Monitor Tempurature
Hi all,
I was wondering if there were any devices that would allow me to monitor the temperature in a room and see that temperature through Mobilink or any other app to control the ISY from my iPhone.
Would this work? http://www.smarthome.com/24950A7/I-O-Li ... Kit/p.aspx
It says it is for activating scenes or doing actions when the temperature reaches a high or low, but will it show me the temperature on my iPhone? I could just set it to not do anything on highs or lows.
Any ideas?
But how could I hook up a thermostat without thermostat hook ups?
I got the wireless addon thermostat and added it to the ISY with no issues. It is reporting the tempurature in the location it is in. However, how can I make it show its temp on the main thermostat's screen. I read there is a way, but that is without using the ISY.
Thank you again!
"I read there is a way, but that is without using the ISY."
That is the way. The ISY does not support setting many configuration options that are set through the thermostat itself.
If I leave it set up through the ISY and set it up directly through both thermostats, will everything still work properly? Only one way to find out...
