Garage Door not close for 30 minutes then email me
I have been trying to create a program on my ISY/99 to check my Garage door I/O Linc Sensor to email me if someone forgot to close it for more than 30 minutes. Sometimes I came back home and noticed that my garage door have been left open all day..
I do not want to auto-close the garage door in 30 minutes. I do not want to notify me every time the garage door is open.
I only want to notify/email me when the garage door (I/O Sensor status is ON) is left open for more that 30 minutes or longer.
Any ideas to program the ISY, please let me know.. :roll:
Did you try something like this:
       Status  'Garage Door Sensor' is On
       Wait  30 minutes
       Send Notification to 'Default'
You also need to go into "Configuration -> Emails/Notifications -> Settings/Groups" and configure a group correctly. The group I used in the example above is named "Default".
The important thing in the above program is that whenever the Garage Door Sensor status changes, the program will start (or re-start) running, even if it was already running. So if the sensor goes 'off' while in the 30 minute wait, the program will re-start and run the 'Else' clause, rather than finishing the 'Then' clause, and you won't get notified.
Thanks a lot. It works great. It even only email me once time only, not every 30 minutes the door is not closed.
I thought you need to use a variable or 2nd program to work. Easier then I thought.
Now I can set any lights that my kids forgot to turn off during the daytime to notify me when I am away from home.
Thanks again. :D
Thanks again. :D
Take it one step further: If you were sent the "Door is Up" alert email that the door has been open for 30 minutes, then have another program send you the "Door is Down alert when the door is closed. You ONLY want to get the down alert if the door was open for more than the interval, i.e. if you get the up email, you want to get the down email. The trick is to set an integer (not state) variable and set it to 0 (false) when the door goes up then to 1 (true) when the up email is sent. Create another program that reacts when the door goes down AND the variable is 1 (true) to send another email alert that the door is down.
And useful feature of ISY programming: programs can be set to "disabled" to control when they run. Programs can execute disabled programs but conditions or status changes cannot.
Thanks again. :D
I hate to ask, but being totally new to ISY and having only had a very basic programming class in highschool...I can't figure out what this program should look like. Would you mind sharing? This is a great idea to get the notification once it's down after that 30 min window that it was up.
I'll take a shot:
First, create a new variable ... "Garage Left Open" ....
Then modify the program above to be:
       Wait  30 minutes
       Send Notification to 'Default' content 'Garage.LeftOpen'
       $Garage_Left_Open  = 1
Then, create a second program:
       Status  'Garage Door Sensor' is Off
And $Garage_Left_Open is 1
       Send Notification to 'Default' content 'Garage.Closed'
       $Garage_Left_Open = 0
Thanks Kman. My garage sensor arrived today actually, so this thread is perfect timing. I'll try to get everything setup tonight...and report back.
Thanks for taking this further. Now when I called home to tell me kids to close the garage, I can make sure they did it.
ISY99i is great for beginners programmer..
Thanks a bunch!
p/s: I plan to upgrade to ISY994i. Any advantages or shall I wait?
  • 1 month later...
I like to make some changes to this program. How do I get ISY to email me again if the garage door is not closed and left open for another 30 minutes, I want to be notify until the garage is closed..
Modify the first program as to add a repeat as follows:
       Wait  30 minutes
       Repeat every 30 minutes
-Xathros
No code supplied but....
What if you are home and forgot the door was open? Perhaps went to bed? Been there on that one.
You could flash some lights or make some noise as a reminder and then if the door doesn't get closed in the next 5 to 10 minutes then send the email 'cause you're not home. If it's late at night close the door automatically as a last resort.
Yes. More code memory. Support for current / newer Insteon Devices.
Advantages....you'll have to decide if you need it yet or not.
If you plan on buying newer devices you may need to upgrade.
It works great thanks!
If I want to send the notification to include the first time the garage door left open timestamp on the email is that possible to do. :roll:
In the email subject or body you can insert a date and time variable from the option at the bottom.
How do I insert the timedate variable on the email. I did not want the time the email sent. I want it to show the time of the first time the door is open. Maybe using a variable to store this when the garage door is open. Any sample codes will be appreciated.
You would have to use all or a good portion of this software http://wiki.universal-devices.com/index.php?title=ISY-99i_Generic_Calendar_Using_Programs_and_Variables
or hopefully UDI will add system variable access in one of the next version releases as per my request here.
http://forum.universal-devices.com/viewtopic.php?f=7&t=13530.
More voiced support never hurts their priority list.
This is not what I want to program to do. I want to insert the timedate variable on the email. I did not want the time the email sent. I want it to show the time of the first time the door is open on the email.. Maybe using a variable to store this when the garage door is open.
There are no string variables yet. Version 5 may allow for this when it is released. The simple solution for now would be to send a message when the door is opened that includes the current time:
  Control GD_IOLinc_Sensor is Switched On
   Send Notification To  Content GarageDoorOpened
For the custom notification:
Garage door opened at: ${alert.time12}} on ${alert.date}
Leave you "Still Open" reminders as they are.
When V5 comes out, hopefully you will be able to modify the above to simply store the date/time in variables when the door is opened then use those variables in your reminder messages.
It's been a while since I looked at apostolakisl's date programs and I don't remember if he tracks time as well as date. It may be possible that you could grab integer Hour and Minute from them to store in variables now but unless you have other uses for those programs, it's a lot of effort for this single use.
-Xathros
I'm wondering if it would it be better to use a state variable and change the init and current state together so the program would survive a power cycle? I'm still learning and use something similar with state variable but wasn't sure if there was a downside to that.
Big517-
Any place a value is critical, regardless of state or integer, setting the init value is a good idea for just that reason.
-Xathros
       Status  'IO Linc Garage Door-Sensor' is On
   And From     7:00:00PM
       To      11:59:00PM (same day)
       Resource 'Garage Door: Has been left open '
What is the expected behavior in this program? If the door is open from 7-11:59 PM an alert message will arrive? I am trying to redo a auto close feature for the GDO. But, want to ensure safeties are in place so this works as intended.
Right now I have a program and a separate device that locks out the GDO when the alarm security system is in lock down mode.
Teken . . .
  • 1 month later...
The repeat function works great. But I got annoyed when I got repeated email forever. How can I make it better by only repeat the send email for only 3 times and stop send me any more email. And after the garage door is close, I want to send me email that the door is closed. Any ideas.. I could not find any feature in 99i that allow me to repeat for x number times for every hour..
I am in no position to check right now, but I thought the repeat could be defined for X number of times. Combined with a one-hour wait would , in my mind, accomplish your goals.
Repeat 3 times
Notify
Wait 1 Hour
-Xathros
