Turning LED on for 8-Button Keypad-Garage Door - HELP Needed
Hi,
I am fairly new with the Insteon set of products. I recently setup the ISY994i and a couple of dimmer switches and a motion sensor. I have now moved on the the I/O Linc Garage Door control.
What I want to do seems simple, but I can't figure out how to program and/or create a scene to do it.... :(
I currently have a simple program as follows
If Control 'Button C-GarageDoor' is switched ON
Then Set 'Garage Door Swc' On
So if I press the C button on the 8 pad switch the garage door opens or closes.
What I want to do is have the LED for Button 'C' always reflect the status of the garage door regardless if I physically press the C button or if I use the hardwire button in the garage or the garage door remote in a car.
So somehow I want to have a program and/or scene that indicates if the 'Garage Door Sensor' is OFF then turn on the LED for Button C so the button is lite anytime the garage door is open. I can't seem to figure out how to do this.
Please Help....
John
Define an ISY Scene ‘keypadlinc button C’ (arbitrary Scene name) with KeypadLinc button C as Responder.
If Control ‘iolinc – Sensor’ is switched On
Or Control ‘iolinc – Sensor' is not switched Off
Set Scene ‘keypadlinc button C’ Off
Set Scene ‘keypadlinc button C’ On
The above ISY Program turns KeypadLinc button C LED Off when the I/O Linc Sensor turns On and turns KeypadLinc button C LED On when the I/O Linc Sensor turns Off
