elk connection lost
apostolakisl
I can't figure out what went wrong. It was working for sure Thursday night, then last night it doesn't work. I use a KPL to turn on the alarm when I go to bed every night so I know for sure it was connected on Thursday.
I can connect to the Elk like usual using elk rp. I can connect to the ISY like usual using the java console. The ISY is controlling light like normal. I can connect to the Elk via its java control panel going to its lan IP address.
I have power cycled the router, the xep, and the ISY.
I have tried changing the ISY's configuration settings for Elk saving, then changing back and saving.
When I first open the ISY control panel, it doesn't list anything at the top for Elk. When I try changing settings and hit save, then it shows the "not connected to elk security system" warning at the top of the screen.
I don't know what else to do.
EDIT: OK I turned off SSL and switched to the 2101 port and it connects. So now the question is what has gone wrong with SSL?
No, I haven't even opened the dashboard in a few months. The only thing I have touched on either system was the DNS. I was using my office server as the DNS which was connected to home via VPN, but I have changed my office around and went to a public DNS. But the Elk and ISY are both programmed to connect via their static IP addresses, no URL's involved.
Try using https to access the ISY web interface. I have noticed that, similar to the device status issue, sometimes the Elk arm disarm bar at the top of the screen doesn't show up. Once I use https it shows up. My ISY appears to be communicating all along regardless of what the top of the GUI shows.
  Michel Kohanim said:
Hi apostolakisl,
Did this happen after an upgrade to either ISY or ELK? Any identifiable precursors?
No, I am running 3.3.10 which I installed right when it came out. Everything was working like normal until a couple days ago. I haven't changed elk firmware in at least a year.
It's not just the bar at the top. It actually wasn't communicating. I discovered it because a KPL that is set to turn the alarm on wasn't working. Of course when I tested other stuff (like door openings turning on lights) that didn't work either.
      37.6k
      376.3k
