isenbje Posted April 6, 2014 Posted April 6, 2014 I have 2 programs that are programed to start executing at the same time. Both contain wait commands. It appears that after one program executes a wait command the second program reevaluates its start time, at which point it stops executing. What to do?
larryllix Posted April 6, 2014 Posted April 6, 2014 Can you copy each programme and paste them here so people can examine the fine details ot the syntax? Use the right click on the programmes and the "Code" button above the text box to paste them in verbatim format.
isenbje Posted April 6, 2014 Author Posted April 6, 2014 If Program 'IsShabbatOrYomtov' is True And ( ( Time is 7:00:00AM And Program 'is9Minyan' is False ) Or ( Time is 7:30:00AM And Program 'is9Minyan' is True ) ) Then Set 'Dafna's Bathroom' On Wait 30 minutes Set 'Curlers' On Set Scene 'Master Bathroom' On Set Scene 'Closets' On Set 'Upstairs Bathroom' On Set 'Jerry's Bathroom' 50% Wait 2 hours Set 'Curlers' Off Set Scene 'Master Bathroom' Off Set Scene 'Closets' Off Set 'Upstairs Bathroom' Off Set 'Jerry's Bathroom' Off Set 'Dafna's Bathroom' Off Else - No Actions - (To add one, press 'Action') If Program 'isRaining' is False And ( On Sat, Tue, Thu Time is 7:30:00AM ) Then Set 'Sprinkler / Zone1 Streetside' On Wait 8 minutes Set 'Sprinkler / Zone1 Streetside' Off Set 'Sprinkler / Zone2 Roses along sidewalk' On Wait 5 minutes Set 'Sprinkler / Zone2 Roses along sidewalk' Off Set 'Sprinkler / Zone3 Front edge of house' On Wait 5 minutes Set 'Sprinkler / Zone3 Front edge of house' Off Set 'Sprinkler / Zone4 South edge of house' On Wait 5 minutes Set 'Sprinkler / Zone4 South edge of house' Off Set 'Sprinkler / Zone5 Poolside' On Wait 5 minutes Set 'Sprinkler / Zone5 Poolside' Off Else - No Actions - (To add one, press 'Action')
oberkc Posted April 6, 2014 Posted April 6, 2014 Without knowing what are the names of these two programs, or knowing what makes programs "IsShabbatOrYomtov", 'is9Minyan', or 'isRaining' to be true or false, it will be hard to say what is causing your programs to halt execution during the wait statement. Assuming the conditions of these two programs accomplish your goals, my temptation would be not to worry about attempting to isolate your problem. Instead, break out the THEN paths of each program, putting them into separate (disabled, without IF conditions) programs. For example, create a program (disabling it) that looks like this: IF THEN Set 'Dafna's Bathroom' On Wait 30 minutes Set 'Curlers' On Set Scene 'Master Bathroom' On Set Scene 'Closets' On Set 'Upstairs Bathroom' On Set 'Jerry's Bathroom' 50% Wait 2 hours Set 'Curlers' Off Set Scene 'Master Bathroom' Off Set Scene 'Closets' Off Set 'Upstairs Bathroom' Off Set 'Jerry's Bathroom' Off Set 'Dafna's Bathroom' Off ELSE Then modify your first program to look like this: If Program 'IsShabbatOrYomtov' is True And ( ( Time is 7:00:00AM And Program 'is9Minyan' is False ) Or ( Time is 7:30:00AM And Program 'is9Minyan' is True ) ) Then run new program (then path) Else - No Actions - (To add one, press 'Action') Take the same approach to the second program.
isenbje Posted April 6, 2014 Author Posted April 6, 2014 Thank you for your suggestion. FYI from my log 1. Both programs started executing at 7:30 AM Saturday morning 2. The command "Set 'Dafna's Bathroom' On" in the 1st program executed successfully. 3. The second program for the sprinkler system executed completely 4. None of the commands in the 1st program after the command noted above were executed. I can try your suggestion, but can you explain why it could solve the problem?
LeeG Posted April 6, 2014 Posted April 6, 2014 If nothing executed after the 30 minute Wait either 'IsShabbatOrYomtov' or 'is9Minyan' changed Status before the Wait completed. That change in Status terminated the Wait and executed the Else. Note: it is a good idea to identify the names of Programs that are posted.
LeeG Posted April 6, 2014 Posted April 6, 2014 There are two things that stop a Program in a Wait, either the Conditions in the If change causing the If to be reevaluated or the Program was Stopped/Disabled.
oberkc Posted April 6, 2014 Posted April 6, 2014 I can try your suggestion, but can you explain why it could solve the problem? Like LeeG suggests, I and I concur...I believe something in your program is changing and triggering your program, likely changing status to false during the 30 minute wait. Look at your program list and find the current status of this first program? Is it false? When was it last executed? After 7:30 and before 8:00? The purpose of breaking it out into it's own program is to avoid it being interrupted by a change in status. Once running, unless called manually or by another program, it will continue to the end. No wait statements will be interrupted.
andyf0 Posted April 8, 2014 Posted April 8, 2014 So the Wait is 30 mins. The "if" contains a test for 7:00 and a test for 7:30. So when the time hits 7:30 it will interrupt the wait (albeit by a hair).
isenbje Posted April 8, 2014 Author Posted April 8, 2014 That is what happens according to the log. Program begins execution at 7 AM and then aborts at 7:30. isMinyan is false and IsShabbatOrYomtov is true. I reran it this morning. The isMinyan and IsShabbatOrYomtov parameters had not changed their status. Is it possible that the program aborts because the wait command forces it to recalculate the time and the change from 7 AM to 7:30 AM forces it to stop execution? Sprinkler program ran to completion.
LeeG Posted April 8, 2014 Posted April 8, 2014 The Program is in the 30 minute Wait at 7:30. The Program is triggered at 7:30 because of the Time parameter. Being ANDed with †'is9Minyan' is True†the evaluation is False so the Else clause executes. Knowing the Program started at 7:00 rather than 7:30 as was originally indicated changes how the scenario occurs but the result is the same. Starting at 7:00 means the 7:30 Time triggers the Program. If it had started at 7:30 one of the other conditions would have had to change to cause the Program to trigger again as the Time parameters had already passed.
isenbje Posted April 8, 2014 Author Posted April 8, 2014 Thank you. In order to solve the problem I will break out the program following oberkc's suggestion shown above. I feel this is a bug in the programming. There should be a way to give a wait command that does not allow the status to be reevaluated.
LeeG Posted April 8, 2014 Posted April 8, 2014 It is not a bug as that is how the Wait and Repeat functions are designed to work. The Wiki section that covers Wait and Repeat explains this interaction. I think adding an option to Wait and Repeat to prevent the If reevaluation has been asked for but has a low priority as using two Programs is the alternative. The If reevaluation works well when used with actions that repeat such as Motion Sensors where the actions after the Wait/Repeat are desired only after all motion stops. If Control 'motion - sensor' is switched On Then turn lights On Wait 10 minutes turn lights Off Else The lights stay On as long a motion detection continues.
oberkc Posted April 8, 2014 Posted April 8, 2014 I feel this is a bug in the programming I have always viewed this as a design decision rather than a bug. It does have its advantages in certain cases, and disadvantages in others. Others, however, have voiced similar viewpoints to your own. There should be a way to give a wait command that does not allow the status to be reevaluated. I believe that there is a way. It is the one I suggested. Alternatively, you can "disable" a program, which restricts a program from self-initiating (allowing the status to be reevaluated). I think you will find sufficient flexibility in programming the ISY, but it does have some learning curve to fully exploit.
apostolakisl Posted April 8, 2014 Posted April 8, 2014 The issue with non-interruptable waits/repeats has been beaten to a pulp. Indeed, it would be nice to have it both ways and probably UD will do something that allows you to choose. In the mean time, you accomplish the same thing by splitting the program in 2. If various conditions Then wait x time do something Else blank Can be changed to Program 1 If various conditions Then run program 2, then clause Else blank Program 2 If blank Then disable program 1 wait x time enable program 1 do something Else blank Now your "wait" clause will run to completion no matter what.
isenbje Posted April 9, 2014 Author Posted April 9, 2014 Rather than splitting the program I believe I can achieve the same end result by introducing the program-variable ContinueHolyMorning shown below (in 3 places). When the program below starts executing it is immediately set to true thereby keeping the 'then' part of the if statement true (avoiding early termination due to a change of status) until the very last statement in the program is executed, when it is set to false. This should prevent the program from aborting. Thank you for pointing out that there are many ways to "skin the cat". If Program 'IsShabbatOrYomtov' is True And ( ( Time is 7:00:00AM And Program 'is9Minyan' is False ) Or ( Time is 7:30:00AM And Program 'is9Minyan' is True ) Or Program 'ContinueHolyMorning' is True ) Then Run Program 'ContinueHolyMorning' (Then Path) Set 'Dafna's Bathroom' On Wait 30 minutes Set 'Curlers' On Set Scene 'Master Bathroom' On Set Scene 'Closets' On Set 'Upstairs Bathroom' On Set 'Jerry's Bathroom' 50% Wait 2 hours Set 'Curlers' Off Set Scene 'Master Bathroom' Off Set Scene 'Closets' Off Set 'Upstairs Bathroom' Off Set 'Jerry's Bathroom' Off Set 'Dafna's Bathroom' Off Run Program 'ContinueHolyMorning' (Else Path) Else - No Actions - (To add one, press 'Action')
apostolakisl Posted April 9, 2014 Posted April 9, 2014 Keeping the program "true" does not stop it from re-evaluating the if and starting the timer over. For example, If control light x is switched on Then wait x minutes do something Else blank This program will restart the wait every time light x on button is pushed, even if it is already on. In short, anything in the "if" clause that experiences a triggerable event, will kill a wait/repeat and either start it over again, or run the other clause. At times, this is a good thing. Like if you have a motion detector and want every re-trigger of it to restart a timer.
oberkc Posted April 9, 2014 Posted April 9, 2014 Rather than splitting the program I believe I can achieve the same end result by introducing the program-variable ContinueHolyMorning shown below (in 3 places). If you would rather avoid splitting the program for some reason, perhaps you can take advantage of an command to "disable" itself, then enabling itself after it is finished. There are also integer variables available that, when used as conditions in programs, do not act as triggers for the program. This may offer some options. But I second apostolaksl observation that it is not a CHANGE in status that triggers a re-evaluation. All of your program conditions are also program triggers. When triggered and evaluated, even if no change of state takes place, the program will re-execute whatever path is dictated by the evaluation, from the beginning. So, if the program is 29 minutes into the wait period and the program is retriggered and again found true, the THEN condition will rerun, from the beginning. Perhaps, if you care to share your purpose and goals for this program, more specific ideas would come out.
isenbje Posted April 9, 2014 Author Posted April 9, 2014 I will take the suggested route and split the program.
