ISY 994i and Z-Wave
Does anyone know if the Z-wave module is compatible with z-wave motion sensors?
Hi Bxsteez,
Yes but in 4.1.3 to be out in couple of weeks.
AWESOME!! I'm not sure if the Z-wave motion sensors are better than insteon but they do look better and there are far more options.
I am new to ISY's. I have ADT Pulse with a front door keyed entry system (which is Z-wave). I saw that the isy has a Z-Wave module which I have installed. However, I think it need a Z-Wave Dongle. Which one should I get. I want to be able to have my ISY994 control the door lock. Is this possible?
Frank
Frank
Hi Frank-
The door locks are most certainly possible. Not so sure about the ADT keypad. I suspect that will be a problem.
For the dongle, you need the "Z-Wave Assembly Kit" from UDI. Go here: http://www.universal-devices.com/sales/products/ and scroll down to accessories.
Frank
Hi Frank-
Thanks Xathros.. They have other USB dongles. Can I use that instead? Or is this the only way.
Frank
The ISY does not support usb connected dongles. There is an expansion connector inside the ISY to accept the ZWave daughter board.
  • 3 months later...
So it seems 4.1.3 never came out but 4.2.x did. Does it support Z-wave motion sensors? Is there a place I can find a list of supported Z-wave devices so I don't have to buy, try and return?
