Can a keypad button trigger a scene at 15%?
Hi,
I am looking to make a scene so that the keypad buttons will dim my sons room to various percentages. I am also looking for a keypad to make the hallway light scene 15%.
Can I do that or does it require a program vs a scene?
Rich
For another button in my bedroom, I have this program because I couldnt figure out the scene part:
       Control 'Main: Master Bedroom A' is switched Off
   And From    10:00:00PM
       To       6:35:00AM (next day)
       Set Scene 'All Off' Off
       Wait  15 seconds
       Set 'Main: Upstairs Hall Keypad' 10%
       Set 'Main: Upstairs Hall - bottom ' 10%
       Set 'Main: Upstairs Hall - by Bath' 10%
       Set 'Main: Upstairs Hall - by Kids' 10%
       Set 'Main: Upstairs Hallway' 10%
It can be done with a Scene. Define the ISY Scene with the KeypadLinc button as Controller and whatever devices should be responders. Click on the Red KeypadLinc button node name below the Scene name and set the various Responder On Levels to the desired values.
Lee,
Are you saying after the scene is made, I can go in to change the on levels & that would only be for the scene?
Rich
OK, now i got it, thats great.
A question is, if I am going to take 4 bedrooms that have keypads & do the following:
A - that rooms fan
B - That rooms light at 75%
C - That rooms light at 50%
D - That rooms light at 25%
Am I better off using 1 program, or am I better off make 4 scenes?
With four rooms, it would be 4 programs, or 16 scenes.
