Can you trigger a program from a Kelylinc button
Hi there-
Can you have a button on a keylinc pad trigger a program? I've not had any luck getting it to work.
Matt
Sure. What problems are you having?
First thing would be sure that the ISY is seeing the KPL button presses. Go to the ISY's Administrative Console, and try pressing the button ON and OFF.
Does the ISY see the status changes?
Can you post the program you are trying to have run?
Hi there. I guess the more specific question: how would you code this. Would you have the buttons set to toggle or not. Would you do any scene assignment? What is the cleanest way?
Matt
mattford: Just set them as toggle. I'd write the program as follows;
PROGRAM 1
IF: KPL 1 is on
THEN: (Run program A)
PROGRAM 2
IF: KPL1 is off
THEN: (turn off program A)
aLf
Any Insteon controller can run a program. You do not have to be in non-toggle mode. Here is an example.
These programs are in a folder that is only true between a logical midnight and a logical dawn.
Folder Conditions for 'When Midnight'
       From    11:00:00PM
       To       4:44:00AM (next day)
   And Program 'Vacation On' is False
    Or From    11:59:00PM
       To       5:14:00AM (next day)
   And Program 'Vacation On' is True
When someone turns on the backyard light between midnight and dawn the first program turns on all the outside lights.
Backyard Fast On
       Control 'Backyard' is switched Fast On
       Set Scene 'Outside Lights' Fast On
When they turn off the backyard light between midnight and dawn this program will override that behavior and turn the light on to a dim level.
Backyard Off
       Control 'Backyard' is switched Off
    Or Control 'Backyard' is switched Fast Off
       Set 'Backyard' 49%
       Run Program 'All Off OL Dark' (Then Path)
Then it resets all the outside lights to their midnight levels.
All Off OL Dark
       Set Scene 'Outside Lights - Evening' On
       Wait  3 minutes
       Wait  2 minutes  (Random)
       Set Scene 'Outside Lights - Midnight' On
I have similar programs set up for all our outside light switches.
Rand
Perfect explanation. Thanks for taking the time to post the examples.
Cheers,
Matt
So how would one use a KPL secondary button to run a program? For example in my master bedroom I want KPL button B to run the program "all off" to turn all insteon lights off. I have the button in nontoggle mode so it doesnt stay lit when I hit it but having a hard time getting the program to run properly each time.
Heres what I have is this correct or is there a better way?
IF
KPL MB-B is switched on
or KPL MB-B is switched off
THEN
Set scene 'My Lighting' Fast off
ELSE
No actions
Thanks in advance!
That looks fine. I would take the button out of non-toggle mode, hit it a bunch of times on/off, and make sure the Administrative Console recognizes your button presses. You may have a communication issue between the KPL and your ISY.
