SSL Key Generation Error
When I attempt to generate a self signed key I receive an exception:
java.security.ProviderException: java.security.NoSuchAlgorithmException: SunTlsKeyMaterial KeyGenerator not available
Attempts to create a Cert request succeed up until the point I click OK after receiving the signing request. Then I receive a dialog box with an exclamation point, followed by: "/CONF/ISYKS.SRV"
I am running Version 3.3.10 on an ISY 994i Pro.
Any help would be greatly appreciated
Three questions:
1. Are you using Java 1.7.13?
2. Are you using the dashboard?
3. Did you accept the security warning when downloading the dashboard?
1. Java (Version 7 Update 15).
2. Yup, I followed the steps in the PDF
3. I did.
I managed to get the CA certificates and the Server certificate uploaded into the ISY using dashboard and a different local computer. They display in the dashboard via the correct buttons however when I connect to the SSL port of the ISY I am still showing the old certificate in the browser and not my new one. This persists even after a reboot.
Any suggestions?
No, I have not been able to resolve this. I also do not have a ticket open, I thought that I would try the forums first since I assumed it was just something I was probably doing wrong and I might get answers from the community rather than bother official support.
