MJsan
  1. I've been fighting this battle for a year ... trying to get a KPL button to control a MH device through a scene. Nothing has worked - removing scenes, removing the KPL and re-adding, removing the MH device, even swapping to a new MH device. I ended up putting an Insteon on-off plug in front to turn it on and off and linked that to the scene, which did the trick. Not as elegant as it should be, but functional (especially for my other half who has chided me for a year "why doesn't it just work like it used to!" Just a note for others who are battling a similar issue :)
  2. @bpwwer thanks MUCH Bob... that makes sense... BUT ... this all used to work flawlessly. Exactly as set-up and described - I had a KPL button trigger an MH only scene. I also had "bedroom all" that triggered the mixed scene. In fact, I have a few others also working right now - "accent lights" is a scene that triggers 13 MH only devices. It stopped working a few months ago, maybe around the time 5.9.1 was rolled out?
  3. I've removed and replaced the corrupted KPLs which solved one issue... but am running into the weirdest issue now. I have a scene "master bedroom" that includes several Insteon plugs and one MH device ("Headboard"). There is a scene "Bedroom all" that has all of the Insteon devices + MH headboard. I have one button of the KPL set to control the scene. If I turn on the scene from the UD mobile app ... it works. If I try to turn on or off the scene from the assigned KPL button ... nothing. What's weird is that if I active the scene - the light for the KPL button responds, but the MH device doesn't. Even weirder ... I have a remote link with the same scene programmed to one button ... and it works. I have a scene defined with just the MH device in it + the KPL and remote link buttons as controllers. The remote link works, activating from UD mobile or the console works... but the KPL doesn't (again, the keypad light responds, but the MH device doesn't. I've deleted both of the scenes, redid them (several times)... no change. Any ideas of how to troubleshoot this further, or is this a UD bug I should have them dig into?
  4. Like I said in the 2nd post, @bpwwer is usually the smartest guy in the room. That was it Bob... delete the scene and recreate it. Since I had a few corrupted records for 2 KPLs, not surprising. I just wish there were a way to "check" all of the files on EISY to ensure that they are all OK.
  5. Interesting... when executing "ON" from UDI, the messages show it happening. When executing the scene "ON" ... I get this link not found error. Now I'm really perplexed. Tagging @bpwwer because he's the smartest guy in the room in a lot of cases
  6. Not sure if this is due to a recent update or not, but I had some corrupted KPL files in my EISY that I had to remove/replace the KPLs (fixed it). However, I have one LED strip that works in the MH app, works in Google Assistant, and seems to work in the UD app on my phone and on the console when I tell it to go ON or OFF (I'm watching it physically go on and off). The weirdness now is that it doesn't show on the UH console whether it's on or off... but does on the UDI app (see attached image). Not a major issue, but I'm trying to suss out why that's not updating but the UDI app does? More problematic: I have this light in a scene so that it can be controlled with a KPL button (and a few other "all off" scenarios), and it's not responding. It used to work relatively flawlessly - I'd have to restart the PG3 once in a while (especially after a power outage) but for 1+ year it's been good. Now the only way to turn it on or off is via the UDI app, MH app, or voice via Google Assistant (so we KNOW it's connected, working, but just not being part of the scene). Any thoughts, ideas, or suggestions? In a related issue... I have about a dozen accent lights tied to a scene. Executing the scene from EISY I usually have 2-4 that don't respond... but when executing a similar scene from Google Assistant, 100% come on (albeing VERY slowly, one by one). PG3x ver 3.3.18, IoX 5.9.1
  7. MJsan replied to MJsan's topic in eisy
    @Geddy truly words of wisdom right now things "work" sort of ... I can't modify any scenes or make changes, but husband won't threaten to kill me for now as long as things "mostly" work as expected. Fun.
  8. MJsan replied to MJsan's topic in eisy
    Sorry - that was in the support ticket It's an EISY 5.9.1
  9. MJsan posted a topic in eisy
    I opened a ticket but thought I’d seek out the collective wisdom here as well… Been running trouble free for several years now ... but cannot add a new module to a scene, and when I try to work on the system I'm getting random errors like this Tue 08/12/2025 12:23:30 PM : DB: Cannot load ./FILES/CONF/3F4715.REC Tue 08/12/2025 12:23:30 PM : [RemoteBedR - H Accent] Finish : Removing from scene 'Accent Lights' was Incomplete I identified that module as a RemoteLinc, removed it from my system, and then other errors were coming up... Tue 08/12/2025 12:26:13 PM : DB: Cannot load ./FILES/CONF/3D7AC8.REC ^-- that module is a keypadlinc and it's working fine. Others are coming up with the same cannot load error I tried doing a restore modem PLM and it runs through a bunch of MCG-LNK-RSP commands... then pops up an error message and this message is in the logs Tue 08/12/2025 12:32:29 PM : DB: Cannot load ./FILES/CONF/3D7AC8.REC Tue 08/12/2025 12:32:29 PM : [All ] Writing 0 bytes to devices PLM is operational (44.30.CE v9E / Connected) I've tried doing the full disconnect, wait 2 mins, reconnect (PLM first, wait 2 mins, then EISY). I've tried clearing Java cache too. I've deleted the 2 remotelinks that were causing issues ... but now the errors are with 2 KPLs and like I said I don't want to start willy-nilly deleting more things if that's only going to keep corrupting things (and forcing me to have to reprogram a TON of scenes). For the 3D7AC8 device, if I query it ... Tue 08/12/2025 12:54:14 PM : [Std-Direct Ack] 3D.7A.C8-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Tue 08/12/2025 12:54:14 PM : DB: Cannot load ./FILES/CONF/3D7AC8.REC Tue 08/12/2025 12:54:14 PM : DB: Cannot load ./FILES/CONF/3D7AC8.REC Tue 08/12/2025 12:54:14 PM : [INST-TX-I2CS] 02 62 3D 7A C8 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 Tue 08/12/2025 12:54:14 PM : [INST-ACK ] 02 62 3D.7A.C8 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 06 (00) Tue 08/12/2025 12:54:14 PM : [INST-SRX ] 02 50 3D.7A.C8 44.30.CE 2B 2E 00 (00) Tue 08/12/2025 12:54:14 PM : [Std-Direct Ack] 3D.7A.C8-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/12/2025 12:54:15 PM : [INST-SRX ] 02 50 3D.7A.C8 44.30.CE 23 2E 00 (00) Tue 08/12/2025 12:54:15 PM : [Std-Direct Ack] 3D.7A.C8-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Tue 08/12/2025 12:54:15 PM : [INST-ERX ] 02 51 3D 7A C8 44 30 CE 16 2E 00 01 01 00 00 20 20 1F FF 2F 0C 00 00 00 00 Tue 08/12/2025 12:54:15 PM : [Ext-Direct ] 3D.7A.C8-->ISY/PLM Group=0, Max Hops=2, Hops Left=1 So it's communicating, but still shows the cannot load error. I'm kind of stuck - I don't want to mess anything up any more than it is ... need some guidance about how to fix this. Is this indicative of my PLM going bad? It's probably 7-8 years old ? It's a model 2413S rev 2.3.4216
  10. MJsan replied to MJsan's topic in MagicHome
    Just to close this out ... after going through a bunch of gyrations and trials, the best way to "fix" this is to use the Google Home. It can activate MH scenes, so when we want those, we just speak it.. Kind of sucks that there's no way to activate MH scenes through EISY - or to directly address colors and functions but this appears to be the simplest, most reliable (albeit with a pretty significant lag - 21 lights go on over a period of about 10 seconds), and most "spouse acceptable" method I've been able to come up with. Now I've added a couple of Govee lights (thanks Amazon Pride Day) which are very cool, but the Govee poly doesn't work with them either. That's another thing Google Home was able to address - automations can directly address both MH and Govee in the same command. I *hate* not having everything addressable via a central app and having to go through multiple apps to control things (Automate for shades, MH for scenes, Govee for those lights, and Eisy for everything else) but with Google Home acting as the speech front-end, it works. I'm still fiddling with Home Assistant - it appears to be able to do everything I want to do, but it's a lot of work and time isn't something I have enough of for a while!
  11. Yup ... it works exactly as expected. Guilty of overthinking it before doing it!!!!
  12. MJsan replied to MJsan's topic in MagicHome
    @larryllix thanks for the details... I'm going to consider playing with it. What I'm really debating is going down the path of adding another rPI to my setup or trying to figure this out with HA.
  13. I've searched and searched and can't seem to find this... Currently using Google Home and thinking about moving over (back) to Amazon Alexa. I want to try it out on a new Echo Show 1st ... is there a trick to getting both Google Home and Amazon Alexa to function at the same time while I test and migrate?
  14. MJsan replied to MJsan's topic in MagicHome
    @larryllix I guess I'm missing something about how MH "scenes" are done - from what you said earlier, I think I undertstand that to mean that a "scene" executed on the MH app from my phone is just a blast of (in my case) 21 commands, i.e. "landing green 100%, hallway red 100%, cabinet yellow 100%" and so on. The way MH integrates to Google Assistant is that the "scenes" show up on Google as "automations" and when I call the automation from Google, it's REALLY slow - light...by.......light....by.........light" for all 21. It works in the end, but takes about 20 seconds for all of them to get to where they should be. MH from the app is instantaneous. Same for executing a group command from UD/EISY that includes MH nodes - they are almost instant. I tried - unsuccessfully - to read a tcpdump from my Mac using the MH app to see if I could see what network commands were going out. I'm quickly getting out of my wheelhouse ;( and couldn't interpret the gibberish. Any other ideas/thoughts on how to bring over those scenes into a NS would be **AMAZING** - and I truly thank you for putting so much effort and thought into this!
  15. @Michel Kohanimit just happened again - not opening up a ticket because I was able to "fix" ... the EISY went offline (network went down for a few mins) and when it came back up, Magichome nodes weren't responsive. Looked at the PG3 log and saw it wasn't working. Did a REDISCOVER in the PG3 window, and after a few minutes of queries.... all works. I recall that's what I did last time - so at least for the last two instances a rediscover works?
