How to set KPL switch states
I control a light from two separate KPLs. I created a Scene to do this and when I turn the light on/off from either KPL the other KPL properly shows the light's current status. I also have a program that turns this light off under certain conditions but I haven't been able to figure out how to make the KPL keys properly reflect that the light has turned off. I can set the backlight level but can't set the key state. How do I set the key state off on both KPLs when I turn the light off in a program?
Just a thought: If you have the program turn the scene on or off rather than the device, would that solve the problem?
Backlight does not apply. That affects the On level of ALL buttons on the KPL. Have the Program turn the Scene On/Off rather then the light itself. Turning an individual device On/Off does not affect the linked devices.
Set Scene 'xxxx' On or Off
I thought that's what I needed (Set scene) but didn't see it. Works great. Thanks!
