Cannot access ISY
Got my ISY last week and spent many hours getting it configured. I gave it static IP address and change the port to 81. All has been working great. I already have a website that uses port 80 and 443, so I decided to update ISY to use port 444 for SSL.
Unit requested a reboot, now I cannot access ISY at all.... what am I missing?
Not sure why, but a disconnect of power, wait 5 secs and re-connect power solved the issue.
Troubleshooting rule number 1 for any computer device: reboot and hope that fixes the problem.works about 50% of the time.
I am having this same problem. I was changing the port on my ISY tonight. It did a reboot, then all my lights went out and I cannot connect to the ISY again. When I reboot the ISY manually, it reboots and turns off all my lights and I still cannot connect to it again. It says ISY not found.
If you run Win 7 (likely Win 8 also) and your static IP assignment failed for some reason, you can run the "Network" app and it should show up so you can determine the IP address.
