Refurbished 2450 IO Linc cannot be added.
I purchased a refurbished 2450 IO Linc but cannot add the device to ISY994i version 4.1.2. Using autodiscover and manual entry for a 2450 I receive "Unsupported Device 7.13". I've tried clearing cache, upgrading to 4.1.2 but the device will not link to the system. Any other suggestions?
By chance is there a model number and hardware revision sticker on the I/OLinc?
Reason I asked. Is I have seen some new I/OLIncs and a unreleased I/O module number. In the HouseLinc Devices.xml file with different Sub Cat numbers.
What power requirements are listed on the back label?
The HouseLinc devices.xml file also shows an interesting 2450 I/OLinc with 50/60 cycle auto select. It also has a different Sub Cat 0D.
Along with a 2248-222,-422,-442,-522 series of I/O Modules that all have new Sub Cat IDs.
From the suffix numbers. It could be they are now going international.
Thanks everyone. I will test with 4.1.3 and post the results.
  • 1 month later...
Upgraded to 4.2.0 and the refurbished 2450 was recognized and configured normally. Thank you for the help!
