Logging events to a file
For a variety of reasons I'd like to create kind of a log file that I can write to through ISY programs. I can (and have) set up programs so the triggers I want send an email notification with all the right event details and variables to an email address I set up. So I have the conditions and tests and all that working.
The emailing part is a workaround though. What I really want is to log the contents of those emails into a file, which would look something like [mm/dd/yy hh:mm:ss] Event xyz occurred, etc. I'd settle for having it logged into the main ISY event log, although ideally I'd like it to be some other file.
Is there a way to do this entirely within the ISY? Would there be some way to do this with the Network module if I had some logger listening on some port on my internal network? I have other systems that are always on (or close enough).
You can do this using the built in notification system. There is a method to create and write to files on the ISY's webserver. See this link:
http://wiki.universal-devices.com/index ... tification
I do this using the network module to write to a log file on an external syslog server running on a RaspberryPi. I would have gone with the method above if it had been implemented sooner. The RPi method allows me greater flexibility since that is a full linux based system.
-Xathros
