problems upgrading to 994i - blinking MEM & ERR LEDs
I am trying to upgrade my ISY and running into issues.
have: ISY-99i, 3.3.10, static IP, 2412 PLM
goal: ISY-994i & 2413s PLM & power supply
I am aware of the Java issue and am using the 4.1.2 GUI as a workaround.
First I tried to follow http://wiki.universal-devices.com/index ... r_ISY-994i and I kept my old PLM. I got the blinking MEM & ERR LEDs. I tried adding the power supply, no help.
This page http://wiki.universal-devices.com/index ... tart_Guide says:
MEM and ERR Blinking: ISY cannot communicate with attached router (or computer, if directly connected). Cable bad, or misconfiguration in ISY or in router (or computer, if directly connected).
Does the ISY-994i require something different on my router? Is this related to my ISY-99i using a static IP? I am using the same cables for my 99i and 994i.
I have tried reseating the micro SD card. Every so often the blink pattern changes and the MEM LED does a short blink, while the ERR LED does a regular blink. Does this mean I have a file system error?
I switched back to my ISY-99i, but added the 2413 PLM & power supply. I followed the "Replace PLM" instructions. That seemed to go OK. So, I am now running on the 99i and 2413.
What do I need to do to migrate to the 994i?
Genius! Thank You!
Actually, it wasn't an IP conflict, but when checking my router to confirm, I saw that my DHCP pool was all used up by visitors and new gadgets. Therefore the new 994i was the first device to not get an IP address when it asked... Murphy's law strikes again. :oops: So, after I expanded the DHCP pool, the ISY-994i booted properly and I was able to connect. I restored my backup, reset my lat/long/time stuff & user/password. And I am back on my static IP.
I just had to boot back to the old unit to get the uuid to transfer my modules because I failed to write it down. :oops:
Looks like everything is working fine now. Thanks a lot.
