March 10, 201313 yr Newbee so any help is welcome. ISY pro 2450 relay (not sensor) set to latching "Relay1 2487S Controler 6 button. button A as a controler Try to program a simple comand If button a is set to on then turn 2450 relay on wait x# of time turn 2450 off else (nothing) When I press A it will set the relay to on but not trigger the timer or to turn it off. Controler is set to a scene with the relay as a responder What I am trying to do is that if button A is pressed turn on relay for 10 min then turn off
March 10, 201313 yr Right click Program name, select copy to clipboard, paste the actual Program in a forum post. Things like using "If Status button A is On" will terminate Wait if button is turned Off before Wait completes.
