Flickering 8 button dimmer switch
I have a 8 button dimmer switch running 6 LED lights on my patio. When I dimmed them to about 50% they worked fine, but every few minutes they would flicker and go to full bright or off for a second. All the lights did this so it was not a bad bulb. Any ideas? do I need to return this switch?
The only time that I have experienced behaviour anything like you describe I attributed to one of those fancy lutron or levitron switches. Since taking them out, the behaviour is gone.
Right now, I have a cooper light switch which inludes a nightlight and motion sensor. I continue to find this light off at night and on the next morning. I wonder if one of my insteon programs (perhaps the 3am query) is somehow triggering this.
The point I raise is to consider the possibility that some non-insteon system may be triggering some funny behaviour. Do you have any other systems that communicate via powerline?
no, everything is insteon. I dont normally mess with the dimmer, but there were a bunch of us sitting outside and it was too bright. Normal full on operation seems to work fine. I tried 2 different dimming setting, roughly 20% and 80% and had issues at both points. In a 5 minute period it would flicker 1-2 times.
I too had these issues.
viewtopic.php?f=28&t=12273
I'm by no means a pro at this stuff but I found that I need a bigger power draw.
Yars ago I put a lamplinc on my led Christmas lights. They wouldn't shut off completely.
I read somewhere in the forum to put more of a demand on the device (lamplinc in this instance)
So I plugged in a phone charger as well. Worked great.
I had the same issues and more with my LED lights. (The link above) I couldn't find a solution so I switched bulbs. The LEDs are now in non insteon switches in the barns and in ther places until the issue gets sorted out.
I've tried many brands. (I'm a little gunshy to go buy more for experimentation but I haven't purchased Cree brand yet)
Sorry for the odd phrasing (bigger power draw, more of a demand on the device).
I'm trying to not say the device needs a bigger load for obvious reasons.
I would love to use all LEDs but they don't dim well yet with our insteon stuff.
With a regular dimmer from Home Depot yes but if you set your device at 30% it's okay, at 29% it flickers. (Just an example I had an issue with)
Drew
I dont think that's it, but it could be. I have at least 30 of these same LED bulbs.
http://www.amazon.com/gp/product/B00CP7 ... UTF8&psc=1
The switch with issues has 5 or 6 of them on it. I have other insteon dimmers with single bulbs and double bulbs and there are no issues dimming these, except that they turn off if I go below 15%.
I found the Philips bulbs to dim well without flickering but they did cut out at about 15%.
That drove me a little crazy.
1) I like the smooth ramp rate to be constant.
2) I have a lab that's afraid of lightning, camera flashes, etc…
(insert personal argh!)
I noticed the FEIT bulbs would fade smoothly from 100 - 0 but they had the issue that I mentioned before.
(if I had just those bulbs in the fixture they wouldnt really fade well at all, yes they're dimmable)
They would almost wait until 40% it seemed and then pop on, flicker inconsistently, etc…
Given the issues I had and the lack of resolution, I chalked it up to the fact that LED bulbs are still new
and they have a bit of refining to do.
Its a give up but it was either that or endlessly slam my face into the desk.
(It's not that pretty to begin with so I can't lose any ground in that department.)
Drew
