Insteon and Sonos with ISY-994i
jonathanud
All of what I assembled here came from other forum posts and the posted sonos.zip network resources.
It took me a while to get it all together, but I was very pleased with the results.
The ISY is one of the best appliances I have ever owned. I purchased it exclusively to drive my lighting, which it does masterfully: timers and adjustments matched to sunset, sunrise, and my routine. I love what it does, but I never expected it to bridge additional systems as it is now doing with Sonos. Had I known I could do this, I would have invested in Sonos sooner.
Thanks to you forum contributors for teaching me how to leverage it, and thank you, UD Sales for giving me a discount on the Network Module in exchange for my contribution to the community. That kind of partnership is really nice to see.
Objective: Living room Insteon controls for Sonos
Play/Pause button
Volume Up/Down button
Previous track button
Next track button
Equipment
ISY-994i with Network Module
Insteon 2486D 6 Button Control
Sonos ZP100
Variable
sonos_lr_play - Sonos doesn't have a play/pause toggle function, so we cheat with a variable.
Buttons
PLAY/PAUSE - toggle on only
VOLUME - toggle on/off to use fade up and fade down controls
PREVIOUS - toggle on only
NEXT - toggle on only
PLAY/PAUSE can also be used as toggle on/off, and the indicator light while match whether music is playing. As long as you use no other Sonos controls (ios app, computer, etc.), this works, but the indicator cannot be guaranteed to match the play mode when other controls are used. I opted just to have a permantently lit toggle and let my ears determine the status.
PROGRAMS
Sonos LR Next
If Control NEXT is switched On
Then Resource 'sonos.lr.next'
Sonos LR Pause
button1 and button2 pause the music as part of other scenes; PLAY/PAUSE is the in-room toggle button
If Control button1 is switched On
Or Control button2 is switched On
Or (Control PLAY/PAUSE is switched On
 And $sonos_lr_play = 1)
Resource 'sonos.lr.pause'
$sonos_lr_play = 0
Sonos LR Play
If Control PLAY/PAUSE is switched On
And $sonos_lr_play = 0
Resource 'sonos.lr.play'
$sonos_lr_play = 1
Sonos LR Previous
If Control PREVIOUS is switched On
Resource 'sonos.lr.previous'
Sonos LR VolumeDown
Button is held, volDown repeats until button is released.
If Control VOLUME is switched Fade Down
And Control VOLUME is not switched Fade Stop
Repeat 25 times
 Resource 'sonos.lr.volDown'
Sonos LR VolumeUp
Button is held again, volUp repeats until button is released.
If Control VOLUME is switched Fade Up
Repeat 25 times
 Resource 'sonos.lr.volUp'
NETWORK RESOURCES
sonos.lr.next
POST /MediaRenderer/AVTransport/Control HTTP/1.1
Host: 192.168.3.134:1400
Connection: Close
Content-Type: text/xml; charset="utf-8"
Content-Length: 265
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Next"
0
sonos.lr.pause
Connection: Close
Content-Length: 267
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Pause"
0
sonos.lr.play
Connection: Close
Content-Length: 285
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Play"
0
1
sonos.lr.previous
Connection: Close
Content-Length: 273
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Previous"
0
sonos.lr.volumeDown
I played with the adjustments a bit to find a good speed, found that I preferred the volume decrease a little quicker than increase. Volume must change sufficiently before the Insteon button enters pairing mode.
POST /MediaRenderer/RenderingControl/Control HTTP/1.1
Connection: Close
Content-Length: 356
SOAPACTION: "urn:schemas-upnp-org:service:RenderingControl:1#SetRelativeVolume"
0
Master
-7
sonos.lr.volumeUp
Connection: Close
Content-Length: 355
0
Master
6
isy994i network resources sonos.zip
  • Like 3
  • Thanks 1
Thanks so much for the post and resources, it was a snap to set up.
My wife loves going to sleep (well sleep in general) to the sound of thunder and lightening. Additionally she likes to read in bed, my loss. Her overhead bed reading can/spotlight is controlled next to her bed via switch linc. When she uses a double fast off, first all the lights in the house are turned off, then her reading spot dims to off and Sonos now loads up her thunder and lightening ambient sounds for sleeping.
When I described it to her initially she thought I needed to "get a life". When she used it the first time, BIG SMILE...
Again, I appreciate all the hard work and ground that has been plowed prior to me joining the forum.
Regards
ACD
  • 3 weeks later...
I too would like to thank dstanley, jonathanud, and everyone for the great work on this.
As a non-programmer I want to add a few simple steps for those that do not understand how to use the network resources module to make this Sonos integration a snap.
1- find the IP address of any Sonos zone player.
2- download either or both of the two zip files
3- import one or both zip files into the network resource manager
START SIMPLE
4- open the URL of the imported resource sonos.lr.pause or bedroom.pause
5- change the host IP address
6- save the change
7- press save at the bottom of the network resource screen
8- open ISY programs
9- create a sonos.pause program with Then resource sonos.lr.pause or bedroom.pause
10- save the program
11- open the Sonos app on any device and play any selection
12- select the ISY sonos.pause program
13- run then (right mouse click)
14- observe that you paused the player
NOW EXPAND
15- change and save the IP address of other resource URL's
16- re-read the discussion notes from the authors and tailor to your needs
17- create more resources and programs with if statements to fit your application
  • Like 3
  • Thanks 1
Zip file is empty when I download......is there another link I'm missing something? Another link? Just came across this and would love to integrate my outdoor sonos speakers.
Hi leith,
Zip file is NOT empty. If you are using Windows' decompression utility, it will have a hard time opening the file. If you really need to see what's in there, try another zip utility such as AllZip.
Michel et al...
The ZIP file isn't empty, but it is slightly corrupted. Using both WinZIP and WinRAR to open it after download, produces these errors:
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/RES.CFG".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/1.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/2.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/3.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/6.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/7.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/8.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/9.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/16.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/17.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/4.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/5.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/10.RES".
Warning: the Zip file is read-only. A file name in the archive is invalid and had to be fixed: "/CONF/NET/11.RES".
Continuing past that does allow the ZIP file to open, and the files within it to be opened, which do look ok. (I opened one with Notepad++ and it appeared to be fine.)
Just an FYI.
Oh, I wasn't suggesting that it couldn't be, only that downloading and opening it with WinZIP or WinRAR produced the error I noted.
Once opened, and that error ignored, the files seemed fine.
Thanks to all that contributed to this.
I love my Sonos setup and this makes it and the ISY a bit more useful. I don't actually want to control my Sonos via ISY per se but rather just pause the music when leaving rooms and/or all systems when Away scene is activated leaving the house. This one feature alone was enough to get me to purchase the Network Module today.
  • 4 months later...
Is there a way to have the ISY switch the Sonos to line-in and then back to the original source to begin playing music again? Ow about group all the speakers together?
I am trying to setup Sonos on my ISY. I want to create a program that starts up and plays a pandora channel. Another that cuts sonos off.  I read another thread and got some items working, but looking for some guidance/support. Anyone willing to help?
Hi jam583,
Have you looked at: http://wiki.universal-devices.com/index.php?title=ISY-99i_Series_INSTEON:Networking:Network_Resources#Sonos_by_jonathanud .... you can simply import the network resources and then just change the ip/port.
Yes, but I can't find any documentation on how to import. When I attempt, via the ISY, network resources, import, it says, "cannot retrieve file"
Play/Pause button
Next track button
Equipment
Sonos ZP100
Variable
Buttons
PROGRAMS
Sonos LR Next
Sonos LR Pause
 $sonos_lr_play = 0
Sonos LR Play
 $sonos_lr_play = 1
Sonos LR Previous
Sonos LR VolumeDown
 Repeat 25 times
Sonos LR VolumeUp
 Repeat 25 times
NETWORK RESOURCES
sonos.lr.next
Connection: Close
Content-Length: 265
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
	<s:Body>
		<u:Next xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
			<InstanceID>0</InstanceID>
		</u:Next>
	</s:Body>
</s:Envelope>
sonos.lr.pause
Connection: Close
Content-Length: 267
	<s:Body>
		<u:Pause xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
		</u:Pause>
	</s:Body>
</s:Envelope>
sonos.lr.play
Connection: Close
Content-Length: 285
	<s:Body>
		<u:Play xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
			<Speed>1</Speed>
		</u:Play>
	</s:Body>
</s:Envelope>
sonos.lr.previous
Connection: Close
Content-Length: 273
	<s:Body>
		<u:Previous xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
		</u:Previous>
	</s:Body>
</s:Envelope>
sonos.lr.volumeDown
Connection: Close
Content-Length: 356
	<s:Body>
		<u:SetRelativeVolume xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1">
			<Channel>Master</Channel>
			<Adjustment>-7</Adjustment>
		</u:SetRelativeVolume>
	</s:Body>
</s:Envelope>
sonos.lr.volumeUp
Connection: Close
Content-Length: 355
	<s:Body>
			<Adjustment>6</Adjustment>
	</s:Body>
</s:Envelope>
attachicon.gifisy994i network resources sonos.zip
Jonathanud: thank you very much for doing this. It is a very nice solution.
Quick question: how difficult is it do those button labels? Did you print your own, or buy them? If printing, where did you get the transparent buttons? Best, James
START SIMPLE
6- save the change 7- press save at the bottom of the network resource screen 8- open ISY programs
NOW EXPAND
Question: are you using static IP addresses for your Sonos devices, or is there a program to figure out each IP address?
If you launch the SONOS Controller program on your PC and go to HELP - ABOUT MY SONOS SYSTEM - you will get a listing of all your equipment with it's MAC addresses and ip addresses.
This is the easiest way to get the info you need!
Dwight
Dwight
dstanley, thanks much for your reply. I did get that far, and I've got the program working. I used a togglelinc dimmer. Love it: pause and play, and volume up and down, all in one little switch. My question was what happens when you the DHCP router assigns new IP addresses to the Sonos players? Then the code would no longer work. I figured out that I need to reserve the IP address for each player (using the MAC address) in the router administration tool. Is that they way you're doing it?
When a device hooks up to a DHCP server (router) it will request an address that it is already using or it will ask to have an address assigned. Most modern routers will remember the MAC address of a device and IP address that it requested or is granted. The Sonos will always ask for the same address over again for each device when needed. I have not had an address change in years.
That said, there are some routers that will assign different addresses - in that case then a router reserved address is best to use.
  • 3 months later...
Hi
Thanks for doing this! I have read this thread, but not yet tried to install.
Would you tell me if this can be used to select "favorites"?
Will it also do other Sonos controls not mentioned above?
If so, I assume one substitutes another sonos command in the script you provided.  Is that conceptually correct?
THanks
  • 10 months later...
I've imported these (which worked fine, so thank you) but they don't seem to be working. I've adjusted the IP on the pause to the IP of my playbar.
In my error log I'm seeing this:
Fri 2015/11/06 01:54:01 PM System -140008 Net Module Rule: 8:500
Fri 2015/11/06 01:54:58 PM System -140008 Net Module Rule: 8:500
Fri 2015/11/06 01:55:34 PM System -140008 Net Module Rule: 8:500
Fri 2015/11/06 01:59:14 PM System -140008 Net Module Rule: 8:500
any ideas?
