2474DWH SwitchLinc Dimmer 2-Wire
After about a month the SwitchLinc has stopped responding to ISY commands and show a big red exclamation mark. Tried to query to no avail. Device is close to other dual band devices (3 - 6 ft) including the ISY PLM. Any thoughts as to whats going on besides just a dead device?
Here is the event log...
Fri 03/14/2014 11:03:55 AM : [iNST-TX-I1 ] 02 62 24 09 F2 0F 19 00
Fri 03/14/2014 11:03:55 AM : [iNST-ACK ] 02 62 24.09.F2 0F 19 00 06 LTSREQ (LIGHT)
Fri 03/14/2014 11:04:04 AM : [iNST-TX-I1 ] 02 62 24 09 F2 0F 19 00
Fri 03/14/2014 11:04:04 AM : [iNST-ACK ] 02 62 24.09.F2 0F 19 00 06 LTSREQ (LIGHT)
Fri 03/14/2014 11:04:13 AM : [iNST-TX-I1 ] 02 62 24 09 F2 0F 19 00
Fri 03/14/2014 11:04:13 AM : [iNST-ACK ] 02 62 24.09.F2 0F 19 00 06 LTSREQ (LIGHT)
I have a few of these that have been problematic especially when there have been power outages. Usually, pulling the air gap switch for 10 seconds then returning to the normal position gets them working again. When pushing the air gap switch back in, be careful not to push it past flush as that may cause a factory reset.
-Xathros
You are a genius... that fixed the problem. Had a power outage the other night till the backup generator kicked in. Thanks.
Not a genius, just an old timer... But thanks. Glad that got it working for you :)
-Xathros
