AutomationNut Posted March 29, 2014 Share Posted March 29, 2014 I recently replaced a 8 button Inseton keypad 2486 with the new Insteon 8 button keypad 2334-222 because the LED's would not illuminate despite setting the LED brightness level to 15 in the ISY admin console. I have since spent some time searching the forum and investigating the symptoms of this problem. The interesting part is that button A is assigned as a controller for a floor light which is set at a "on level" of 98% (to reduce voltage to light and save the bulb a bit). When I set the LED brightness for the keypad in the admin console to 15 and operate button A the LED comes on when pressed and goes off when pressed again, just as is should. I operated it multiple times and the LED comes on and off just as it should. Now Button B is assigned as a controller for a scene called "Movie Scene" the "Movie Scene" turns on two lights, both at 24% when I FIRST press button B after changing the brightness level in the admin console the LED backlight and the "Movie Scene" is activated, a second press turns off the "Movie Scene", the two lights and the LED backlight...now pressing it a third time activates the "Movie Scene" and the two lights but the LED backlight for Button B does NOT illuminate. Furthermore, when I return to the Admin Console to check the LED brightness it has reset to 0 for all buttons. I have done this several times (reset in Admin Console, press B button three times, LED Brightness resets to 0). I'm stuck, this functionality used to work with my old 8 button 2486 but when the 2486 quit working I replaced it with the new 2334-222 and the problem persists. What has changed? anyone have any ideas? Thanks in advance for the help! Link to comment
LeeG Posted March 29, 2014 Share Posted March 29, 2014 First, the Backlight level cannot be set for individual buttons. Setting a Backlight value applies to all buttons. The newer devices use Backlight value as a % On rather than an Off/On value. An Off/On setting of 7/15 (0x7F) is 100% On. An Off/On value of 3/15 (0x3F) is approx 50% On level. An Off/On value of 0/0 turns the button LEDs completely Off. It does not logically turn the button Off, only the LEDs Off for those who want a dark KPL at night. Going from 0/0 to 7/15 will turn the LEDs back to the previous button LED On/Off state. That is, a button LED that was On before going to 0/0 will be On when going back to 7/15. Link to comment
AutomationNut Posted March 29, 2014 Author Share Posted March 29, 2014 LeeG, thanks for your quick response. I did set the KPL to 7/15 using the admin console and in the OFF state all the buttons were lit. I pressed the "Movie Scene" which is on button B a couple of times and all the KPL buttons turned off and stayed off. Returning to the Admin Console I found that the LED Brightness was back to 0/0. I then reset it to 7/15 using the admin console and again found all buttons lit. I repeatedly pressed the "A" button (100% floor light on) and all the buttons stayed lit. I then pressed the "B" button and all the buttons went dark, returning to the admin console I found the LED Brightness in the Admin Console to be reset to 0/0. I don't understand what is resetting the LED brightness and why the brightness will not hold in the KPL, any ideas? Link to comment
oberkc Posted March 29, 2014 Share Posted March 29, 2014 This sure sounds abnormal to me. Have you checked the keypad manual to determine how to manually set the backlight levels? Does it involve button B somehow? I wonder is there is some failure or stuck button on the keypad that is causing this. Link to comment
AutomationNut Posted March 29, 2014 Author Share Posted March 29, 2014 I did play with trying to manually set the backlight level, involves tapping the C and F buttons and holing the A (or on button). I can set them locally but have the same issue. Wondering if the scene assigned to be toggled by button B has anything to do with this issue? the Button assigned to Scene B turns on two room lights at 24%. I'm stuck, any help appreciated. Link to comment
LeeG Posted March 29, 2014 Share Posted March 29, 2014 What does Help | About show for Firmware and UI levels? Link to comment
AutomationNut Posted March 30, 2014 Author Share Posted March 30, 2014 Insteon_UD994 v.4.1.2 (23014-01-13-23:20:00) Link to comment
AutomationNut Posted April 2, 2014 Author Share Posted April 2, 2014 Hey folks, I'm still having problems with this keypad . This arrangement used to work several months ago so I assumed it was a bad Keypad, but the new keypad has the same behavior. Any help would be appreciated. thanks Link to comment
Michel Kohanim Posted April 2, 2014 Share Posted April 2, 2014 Hello AutomationNut, Please submit a ticket (links/contact info below) and we'd be delighted to log in to your system and see what's going on. With kind regards, Michel Link to comment
AutomationNut Posted April 4, 2014 Author Share Posted April 4, 2014 Michel, Steve has resolved my problem with the keypad, it was in fact my error in a program causing the problem. Steve, much thanks to you and your keen insight to figure out my error. Link to comment
NerlyAguilera Posted September 5, 2014 Share Posted September 5, 2014 I have a keypad 8, the Main button turns on a light, but I made a program so that when it turns the Main lit another lamp. If I turn on the Main from Admin Console, it works. If I turn pressing the Main button does not work. You can be? Link to comment
LeeG Posted September 5, 2014 Share Posted September 5, 2014 Sounds like the Program If section needs some additional work. Please paste the Program into a post. Link to comment
