ticket. The backup process gets to the point where a zip folder is created. The folder is empty.
  3. When I try to back up I get this message: Could not parse the configuration file
  4. This all makes sense. Thank you all for the solution but also for the explanation. I will add wait lines.
  5. In the program below, some of the lines do not always execute. There doesn't seem to be a pattern to the failures. What have I done wrong? Sunrise - [ID 0006][Parent 0001] If Time is Sunrise Then Set 'Liv Foyer Lib Prch / Landscape lights' Fast Off Set 'Liv Foyer Lib Prch / KP Liv Rm.Porch Plugs' Off Set 'Liv Foyer Lib Prch / Powder rm bulb' Off Set 'Garage Deck / Deck Stained Glass' Off Set 'Second flr Attic / Attic Star' Fast Off Set 'Second flr Attic / Mstr bdrm lamps' Off Set 'Liv Foyer Lib Prch / SW side dr sconce' Off Else - No Actions - (To add one, press 'Action')
  6. Thanks. The wiki info worked and I have notifications running.
  7. I found the section of the cookbook and followed the directions to set up SMTP for Google. When I hit test I get this error message which is not listed in the cookbook section about gmail errors: Mail Server Error [[SMTP_ERRORS--1]]
  8. You guys are very helpful. I want to set up notifications. Can you direct me to documentation to help with this?
  9. I'm really not that bored. Trying to figure out why an insteon switch makes incandescent light flicker randomly. Figured it might be from comm traffic so I have put the PLM on my desk where I can see it. No activity on the Event Viewer at level 3.
  10. Thank you both. Got it. Next question. Why does my PLM LED blink when there is no Insteon communication traffic that I am originating? Query All - [ID 0002][Parent 0001] If Time is 4:35:00PM Then Set 'ISY' Query Else - No Actions - (To add one, press 'Action') Factory Query Program
  11. <?xml version="1.0" ?><triggers><d2d><trigger><id>4</id><name>Query All Copy</name><parent>1</parent><if><and /><schedule><at><time>41040</time></at></schedule></if><then><comment> Warning: Unrecognized Action (program may not run)&#x0A;&lt;cmd NODE=&quot;00:21:b9:02:31:79&quot; ID=&quot;QUERY&quot;/&gt; &#x0A;</comment></then><else></else><comment>Factory Query Program</comment></trigger></d2d></triggers>
  12. How do I do that?
  13. My query all program has the follow lines commented out in the "THEN" section Warning: Unrecognized Action (program may not run) <cmd NODE="00:21:b9:02:31:79" ID="QUERY"/>
  14. Thanks all. I am giving UD Mobile a try.
  15. I just installed my eisy and wonder if it makes sense to continue using Mobilinc X or switch to UD Mobile. Opinions?
  16. Maybe 10 years. How much storage capacity does the SD does it need?
  17. The default admin logon worked. Then I had to restore from a recent backup. What caused this? Do I need to upgrade to replace something?
  18. LAN and Wifi are both up and running. Help!
  19. I don't think it is the wiring or bulbs (incandescent) because the problem goes away when I put in a traditional toggle switch. Also, I have tried swapping Insteon switches and the trouble remains.
  20. See attached
  21. I tried a restore but it failed due to invalid config file
  22. A few months ago I started getting random flickers on some of my lights. Today I opened my admin console and all of my programs were gone. Is my ISY failing? What else could be the problem. Help!!
  23. Thank you Dennis. I had switched locations and was no longer using my monitor connected to my NBPC. The resolution was deleting the UDI files.
  24. I followed the instructions for clearing Java and then loading the newer launcher. It has been working although when my PC is ideal it seems to lock up and I need to END the TASK and launch again. Now, however, when I try to launch Console on LAN, I get a spinning wheel and then the launcher freezes. What am I doing wrong? How can I diagnose this problem?
  • Create New...
