Bert2013 Posted May 5, 2013 Share Posted May 5, 2013 I have a setup similar to a garage door. I use an IO linc and I have a sensor. I would like to send an ON command to the relay of IO linc to open the door and an OFF command to close the door. I assume I have to set my IO linc to Momentary C. Since my sensor is ON when the door is open, I probably have to set "Trigger Reverse". However, it doesn't seem to work as expected (or I missed some configuration). When I send an ON command to my IO linc, it does the momentary thing (close the relay for 10 sec), regardless of the sensor state. When I send the OFF command, nothing happens. Any insight is very appreciated. Link to comment Share on other sites More sharing options...
Michel Kohanim Posted May 5, 2013 Share Posted May 5, 2013 Hello Bert2013, As far as the relay, I think you would want Latching (on for On, and off for Off) and not Momentary. With kind regards, Michel Link to comment Share on other sites More sharing options...
LeeG Posted May 5, 2013 Share Posted May 5, 2013 Bert2013 The I/O Linc Relay reaction based on On and Off commands and Sensor status has to do with the I/O Linc Relay being controlled with a Scene. Sending a Direct On command to the I/O Linc Relay always turns the Relay On, regardless of Momentary mode, regardless of Sensor state. All the information in the I/O Linc User Guide as far as how the I/O Linc Relay responds in the various Momentary modes applies only when the I/O Linc Relay is controlled with a Scene. In the Smarthome world the only way to control the Relay is with a Scene. Insteon devices (except PLM under control of an HA application) cannot send Direct commands. Control by Scenes is all a normal Insteon device (except PLM) can do. Define an ISY Scene, assign the I/O Linc Relay as a Responder, turn the Scene On/Off. Link to comment Share on other sites More sharing options...
