what am I seeing with this error log here
No one was up trying to access the ISY from that .50 (which I think is my xbox) what am I seeing occur here for hours and hours and hours. My error log is thousands of lines long..
70001 [Auth] 192.168.1.50:52479->80, Num=6
Thu 2013/07/25 09:07:28 PM System -10108 Check log
Thu 2013/07/25 09:22:28 PM System -170001 [Auth] 192.168.1.50:52533->80, Num=7
Thu 2013/07/25 09:22:28 PM System -10108 Check log
Thu 2013/07/25 09:22:28 PM System -170001 [Auth] 192.168.1.50:52533->80, Num=8
Thu 2013/07/25 09:37:28 PM System -170001 [Auth] 192.168.1.50:52536->80, Num=9
Thu 2013/07/25 09:37:28 PM System -10108 Check log
Thu 2013/07/25 09:37:28 PM System -170001 [Auth] 192.168.1.50:52536->80, Num=10
Thu 2013/07/25 09:52:28 PM System -170001 [Auth] 192.168.1.50:52595->80, Num=11
Thu 2013/07/25 09:52:28 PM System -10108 Check log
Thu 2013/07/25 09:52:28 PM System -170001 [Auth] 192.168.1.50:52595->80, Num=12
Thu 2013/07/25 10:07:27 PM System -170001 [Auth] 192.168.1.50:52616->80, Num=13
Thu 2013/07/25 10:07:27 PM System -10108 Check log
Thu 2013/07/25 10:07:28 PM System -170001 [Auth] 192.168.1.50:52616->80, Num=14
Thu 2013/07/25 10:07:28 PM System -10108 Check log
Thu 2013/07/25 10:16:19 PM System -5012 152
Thu 2013/07/25 11:07:28 PM System -170001 [Auth] 192.168.1.50:52788->80, Num=3
Thu 2013/07/25 11:07:28 PM System -170001 [Auth] 192.168.1.50:52788->80, Num=4
Thu 2013/07/25 11:22:29 PM System -170001 [Auth] 192.168.1.50:52841->80, Num=5
Thu 2013/07/25 11:22:29 PM System -170001 [Auth] 192.168.1.50:52841->80, Num=6
Thu 2013/07/25 11:22:29 PM System -10108 Check log
Thu 2013/07/25 11:37:28 PM System -170001 [Auth] 192.168.1.50:52845->80, Num=7
Thu 2013/07/25 11:37:28 PM System -10108 Check log
Thu 2013/07/25 11:37:28 PM System -170001 [Auth] 192.168.1.50:52845->80, Num=8
Thu 2013/07/25 11:52:28 PM System -170001 [Auth] 192.168.1.50:52988->80, Num=9
Thu 2013/07/25 11:52:28 PM System -10108 Check log
Thu 2013/07/25 11:52:28 PM System -170001 [Auth] 192.168.1.50:52988->80, Num=10
Fri 2013/07/26 12:07:28 AM System -170001 [Auth] 192.168.1.50:52993->80, Num=11
Fri 2013/07/26 12:07:28 AM System -10108 Check log
Fri 2013/07/26 12:07:28 AM System -170001 [Auth] 192.168.1.50:52993->80, Num=12
Fri 2013/07/26 12:22:28 AM System -170001 [Auth] 192.168.1.50:53040->80, Num=13
Fri 2013/07/26 12:22:28 AM System -10108 Check log
Fri 2013/07/26 12:22:28 AM System -170001 [Auth] 192.168.1.50:53040->80, Num=14
Fri 2013/07/26 12:37:29 AM System -170001 [Auth] 192.168.1.50:53047->80, Num=15
Fri 2013/07/26 12:37:29 AM System -10108 Check log
Fri 2013/07/26 12:37:29 AM System -170001 [Auth] 192.168.1.50:53047->80, Num=16
Fri 2013/07/26 12:52:28 AM System -170001 [Auth] 192.168.1.50:53082->80, Num=17
Fri 2013/07/26 12:52:28 AM System -10108 Check log
Fri 2013/07/26 12:52:28 AM System -170001 [Auth] 192.168.1.50:53082->80, Num=18
Fri 2013/07/26 01:07:29 AM System -170001 [Auth] 192.168.1.50:53089->80, Num=19
Fri 2013/07/26 01:07:29 AM System -10108 Check log
Fri 2013/07/26 01:07:29 AM System -170001 [Auth] 192.168.1.50:53089->80, Num=20
Fri 2013/07/26 01:22:29 AM System -170001 [Auth] 192.168.1.50:53125->80, Num=21
Fri 2013/07/26 01:22:29 AM System -10108 Check log
Fri 2013/07/26 01:22:29 AM System -170001 [Auth] 192.168.1.50:53125->80, Num=22
Fri 2013/07/26 01:37:28 AM System -170001 [Auth] 192.168.1.50:53131->80, Num=23
Fri 2013/07/26 01:37:28 AM System -10108 Check log
Fri 2013/07/26 01:37:28 AM System -170001 [Auth] 192.168.1.50:53131->80, Num=24
Fri 2013/07/26 01:52:30 AM System -170001 [Auth] 192.168.1.50:53164->80, Num=25
Fri 2013/07/26 01:52:30 AM System -10108 Check log
Fri 2013/07/26 01:52:30 AM System -170001 [Auth] 192.168.1.50:53164->80, Num=26
Fri 2013/07/26 02:07:29 AM System -170001 [Auth] 192.168.1.50:53167->80, Num=27
Fri 2013/07/26 02:07:29 AM System -10108 Check log
Fri 2013/07/26 02:07:29 AM System -170001 [Auth] 192.168.1.50:53167->80, Num=28
Fri 2013/07/26 02:22:28 AM System -170001 [Auth] 192.168.1.50:53204->80, Num=29
Fri 2013/07/26 02:22:28 AM System -10108 Check log
Fri 2013/07/26 02:22:28 AM System -170001 [Auth] 192.168.1.50:53204->80, Num=30
Fri 2013/07/26 02:37:29 AM System -170001 [Auth] 192.168.1.50:53207->80, Num=31
Fri 2013/07/26 02:37:29 AM System -10108 Check log
Fri 2013/07/26 02:37:29 AM System -170001 [Auth] 192.168.1.50:53207->80, Num=32
Fri 2013/07/26 02:52:29 AM System -170001 [Auth] 192.168.1.50:53251->80, Num=33
Fri 2013/07/26 02:52:29 AM System -10108 Check log
Fri 2013/07/26 02:52:29 AM System -170001 [Auth] 192.168.1.50:53251->80, Num=34
Fri 2013/07/26 03:07:30 AM System -170001 [Auth] 192.168.1.50:53256->80, Num=35
Fri 2013/07/26 03:07:30 AM System -10108 Check log
Fri 2013/07/26 03:07:30 AM System -170001 [Auth] 192.168.1.50:53256->80, Num=36
Fri 2013/07/26 03:22:29 AM System -170001 [Auth] 192.168.1.50:53262->80, Num=37
Fri 2013/07/26 03:22:29 AM System -10108 Check log
Fri 2013/07/26 03:22:29 AM System -170001 [Auth] 192.168.1.50:53262->80, Num=38
Fri 2013/07/26 03:37:29 AM System -170001 [Auth] 192.168.1.50:53315->80, Num=39
Fri 2013/07/26 03:37:29 AM System -10108 Check log
Fri 2013/07/26 03:37:29 AM System -170001 [Auth] 192.168.1.50:53315->80, Num=40
Fri 2013/07/26 03:52:29 AM System -170001 [Auth] 192.168.1.50:53319->80, Num=41
Fri 2013/07/26 03:52:29 AM System -10108 Check log
Fri 2013/07/26 03:52:29 AM System -170001 [Auth] 192.168.1.50:53319->80, Num=42
Fri 2013/07/26 04:07:30 AM System -170001 [Auth] 192.168.1.50:53569->80, Num=43
Fri 2013/07/26 04:07:30 AM System -10108 Check log
Fri 2013/07/26 04:07:30 AM System -170001 [Auth] 192.168.1.50:53569->80, Num=44
Fri 2013/07/26 04:22:30 AM System -170001 [Auth] 192.168.1.50:53574->80, Num=45
Fri 2013/07/26 04:22:30 AM System -10108 Check log
Fri 2013/07/26 04:22:30 AM System -170001 [Auth] 192.168.1.50:53574->80, Num=46
Fri 2013/07/26 04:37:30 AM System -170001 [Auth] 192.168.1.50:53631->80, Num=47
Fri 2013/07/26 04:37:30 AM System -10108 Check log
Fri 2013/07/26 04:37:30 AM System -170001 [Auth] 192.168.1.50:53631->80, Num=48
Fri 2013/07/26 04:52:30 AM System -170001 [Auth] 192.168.1.50:53636->80, Num=49
Fri 2013/07/26 04:52:30 AM System -10108 Check log
Fri 2013/07/26 04:52:30 AM System -170001 [Auth] 192.168.1.50:53636->80, Num=50
Fri 2013/07/26 05:07:30 AM System -170001 [Auth] 192.168.1.50:53682->80, Num=51
Fri 2013/07/26 05:07:30 AM System -10108 Check log
Fri 2013/07/26 05:07:30 AM System -170001 [Auth] 192.168.1.50:53682->80, Num=52
Fri 2013/07/26 05:22:29 AM System -170001 [Auth] 192.168.1.50:53689->80, Num=53
Fri 2013/07/26 05:22:29 AM System -10108 Check log
Fri 2013/07/26 05:22:29 AM System -170001 [Auth] 192.168.1.50:53689->80, Num=54
Fri 2013/07/26 05:37:29 AM System -170001 [Auth] 192.168.1.50:53729->80, Num=55
Fri 2013/07/26 05:37:29 AM System -10108 Check log
Fri 2013/07/26 05:37:29 AM System -170001 [Auth] 192.168.1.50:53729->80, Num=56
Fri 2013/07/26 05:52:30 AM System -170001 [Auth] 192.168.1.50:53732->80, Num=57
Fri 2013/07/26 05:52:30 AM System -10108 Check log
Fri 2013/07/26 05:52:30 AM System -170001 [Auth] 192.168.1.50:53732->80, Num=58
Fri 2013/07/26 06:07:30 AM System -170001 [Auth] 192.168.1.50:53771->80, Num=59
Fri 2013/07/26 06:07:30 AM System -10108 Check log
Fri 2013/07/26 06:07:30 AM System -170001 [Auth] 192.168.1.50:53771->80, Num=60
Fri 2013/07/26 06:22:30 AM System -170001 [Auth] 192.168.1.50:53795->80, Num=61
Fri 2013/07/26 06:22:30 AM System -10108 Check log
Fri 2013/07/26 06:22:30 AM System -170001 [Auth] 192.168.1.50:53795->80, Num=62
Fri 2013/07/26 06:52:30 AM System -170001 [Auth] 192.168.1.50:53880->80, Num=63
Fri 2013/07/26 06:52:30 AM System -10108 Check log
Fri 2013/07/26 06:52:30 AM System -170001 [Auth] 192.168.1.50:53880->80, Num=64
Fri 2013/07/26 07:02:24 AM System -5012 153
Fri 2013/07/26 07:03:22 AM System -170001 [uDSockets] RSub:31 error:6
Fri 2013/07/26 07:03:27 AM System -170001 [uDSockets] RSub:31 error:6
Fri 2013/07/26 07:03:32 AM System -5012 154
Fri 2013/07/26 07:10:36 AM System -170001 [HTTP] 192.168.1.6:59542->80
Fri 2013/07/26 07:10:36 AM System -170001 [HTTP] 192.168.1.6:59543->80
Fri 2013/07/26 07:10:36 AM System -170001 [HTTP] 192.168.1.6:59544->80
Fri 2013/07/26 07:10:36 AM System -170001 [HTTP] 192.168.1.6:59545->80
Fri 2013/07/26 07:10:48 AM System -170001 [HTTP] 192.168.1.6:59546->80
Fri 2013/07/26 07:10:48 AM System -170001 [HTTP] 192.168.1.6:59547->80
Fri 2013/07/26 07:10:48 AM System -170001 [HTTP] 192.168.1.6:59548->80
Fri 2013/07/26 07:10:48 AM System -170001 [HTTP] 192.168.1.6:59549->80
Fri 2013/07/26 07:11:10 AM System -170001 [HTTP] 192.168.1.6:59555->80
Fri 2013/07/26 07:11:10 AM System -170001 [HTTP] 192.168.1.6:59558->80
http://192.168.1.100>DON
I forgot the check the xbox while I had it on, suppose it's trying some UPNP related stuff to discover it as a media device or something like that?
