Mark Sanctuary
  1. I upgraded without issues. It was smooth. The UDI phone app kept sending notifications about the progress. INSTEON working fine. I don't have any Zigbee or Z-Wave devices. Looking forward to the upcoming plugin mentioned in the release notes that will enable homekit.
  2. This release just dropped today (2/10/24). Who's installed it so far?
  3. Mark Sanctuary replied to SSS's topic in eisy
    @Michel Kohanim Looks like the code examples for matter.js have been updated. There are both old and new API examples. https://github.com/project-chip/matter.js/tree/main/packages/matter-node.js-examples/src/examples Have you made any progress tying any of it into the ISY code?
  4. Mark Sanctuary replied to SSS's topic in eisy
    @Michel Kohanim Looks like matter.js 0.9.0 (2024-05-14) is yet another big list of changes! And they introduced a new API not that long ago. So does one develop now in hopes its finally stable.?.?.? sheesh
  5. Mark Sanctuary replied to SSS's topic in eisy
    Thanks Michael! Can't build a house if the foundation is not ready. Just digging around the GitHub for Matter stuff. I think (just a guess and could be wrong) Michael and team is using matter.js implementation. Looking over the ChangeLog they have indeed done a bunch of work recently. https://github.com/project-chip/matter.js/blob/main/CHANGELOG.md https://github.com/project-chip/matter.js
  6. Mark Sanctuary replied to SSS's topic in eisy
    @Michel Kohanim, You mentioned the Matter support might require a boarder router. I think that works for many since a lot of us that use HomeKit have Apple TVs, HomePods. And if not Apple I am sure they have SmartThings or something else like it. Let us know if there is anything we can do to help support this development.
  7. Initiated update, rebooted when prompted, cleared Java cache, logged back in. Updated Polisy without issues.
  8. @Michel Kohanim mentioned Matter a bit a go. I think Matter support is coming from UDI shortly...
  9. Mark Sanctuary replied to SSS's topic in eisy
    Always good news when the UDI team has a new development "very close" to ready. Looking forward to seeing the new HomeKit support.
  10. I did the update and it finished. Rebooted when the popup said it needed a Reboot. Programs seemed to be OK without any changes.
  11. Mark Sanctuary changed their profile photo
  12. I had issues with being stuck on PG3 v3.1.23_1. After many attempts with [Upgrade Packages] and rebooting several times, I did some reading around the forums and finally realized I had not done the PG3 to PG3x upgrade. I found the Upgrade to PG3x process in the UDI Wiki. Followed the steps and after two tries, cleared Java and browser caches, etc. I finally got my Polisy updated to PG3x. One final try to upgrade to PG3x v3.2.2 with clicking the [Upgrade Packages] and rebooting it worked.
  13. Mark Sanctuary started following tazman
  14. Mark Sanctuary started following Michel Kohanim
  15. Good catch IM! Thanks Michel!
  16. Not sure if it helps but I had a while back some SwitchLinc Timer switches that went bad which made the ISY lockup until I removed and replaced them with new regular SwitchLinc switches. I did not figure this out though until I unlinking a bunch of the switches from the ISY to systematically isolate the problem.
  17. Mark Sanctuary replied to aLf's topic in ISY994
    The thing about the ISY programming is it can easily loop back on itself when you try to check something your going to change. In order for this to work without issue you will have to do it like this... If From Sunset To 10:30:00PM (same day) Then Set 'Outlet' On Set 'Lantern' On Else Set 'Outlet' Off Set 'Lantern' Off And to improve this further you can put them in a scene and then you would only need to do this... If From Sunset To 10:30:00PM (same day) Then Set 'Outlet and Lantern Scene' On Else Set 'Outlet and Lantern Scene' Off
