Scene Instantly Controlled by a Motion Sensor & Switches
I have a few rooms where I wanted a motion sensor to trigger lights but without the 1+ second delay that having only a program control them introduces. And I wanted the dimmer switches to behave nearly normal. Basically there are four states I wanted for the lights.
- Have the motion sensor not turn the lights on (set by off click or when it becomes not dark out)
- Have the motion sensor turn the lights to dim and turn off after x minutes (set by fast off (reset) or when it becomes dark out)
- Have the lights dim and not turn off (set by On click (when lights bright) or fade)
- Have the lights bright and not turn off (set by On click (when lights dim))
Although, some people seem to dislike them I have 11 motion sensors and have been pretty happy with them. I've had a few variants of programs that do similar things described above but I think my current set works pretty good and might help someone else out. Once one room is setup it's fairly easy to copy and adjust for another room.
The only thing I don't like about the setup is the lights could flash to the previous brightness setting when changing the brightness setting for a couple seconds. This is because the programs take a few seconds to update the scene and the motion sensor could trigger the lights with an old setting. If anyone has suggestions I'd love to hear them!
So, the programs below are for 2 lights controlled by one motion sensor set to only trigger on commands (jumper 5 set on the motion sensor and the option set in the ISY for only on commands). I also use one variable to keep track of what the brightness is supposed to be as this is more reliable than checking the light itself as it could be changing from one brightness to another. I also, use a state variable for all my light schedules to indicate when it's dark which is more robust than a schedule.
Living Room Off Timer
Control 'Main Floor / Living Room / Living Room Motion-Sensor' is switched On
Wait 180 seconds
Set Scene 'Main Floor / Living Room / Living Room' Off
This program will run everytime motion is detected and wait 3 minutes to shut lights off. Unless one of the other programs disabled it because lights were manually adjusted.
Living Room Set Motion Bright
$iLivingRoomLightLevel is 1
And (
Control 'Main Floor / Living Room / Living Room Hall Light' is switched On
Or Control 'Main Floor / Living Room / Living Room Lights' is switched On
Stop program 'Living Room Set Motion Dim'
Stop program 'Living Room Set Motion Off'
$iLivingRoomLightLevel = 2
In Scene 'Main Floor / Living Room / Living Room Motion-Sensor' Set 'Main Floor / Living Room / Living Room Lights' 100% (On Level)
In Scene 'Main Floor / Living Room / Living Room Motion-Sensor' Set 'Main Floor / Living Room / Living Room Hall Light' 100% (On Level)
Run Program 'Living Room Set On Dim' (Then Path)
Disable Program 'Living Room Off Timer'
Wait 1 second
Wait 1 second
Wait 2 seconds
Wait 3 seconds
If light switch turned on while lights are set to be dim
- stop other programs that may still be running and setting a different brightness
- set lights to go to 100% brightness via motion sensor
- set lights to go to dim brightness next on click (Lights will already have gone to 100% brightness based on existing scene setup)
- leave them on by disabling off program
- Set them to 100% bright a few times in case motion sensor triggers them to previous setting before scene is updated
$iLivingRoomLightLevel is 2
And (
Or Control 'Main Floor / Living Room / Living Room Hall Light' is switched Fade Stop
Or Control 'Main Floor / Living Room / Living Room Lights' is switched Fade Stop
Stop program 'Living Room Set Motion Bright'
$iLivingRoomLightLevel = 1
In Scene 'Main Floor / Living Room / Living Room Motion-Sensor' Set 'Main Floor / Living Room / Living Room Lights' 50% (On Level)
In Scene 'Main Floor / Living Room / Living Room Motion-Sensor' Set 'Main Floor / Living Room / Living Room Hall Light' 50% (On Level)
Run Program 'Living Room Set On Bright' (Then Path)
Wait 1 second
Wait 1 second
Wait 2 seconds
Wait 3 seconds
If light switch turned on while lights are bright or switch faded up or down
- set lights to go to dim brightness via motion sensor
- set lights to go to 100% brightness next on click (Lights will already have gone to dim brightness based on existing scene setup)
- Set them to dim brightness a few times in case motion sensor triggers them to previous setting before scene is updated
Living Room Set Motion Dim With Off Timer
Control 'Main Floor / Living Room / Living Room Lights' is switched Fast Off
Or Control 'Main Floor / Living Room / Living Room Hall Light' is switched Fast Off
Or $sDark is 1
Enable Program 'Living Room Off Timer'
If light switch double-clicked off or it's now dark out (reset to normal)
- enable off timer program
Control 'Main Floor / Living Room / Living Room Hall Light' is switched Off
Or Control 'Main Floor / Living Room / Living Room Lights' is switched Off
Or $sDark is 0
In Scene 'Main Floor / Living Room / Living Room Motion-Sensor' Set 'Main Floor / Living Room / Living Room Lights' 0% (On Level)
In Scene 'Main Floor / Living Room / Living Room Motion-Sensor' Set 'Main Floor / Living Room / Living Room Hall Light' 0% (On Level)
Wait 1 second
Set 'Main Floor / Living Room / Living Room Lights' Off
Set 'Main Floor / Living Room / Living Room Hall Light' Off
Wait 1 second
Wait 2 seconds
Wait 2 seconds
If light switch turned off or no longer dark out
- set lights to go to 0% brightness via motion sensor
- set lights to go to dim brightness next on click (Lights will already have gone to 0% brightness based on existing scene setup)
- Set them to 0% brightness a few times in case motion sensor triggers them to previous setting before scene is updated
In Scene 'Main Floor / Living Room / Living Room Hall Light' Set 'Main Floor / Living Room / Living Room Hall Light' 100% (On Level)
In Scene 'Main Floor / Living Room / Living Room Hall Light' Set 'Main Floor / Living Room / Living Room Lights' 100% (On Level)
In Scene 'Main Floor / Living Room / Living Room Lights' Set 'Main Floor / Living Room / Living Room Lights' 100% (On Level)
In Scene 'Main Floor / Living Room / Living Room Lights' Set 'Main Floor / Living Room / Living Room Hall Light' 100% (On Level)
Set the lights to go to bright setting next on click.
In Scene 'Main Floor / Living Room / Living Room Hall Light' Set 'Main Floor / Living Room / Living Room Hall Light' 50% (On Level)
In Scene 'Main Floor / Living Room / Living Room Hall Light' Set 'Main Floor / Living Room / Living Room Lights' 50% (On Level)
In Scene 'Main Floor / Living Room / Living Room Lights' Set 'Main Floor / Living Room / Living Room Lights' 50% (On Level)
In Scene 'Main Floor / Living Room / Living Room Lights' Set 'Main Floor / Living Room / Living Room Hall Light' 50% (On Level)
Set the lights to go to dim setting next on click.
Hi switches,
Thanks so very much for the details which I am sure others will find useful.
My only concern with using so many Motion Sensors is if you have 2413S PLM. As it has been reported before, in some cases, too much RF traffic might corrupt one of the packets and turn it into an ALL On packet. Have you ever noticed that all your lights have turned on?
Thanks again and with kind regards,
I'm curious how this would apply with a zwave setup. Is there a status that would indicate if a zwave dimmer has been manually operated like insteon does?
Would this same rf traffic corruption happen in a zwave network?
Hi switches,
Yes, Michel I've had those issues and you put me in touch with Smarthome to get a newer PLM. I thought that the issue was only when a motion sensor changed a KPL backlight? And I assumed that a newer PLM would fix the issue. Am I wrong with these assumptions?
Also, I have had the issue happen one more time recently except some things turned on 100% and something things actually shut off but again could have been triggered by a motion sensor and the log doesn't show these devices turning off or on? Is this the same issue? I hope so otherwise I have another mystery issue.
