How to monitor for low battery on Motion Detector
Hi guys,
I am new here and would like some help in programming my new ISY994I. First off, let's discuss how to monitor for a low battery on a motion detector, as I could not find where these options were discussed related to a motion detector.
I created a table of the programming options (as an image), but did not see how to place it here in this post. Please see it here on my blog
[/url]http://insteonhome.blogspot.ca/[/url]
Essentially there are six possible choices to get the ISY to send out an alert email if the "battery low" condition sends a message to the ISY.
Of the possible choices, what is the best one, or should one monitor for multiple options? Maybe some of the answers depend on the option settings in the 2842-222 ?
Your help is appreciated.
Seems to me there are six possibilities, or 12 if we substitute "Status" for "Control"
Any insight as to the most robust program --i.e. you want to make sure a low battery is replaced.
Regards,
Donald
Status 'Garage Motion-Low Bat' is On
Send Notification to 'Don at Rogers' content 'Condition IS ON'
Status 'Florida Room Sensor-Low Bat' is not Off
Send Notification to 'Don at Rogers' content 'Condition IS OFF'
Status 'Florida Room Sensor-Low Bat' is not On
Send Notification to 'Don at Rogers' content 'Condition IS NOT ON'
Status 'Florida Room Sensor-Low Bat' is not Responding
Send Notification to 'Don at Rogers' content 'Condition IS NOT RESPONDING'
Regards,
Donald
LeeG has given you the most appropriate response - I agree with it.
The motion sensor is a controller - the "control condition" is the most appropriate. I the ISY does not detect a control ON activity, it cannot (by definition) detect a status activity.
Beyond that, the motion sensor is a two state device:
1) "Is on" = "Is not off"
2) "Is off" = "Is not on"
3) I don't think that "Is not responding" makes sense for a motion detector since it is a controller. The ISY only provides a response after it has already received a transmission from the motion sensor.
Bottom line - use the example that Lee provided.
Do not forget to provide both a subject and body in your email notification.
