AT&T to end email-to-text ×
Where are my double Taps?
Michaelv
I recently upgraded from an ISY99IR Pro to the ISY994ir Pro. Process went pretty smoothly, but It seems that none of my programs I have written that include a quick double tap to trigger to run the program are working. Any Ideas?
Did you update to the latest firmware, this was a known bug in earlier versions and if you just upgraded you might be on that older buggy version.
I am now upgraded to 4.1.1. Still not working.
Here is the Log as suggested by LeeG.
Tue 12/31/2013 06:00:44 PM : [X10-RX ] 02 52 95 00
Tue 12/31/2013 06:00:44 PM : [ X10] F7
Tue 12/31/2013 06:00:45 PM : [X10-RX ] 02 52 93 80
Tue 12/31/2013 06:00:45 PM : [ X10] F7/Off (11)
Tue 12/31/2013 06:00:48 PM : [X10-RX ] 02 52 95 00
Tue 12/31/2013 06:00:48 PM : [ X10] F7
Tue 12/31/2013 06:00:48 PM : [X10-RX ] 02 52 93 80
Tue 12/31/2013 06:00:48 PM : [ X10] F7/Off (11)
There are X10 messages in the trace and no Insteon messages. Are these the messages that were produced when the device was double tapped?
Is a new PLM being used with the 994i?
No, it is the Old PLM. they were on Back order from Smarthome. It should be here tomorrow.
I did a single, then a double tap.
I believe this switch used to control some X-10 switches that I have since replaced with Insteon switches.
However, this double tap was controlling and insteon switch before the upgrade to the new ISY.
If these are the messages generated when the paddle is pressed it has an X10 address assigned to it. X10 does not have double tap function that I remember.
Running with the older PLM should be fine. If the PLM was changed it would require the new PLM link database be rebuilt.
The switch is in the ISY.
Here is the event view doing a single tap and a double tap on a different switch.
Wed 01/01/2014 12:41:59 PM : [ Time] 12:42:00 1(0)
Since I have not seen an Insteon message in any of the event viewer postings I suggest doing a File | Restore Modem (PLM) to rebuild the PLM link database.
