February 18, 201312 yr Hello all, I am happy to announce the availability of our 4.0.1 Beta release! For a list of changes, please take a look at viewtopic.php?f=25&t=10770]this post[/url]. IMPORTANT If you have not already done so, please upgrade your Java to 1.7.13: viewtopic.php?f=44&t=10409 . IMPORTANT We will no longer have any firmware updates for ISY99i Series (viewtopic.php?f=44&t=10771) . Know Issues - None Things to test: - All fixes and enhancements *Please note that Safari does not support SSL session reuse and thus might take an exorbitant amount of time to communicate with ISY. As such, when using 2048 bit SSL, it's best not to use Safari. *For a discussion of variables, please look at our Program Variables forum. Instructions: 1. Please backup your ISY (File | Backup ISY). If you are backing up a 3.1.6 system, please note that the backups are corrupted. If you have a backup from prior releases, you should be OK 2. Please download the firmware for your platform - please do not unzip ISY 994i Series ISY 994i Z & ZS Series 3. Login to the Admin Console and choose Help | Manually Upgrade [the name of your system] 4. Choose the file saved in step 2 5. After the upgrade, ISY reboots. Please do ensure to clear your Java Cache 6. IMPORTANT Once upgrade is completed and ISY reboots, use any of the following methods to access your ISY's Admin Console: a. Enable Java Plugin: http://www.java.com/en/download/help/di ... rowser.xml b. http://your.isy.ip.address/admin.jnlp - Java application c. http://isy.universal-devices.com/99i/4.0.1/admin.jnlp d. Disable Java Plugin: http://www.java.com/en/download/help/di ... rowser.xml Please note that both methods above should install an icon on our desktop which should be used instead of using a browser to access ISY. Dashboard - http://isy.universal-devices.com/99i/4. ... board.jnlp 8. Please backup your system again Thanks and with kind regards, Michel
February 18, 201312 yr After installation I have a problem. I am using the method c. and the 99i Administrative Console Icon insists I choose my device in the ISY Finder ever time I start it. Same for Dashboard.
February 18, 201312 yr No. 3.3.10 is the last ISY99i firmware to be released. viewtopic.php?f=44&t=10771
February 18, 201312 yr I/O Linc Relay slider now sets Responder On Level to 0% or 100% - 4.0.1 change, works great However, regardless of whether On Level at 100% or 0% the I/O Linc Relay Status is reversed. The Relay action is physically reversed with 0% On Level. Scene Off button turns Relay On and Scene On button turns Relay Off as expected. The Relay Current State Status correctly tracks the physical state of the Relay. This is change at 4.0.1 and is working correctly. The problem now is when the Responder On Level is set to 100%, Scene On turns the Relay On as it should, however the Relay Current State Status is still reversed as though the Responder On Level was set to 0% On Level. Scene On turns Relay On correctly, Relay Status shows Off. Scene Off turns Relay Off correctly, Relay Status shows On.
February 18, 201312 yr Is there any trade in program since I have only had my ISY99i for less than a year. Actually about 6 months.
February 18, 201312 yr Oops should have read where you pointed me first! Thanks, I will contact sales for the upgrade. I have the X10 add in module installed. Will I be able to transfer that to the ISY994 ?
February 18, 201312 yr Sure. Provide sales@ with the UUID of the 99i noting that you have the optional X10/A10 module. It will then be installable on the 994.
February 18, 201312 yr I've also seen the behavior that you need to select your isy in the isy finder for it to open.
February 18, 201312 yr I've also noticed that for instance the sand theme seems to have a mix of the standard theme in it for instance the top bar has blue in it.
February 18, 201312 yr Upgraded to 4.0.1 and installed zwave module without issue. Thanks. -Xathros EDIT: What/where exactly is the IP camera support mentioned? - Found it! - On the basic web interface.
February 18, 201312 yr I also noticed that the ISY finder comes up as blue rather than desert as it did before when your theme is desert.
February 18, 201312 yr I/O Linc Relay slider now sets Responder On Level to 0% or 100% - 4.0.1 change, works great However, regardless of whether On Level at 100% or 0% the I/O Linc Relay Status is reversed. The Relay action is physically reversed with 0% On Level. Scene Off button turns Relay On and Scene On button turns Relay Off as expected. The Relay Current State Status correctly tracks the physical state of the Relay. This is change at 4.0.1 and is working correctly. The problem now is when the Responder On Level is set to 100%, Scene On turns the Relay On as it should, however the Relay Current State Status is still reversed as though the Responder On Level was set to 0% On Level. Scene On turns Relay On correctly, Relay Status shows Off. Scene Off turns Relay Off correctly, Relay Status shows On. Thanks Lee, I have been fighting my Garage Door programs for 1/2 hr now. I agree Relay current state "is" reversed. When I send an ON it reports OFF. Also, I think the 100% reporting thing still needs a little work. In the program UI all my ONs now report 100% which doesn't make sense for some devices. IO Linc status can only be ON or OFF, it's little confusing to see 100%. Motion Sensors only report ON or OFF, Low Batt also. I'm happy to see 100% for devices that can have various levels but ON / OFF only devices should display and be able to be programmed ON / OFF only. My 2c. A lot of devices that show 100% can be changed to ON in the program lines in the lower window. Some can, some can only be 100%, OFF or Responding. If a device shows it can only be set to those values, if you come back to it later it does give you the ON option. I think if you are checking status in the IF statement it's stuck to checking for 100% but in the THEN statement you can change back to ON most of the time. Examples: EZFLora showed 100% but allowed me to change it to ON Motion Sensors only allow 100%, OFF or Responding Thermostat scenes showed 100% but allowed me to change to ON.
February 18, 201312 yr Author Hello all, Thanks so very much for the feedback: 1. ISY Finder issues - Bug ID#38 2. IOLinc Status issues - Bug ID#39 3. On showing 100% - Bug ID#40 With kind regards, Michel
February 18, 201312 yr Thank you for addressing Item #3. Been fighting with this command for some time now. I have a beeper hooked up such that if the Sensor reads an ON command then my beeper will beep. Unfortunately the beeper beeps at 100% as well also beeps at 0%. I hope that by adding the option from just sensor ON, OFF or respond, that the % amount can be added thereby I belive will fix my issue if I can then state vs if ON beep to if 100% then beep. Thanks Hello all, Thanks so very much for the feedback: 1. ISY Finder issues - Bug ID#38 2. IOLinc Status issues - Bug ID#39 3. On showing 100% - Bug ID#40 With kind regards, Michel
February 18, 201312 yr Upgraded to 4.0.1 and installed zwave module without issue. Thanks. -Xathros EDIT: What/where exactly is the IP camera support mentioned? - Found it! - On the basic web interface. Xathros, could you post a screen shot or dozen? I've not bought any cameras yet, and chicken to go to 4.01 this moment. If you need, I can host the photos, just email me. Alan
February 18, 201312 yr Looks like some theme issues in 4.0.1 As soon as I added a Zwave device, the blue started to creep in. I think the finder came up blue before that. The Wiki seems to show the theme working so not sure if this is just a MAC thing. Here are some examples: I noticed the Add dialog for zwave devices has a MASSIVE font size during the add and only the bottom half of the Adding Device message was visible. No operational problems to report yet. -Xathros
February 18, 201312 yr Roman “I hope that by adding the option from just sensor ON, OFF or respond, that the % amount can be added thereby I belive will fix my issue if I can then state vs if ON beep to if 100% then beep.†Unfortunately this should have no affect on your problem. ON means the same thing as 100%. Whether it shows as ON or shows a 100% the I/O Linc can only be OFF (0%) or ON (100%). Is the I/O Linc using Trigger Reverse option?
February 18, 201312 yr First zwave related operational problem - maybe. I created a scene with a zwave appliance module as responder and a Togglinc as controller as shown below. If I turn the scene on/off from the console it works just fine. If I turn the scene on/off from the togglinc, the console shows the togglinc status change but does not tell the zwave module to turn on/off. If I run a scene test, it fails as below. Both the module and togglinc turn on for the test but the appliance module does not turn off untiol after the trest reports failed. I understand that the Insteon togglinc does not link to the zwave module but I assume ISY is supposed to pass on the message when both devices coexist in a scene. Am I misunderstanding? Do I need to use programs to track and manage the devices? -Xathros
February 18, 201312 yr Author Hello Xathros, The themes issue is fixed in 4.0.2. Would you please post Z-Wave related issues to: viewforum.php?f=93 Thanks and with kind regards, Michel
February 19, 201312 yr Anyone else having IR issues with this version? Since upgrading my system to 4.0.1 none of IR receives work anymore. The event viewer sees my remote button presses but it's never the code it should be seeing.
February 19, 201312 yr Thanks LeeG, Just noticed Trigger Reverse option is not ticked.. Will tick and hopefully solves my issue. Thought so much... Roman Roman “I hope that by adding the option from just sensor ON, OFF or respond, that the % amount can be added thereby I belive will fix my issue if I can then state vs if ON beep to if 100% then beep.†Unfortunately this should have no affect on your problem. ON means the same thing as 100%. Whether it shows as ON or shows a 100% the I/O Linc can only be OFF (0%) or ON (100%). Is the I/O Linc using Trigger Reverse option?
February 19, 201312 yr I observed in my own IO linc, that the reverse option does not survive power cycles. I opted to reverse my reed switches so as to not have a false positive.
February 19, 201312 yr LeeG, My problem actually was a silly on... I had to put a condition under the chime asking to check if sensor was ON then chime.. I had left this condition out and only had state conditions which were from the logs being triggered as true.. Adding the sensor condition must be on resolved my issue. Reverse trigger did the opposite of what I wanted done.. Thanks for your assistance, led me in the right direction.. Roman
