Admin console will not run on mac
I can run admin console on windows without complaint, but I only have one windows machine and multiple mac laptops and desktops... all running 10.9.2.
I got the admin.jnlp from the release notes for 4.1.2 for my isy994i ZS, but I cannot run this on my mac, even after javaws -clearcache at the command line.
The dialog box shown is:
Insecure update error!
For security reasons, you need to sign your updates with a DSA key. See Sparkle's documentation for more information.
[OK]
And the ISY Finder is also shown at the same time with no devices found.
I would really appreciate not having to use a windows machine that really only exists for the sole purpose of running elkRP in order to configure or update my isy.
Java console shows the following on a clean startup after clearing everything out:
Java Web Start 10.51.2.13
Using JRE version 1.7.0_51-b13 Java HotSpot 64-Bit Server VM
User home directory = /Users/nil
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
0-5: set trace level to
basic: Java part started
basic: jnlpx.jvm: /Library/Third Party Plugins/JavaAppletPlugin.plugin/Contents/Home/bin/java
basic: jnlpx.splashport: -1
basic: jnlpx.remove: true
basic: jnlpx.heapsize: null
network: Loading user-defined proxy configuration ...
network: Done.
network: Loading proxy configuration from Netscape Navigator ...
network: Done.
network: Loading browser proxy configuration ...
network: Done.
network: Proxy Configuration: System Proxy Configuration
basic: Running JVMParams: [JVMParameters]
-> [JVMParameters]
security: Loading Deployment certificates from /Users/nil/Library/Application Support/Oracle/Java/Deployment/security/trusted.certs
security: Loaded Deployment certificates from /Users/nil/Library/Application Support/Oracle/Java/Deployment/security/trusted.certs
security: Loading certificates from Deployment session certificate store
security: Loaded certificates from Deployment session certificate store
security: Loading Root CA certificates from /Library/Third Party Plugins/JavaAppletPlugin.plugin/Contents/Home/lib/security/cacerts
security: Loaded Root CA certificates from /Library/Third Party Plugins/JavaAppletPlugin.plugin/Contents/Home/lib/security/cacerts
security: Obtain certificate collection in Root CA certificate store
security: Loading blacklisted.certs file: /Users/nil/Library/Application Support/Oracle/Java/Deployment/security/blacklisted.certs
security: SHA-256Certificate finger print: 78A693463B8C884B894F19B76F47D7A50ED9EAD8FCF6A172BEB5CCCD8597A3CC
security: SHA-256Certificate finger print: 0CFC19DB681B014BFE3F23CB3A78B67208B4E3D8D7B6A7B1807F7CD6ECB2A54E
security: SHA-256Certificate finger print: 8420DFBE376F414BF4C0A81E6936D24CCC03F304835B86C7A39142FCA723A689
security: SHA-256Certificate finger print: A4B6B3996FC2F306B3FD8681BD63413D8C5009CC4FA329C2CCF0E2FA1B140305
security: The OCSP support is enabled
security: The CRL support is enabled
network: Connecting http://ocsp.verisign.com/ with proxy=DIRECT
network: Connecting socket://ocsp.verisign.com:80 with proxy=DIRECT
security: OCSP Response: GOOD
security: Certificate validation succeeded using OCSP/CRL
network: Created version ID: 1.0+
network: Created version ID: 1.7.0.51
network: Created version ID: 2.2.51
temp: new XMLParser with source:
temp: <?xml version="1.0" encoding="utf-8"?>
ISY994 Administrative Console
Universal Devices, Inc.
Configuration Utility for ISY
ISY Admin Console
urn:udi-com:device:X_Insteon_Lighting_Device:1
temp:
returning ROOT as follows:
ISY Admin Console
network: Created version ID: 1.7+
temp: returning LaunchDesc from XMLFormat.parse():
ISY Admin Console
network: prepareToLaunch: offlineOnly=true
network: Cache entry not found http://
basic: Could not launch from cache. Will try online mode. [Missing from the cache: http://isy.universal-devices.com/994i/4.1.2/admin.jnlp]
network: prepareToLaunch: offlineOnly=false
network: Connecting http://isy.universal-devices.com/994i/4.1.2/admin.jnlp with proxy=DIRECT
network: Connecting socket://isy.universal-devices.com:80 with proxy=DIRECT
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/admin.jnlp : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/admin.jnlp : null
network: Server response: (length: 1150, lastModified: Mon Jan 13 23:24:29 PST 2014, downloadVersion: null, mimeType: application/x-java-jnlp-file)
network: Downloading resource: [url=http://isy.universal-devices.com/994i/4.1.2/admin.jnlp]http://isy.universal-devices.com/994i/4.1.2/admin.jnlp
Content-Length: 1,150
Content-Encoding: null
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/admin.jnlp to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/10/3ad77d4a-64328bc1-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/admin.jnlp
network: Cache: Enable a new CacheEntry: http://isy.universal-devices.com/994i/4.1.2/admin.jnlp
network: Downloaded http://isy.universal-devices.com/994i/4.1.2/admin.jnlp: /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/10/3ad77d4a-64328bc1
cache: Adding MemoryCache entry: http://isy.universal-devices.com/994i/4.1.2/admin.jnlp
ISY Admin Console
temp:
ISY Admin Console
ISY Admin Console
network: isUpdated: true
basic: Launcher: isInstaller: false, isRelaunch: false, isImport(): false, java.home:/Library/Third Party Plugins/JavaAppletPlugin.plugin/Contents/Home, Running JRE: JREInfo for index 1:
platform is: 1.7
product is: 1.7.0_51
location is: http://java.sun.com/products/autodl/j2se
path is: /Library/Third Party Plugins/JavaAppletPlugin.plugin/Contents/Home/bin/java
args is: null
native platform is: Mac OS X, x86_64 [ x86_64, 64bit ]
JavaFX runtime is: JavaFX 2.2.51 found at /Library/Third Party Plugins/JavaAppletPlugin.plugin/Contents/Home/
enabled is: true
registered is: true
system is: false
basic: JREInfos
basic:
JREInfo: 2 entries
basic: JREInfo 0:
basic: JREInfo for index 0:
platform is: 1.7
args is: null
enabled is: true
registered is: true
system is: true
basic: JREInfo 1:
network: Connecting http://isy.universal-devices.com/994i/4.1.2/udlogo.png with proxy=DIRECT
basic: JREInfo for index 1:
platform is: 1.7
args is: null
enabled is: true
registered is: true
system is: false
basic: LaunchDesc.selectJRE(false, false) returning selected jre: JREInfo for index 0:
platform is: 1.7
location is: [url=http://java.sun.com/products/autodl/j2se]http://java.sun.com/products/autodl/j2se
args is: null
enabled is: true
registered is: true
system is: true
basic: LaunchDesc location: http://isy.universal-devices.com/994i/4.1.2/admin.jnlp
cache: JNLPPreverifyClassLoader.initialize: FAILED: http://isy.universal-devices.com/994i/4.1.2/insteon.jar
basic: Offline mode: false
IsInCache: false
forceUpdate: true
needUpdate: false
IsInstaller: false
security: Security check for progress jars: allSigned=true
network: LaunchDownload: concurrent downloads from LD: 4
network: Total size to download: -1
network: Connecting http://isy.universal-devices.com/994i/4.1.2/insteon.jar with proxy=DIRECT
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/udlogo.png : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/udlogo.png : null
network: Server response: (length: 41358, lastModified: Mon Jan 13 23:25:13 PST 2014, downloadVersion: null, mimeType: image/png)
network: Downloading resource: [url=http://isy.universal-devices.com/994i/4.1.2/udlogo.png]http://isy.universal-devices.com/994i/4.1.2/udlogo.png
Content-Length: 41,358
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/insteon.jar : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/insteon.jar : null
network: Server response: (length: 3537106, lastModified: Mon Jan 13 23:25:06 PST 2014, downloadVersion: null, mimeType: application/java-archive)
network: Downloading resource: http://isy.universal-devices.com/994i/4.1.2/insteon.jar
Content-Length: 3,537,106
network: Connecting http://isy.universal-devices.com/994i/4.1.2/isy.jpg with proxy=DIRECT
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/isy.jpg : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/isy.jpg : null
network: Server response: (length: 2967, lastModified: Mon Jan 13 23:24:56 PST 2014, downloadVersion: null, mimeType: image/jpeg)
network: Downloading resource: [url=http://isy.universal-devices.com/994i/4.1.2/isy.jpg]http://isy.universal-devices.com/994i/4.1.2/isy.jpg
Content-Length: 2,967
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/isy.jpg to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/25/25ff2099-6c6cd3ad-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/isy.jpg
network: Cache: Enable a new CacheEntry: http://isy.universal-devices.com/994i/4.1.2/isy.jpg
network: Downloaded http://isy.universal-devices.com/994i/4.1.2/isy.jpg: /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/25/25ff2099-6c6cd3ad
cache: Adding MemoryCache entry: http://isy.universal-devices.com/994i/4.1.2/isy.jpg
network: CleanupThread used 444916 us
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/udlogo.png to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/22/3f1dfd16-60efc8bf-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/udlogo.png
network: Cache: Enable a new CacheEntry: http://isy.universal-devices.com/994i/4.1.2/udlogo.png
network: CleanupThread used 2 us
network: Downloaded http://isy.universal-devices.com/994i/4.1.2/udlogo.png: /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/22/3f1dfd16-60efc8bf
cache: Adding MemoryCache entry: http://isy.universal-devices.com/994i/4.1.2/udlogo.png
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/insteon.jar to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/54/3ad1576-5d134a3f-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/insteon.jar
security: Blacklist revocation check is enabled
security: blacklist: created: NEED_LOAD, lastModified: 1395699658000
security: blacklist: check contains X9Kn9lBYfffATjrp3QMrwpZR8LMJVb3BjbY5cUlJS18=, state now NEED_LOAD
security: blacklist: loadCache
security: blacklist: not found in cache
security: Trusted libraries list check is enabled
security: Trusted libraries list file not found
cache: Create from verifier: JarSigningData{hasOnlySignedEntries=true, hasSingleCodeSource=true, hasMissingSignedEntries=false}
network: Cache: Enable a new CacheEntry: http://isy.universal-devices.com/994i/4.1.2/insteon.jar
network: Downloaded http://isy.universal-devices.com/994i/4.1.2/insteon.jar: /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/54/3ad1576-5d134a3f
cache: Adding MemoryCache entry: http://isy.universal-devices.com/994i/4.1.2/insteon.jar
network: Download Progress: jarsDone: 1
cache: Cancel delay cleanup: URL: http://isy.universal-devices.com/994i/4.1.2/isy.jpg | /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/25/25ff2099-6c6cd3ad.idx
network: Created version ID: 7.0
temp: Convert image: /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/25/25ff2099-6c6cd3ad->/Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/25/25ff2099-6c6cd3ad.icns
cache: Cancel delay cleanup: URL: http://isy.universal-devices.com/994i/4.1.2/admin.jnlp | /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/10/3ad77d4a-64328bc1.idx
security: Trust for: http://isy.universal-devices.com/994i/4.1.2/insteon.jar has ended: Wed Dec 31 16:00:00 PST 1969
security: Validating cached jar url=http://isy.universal-devices.com/994i/4.1.2/insteon.jar ffile=/Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/54/3ad1576-5d134a3f com.sun.deploy.cache.CachedJarFile@9fe6055
security: Missing Codebase manifest attribute for: http://isy.universal-devices.com/994i/4.1.2/insteon.jar
security: Missing Application-Library-Allowable-Codebase manifest attribute for: http://isy.universal-devices.com/994i/4.1.2/insteon.jar
security: Istrusted: http://isy.universal-devices.com/994i/4.1.2/admin.jnlp false
security: Validate the certificate chain using CertPath API
security: SHA-256Certificate finger print: 121074F1688049DEF8BEEF399B4DA4B8293FB2B4578C674ABCCC1A9704D05149
security: SHA-256Certificate finger print: 178439CF1D0C81E7F3AEC4F1193C4884BEF139FE0A016016AA7E72177AE01419
security: SHA-256Certificate finger print: EBD41040E4BB3EC742C9E381D31EF2A41A48B6685C96E7CEF3C1DF6CD4331C99
security: Failing over to CRLs: Certificate does not specify OCSP responder
network: Cache entry found http:// prevalidated=false/0
cache: Adding MemoryCache entry: http://crl.globalsign.net/root.crl
Resource http://crl.globalsign.net/root.crl has future expires: Mon Apr 07 15:20:55 PDT 2014 update check skipped.
network: Connecting http://ocsp2.globalsign.com/gscodesigng2 with proxy=DIRECT
network: Connecting socket://ocsp2.globalsign.com:80 with proxy=DIRECT
network: Connecting http://ocsp2.globalsign.com/gscodesigng2 with cookie "__cfduid=d3168441f397a41f3328799bb7b63c8601393565689892"
security: Saving certificates in Deployment session certificate store
security: Saved certificates in Deployment session certificate store
basic: updateValidationResultsForApplet update
cache: Mark prevalidated: http://isy.universal-devices.com/994i/4.1.2/insteon.jar true tm=1395700995503 cert=1459617307000
security: Certificate revocation enabled. Disable security validation optimizations.
cache: Reading Signers from 0 http://isy.universal-devices.com/994i/4.1.2/admin.jnlp | /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/10/3ad77d4a-64328bc1.idx
basic: passing security checks; secureArgs:true, allSigned:false
basic: trusted app: true, -secure=false
basic: JREMatcher:
JREDesc: JREDesc[version 1.7+, versionType=0, secure=false, heap=-1--1, args=null, href=http://java.sun.com/products/autodl/j2se, sel=true, null, null]
JREInfo: JREInfo for index 0:
platform is: 1.7
args is: null
enabled is: true
registered is: true
system is: true
Init Heap: -1
Max Heap: 67108864
Satisfying: true, true
SatisfyingVersion: true
SatisfyingJVMArgs: true, true
SatisfyingSecure: true
Selected JVMParam: [JVMParameters]
Running JVMParam: [JVMParameters]
temp: Create bundle=/Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/bundles/ISY994 Administrative Console.app
temp: bundleDirectory is /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/bundles/ISY994 Administrative Console.app
temp: bundleExecutable is ISY994 Administrative Console
temp: bundleGetInfoString is Configuration Utility for ISY
temp: bundleIdentifier is com.oracle.jnlp--1597469455
temp: bundleAppIconFile is /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/25/25ff2099-6c6cd3ad.icns
temp: bundleName is ISY994 Administrative Console
temp: launchArgs:
temp: [0]=-localfile
temp: [1]=-online
temp: [2]=-J-Djnlp.application.href=http://isy.universal-devices.com/994i/4.1.2/admin.jnlp
temp: [3]=/Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/10/3ad77d4a-64328bc1
basic: continuing launch in this VM
basic: Main-class: com.universaldevices.client.ui.UDClientApplet
security: JAVAWS AppPolicy Permission requested for: http://isy.universal-devices.com/994i/4.1.2/insteon.jar
security: Grant socket perm for http://isy.universal-devices.com/994i/4.1.2/insteon.jar : java.security.Permissions@6d2efbbd (
("java.net.SocketPermission" "isy.universal-devices.com" "connect,accept,resolve")
network: LDUpdater: started background update check
network: JARUpdater: update check for http://isy.universal-devices.com/994i/4.1.2/insteon.jar
network: JARUpdater: update check for http://isy.universal-devices.com/994i/4.1.2/ce.jar
network: Connecting http://isy.universal-devices.com/994i/4.1.2/ce.jar with proxy=DIRECT
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/ce.jar : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/ce.jar : null
network: Server response: (length: 109549, lastModified: Mon Jan 13 23:24:35 PST 2014, downloadVersion: null, mimeType: application/java-archive)
network: CleanupThread used 3 us
network: Downloading resource: http://isy.universal-devices.com/994i/4.1.2/ce.jar
Content-Length: 109,549
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/ce.jar to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/35/60bc9123-161df8b6-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/ce.jar
security: blacklist: check contains FFOFXW/1TRu/WcENWDL62kGKK9Szkog++xDXnjD1tf0=, state now IN_MEMORY
network: JARUpdater: update check for http://isy.universal-devices.com/994i/4.1.2/chart.jar
network: Connecting http://isy.universal-devices.com/994i/4.1.2/chart.jar with proxy=DIRECT
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/chart.jar : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/chart.jar : null
network: Server response: (length: 981989, lastModified: Mon Jan 13 23:24:38 PST 2014, downloadVersion: null, mimeType: application/java-archive)
network: Downloading resource: http://isy.universal-devices.com/994i/4.1.2/chart.jar
Content-Length: 981,989
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/chart.jar to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/32/6566bfa0-226a0cc4-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/chart.jar
security: blacklist: check contains qGOqdRQC81kIvklYbY5P641Q8Av//i0UqT2CZw/eDas=, state now IN_MEMORY
network: JARUpdater: update check for http://isy.universal-devices.com/994i/4.1.2/fp.jar
network: Connecting [url=http://isy.universal-devices.com/994i/4.1.2/fp.jar'>http://isy.universal-devices.com/994i/4.1.2/fp.jar]http://isy.universal-devices.com/994i/4.1.2/fp.jar with proxy=DIRECT
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/fp.jar : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/fp.jar : null
network: Server response: (length: 776284, lastModified: Mon Jan 13 23:24:53 PST 2014, downloadVersion: null, mimeType: application/java-archive)
network: CleanupThread used 4 us
network: Downloading resource: http://isy.universal-devices.com/994i/4.1.2/fp.jar
Content-Length: 776,284
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/fp.jar to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/30/1d34179e-35294618-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/fp.jar
security: blacklist: check contains k0t4AgK0m+Exz1EPpKJ4wossj7/b/j/tnmubo4Ce8yI=, state now IN_MEMORY
network: CleanupThread used 1 us
network: JARUpdater: update check for http://isy.universal-devices.com/994i/4.1.2/RXTX.jar
network: Connecting http://isy.universal-devices.com/994i/4.1.2/RXTX.jar with proxy=DIRECT
network: ResponseCode for http://isy.universal-devices.com/994i/4.1.2/RXTX.jar : 200
network: Encoding for http://isy.universal-devices.com/994i/4.1.2/RXTX.jar : null
network: Server response: (length: 67746, lastModified: Mon Jan 13 23:25:08 PST 2014, downloadVersion: null, mimeType: application/java-archive)
network: Downloading resource: http://isy.universal-devices.com/994i/4.1.2/RXTX.jar
Content-Length: 67,746
network: Wrote URL http://isy.universal-devices.com/994i/4.1.2/RXTX.jar to File /Users/nil/Library/Application Support/Oracle/Java/Deployment/cache/6.0/21/334bca15-6e2a66f0-temp
network: Disconnect connection to http://isy.universal-devices.com/994i/4.1.2/RXTX.jar
security: blacklist: check contains MacYLi7Mi+RZ7CazOjJ8nP4mbe8rt7Y8Wb90mIX113E=, state now IN_MEMORY
network: Cache: Enable a new CacheEntry: [url=http://isy.universal-devices.com/994i/4.1.2/ce.jar]http://isy.universal-devices.com/994i/4.1.2/ce.jar
network: Cache: Enable a new CacheEntry: [url=http://isy.universal-devices.com/994i/4.1.2/chart.jar]http://isy.universal-devices.com/994i/4.1.2/chart.jar
network: Cache: Enable a new CacheEntry: http://isy.universal-devices.com/994i/4.1.2/fp.jar
network: Cache: Enable a new CacheEntry: [url=http://isy.universal-devices.com/994i/4.1.2/RXTX.jar]http://isy.universal-devices.com/994i/4.1.2/RXTX.jar
Hello nlaredo,
This error dialog makes no sense:
[OK]
It seems to me that the system is complaining about something else. This is not an Update and jar files are signed by RSA and never DSA.
Do you have the same issue with all your MACs? Specifically, do you get the same dialog?
As nearly as I can tell, it is part of the auto-update framework for the Java Runtime Environment/JavaAppletPlugin since JRE7u6.
I did not have this problem before the update to 7.
If I manually install JDK8 and then manually invoke as follows (vs using /usr/bin/javaws), I can make it work
/Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/javaws admin.jnlp
I'm pretty sure though since my macs are managed by my employer that they will likely undo what I have done shortly.
