help with scenes
new to the system.
#1 on the control panel I see the set of exclamation points and cant figure out how to get the system to recognize the device. See file 1.
#2 I have created a scene and it works from the adminstrative console. I would now like to program it to one of the switches in the room. How do I set one of the key link buttons to turn it on and turn it off? see file 2
These little red exclamation points generally indicate an inability to communicate with, or write updates to, a given device. What happens if you right-click, and select "write updates" (or something like that)? Do you have access points installed on opposite legs of your electrical system?
First, make sure that the device you wish to use to control the scene (a keypad button, in this case) is defined as "controller" (as opposed to, simply, "responder") of that scene. Once a controller, select that scene device from you admin console and make sure that the ON levels (level to which scene devices go to in response to this controller) are where you want them. These responder levels can, by design, be different than the levels at the scene level, and can also be zero (turn off in response to an ON command).
