barrygordon Posted April 26, 2014 Share Posted April 26, 2014 I just installed firmware 4.2.1, I still have the UI of 4.1.2 installed. I also purchased and installed the Network module and the PRO module and installed them. The Insteon Thermostat entry in the admin console now shows "Heat On" for the Heat/Cool state when the thermostat is neither cooling nor heating, i.e. the thermostat is showing the system state as "Off", and the subscription system is sending a value of 1 for CLIHCS. When the thermostat shows cooling (i.e the LED is green) the ISY also shows the system state as "Cooling" and the subscription system sends a value of 2. I have four (4) thermostats installed, two wired and two wireless. They form up as two sets, each set containing a wired and a wireless thermostat. The wired thermostats are both in the ISY configuration. Neither of the wireless units are in the ISY configuration. As I stated in a previous post, the issue is very confusing with regard to the wireless vs. wired thermostats. The Smarthome staff claims that their Insteon Hub show which thermostat (wired or wireless) is the master. This would be a good thing for the ISY to also show and report upon. Here is a copy of the event log for a short period of time. The thermostat mode is set to cool as opposed to off, heat, or auto. Is there someplace I can learn what some of the fields in the event log mean? e.g. D2D Event. I have removed a bunch of humidity events which appear fairly often in large bursts, but I left one in at the end so you can see what it typically says.. Sat 04/26/2014 08:42:48 AM : [D2D EVENT ] Event [20 44 74 2] [DON] [0] uom=0 prec=-1 Sat 04/26/2014 08:42:48 AM : [ 20 44 74 2] DON 0 Sat 04/26/2014 08:42:48 AM : [D2D EVENT ] Event [20 44 74 2] [sT] [255] uom=0 prec=-1 Sat 04/26/2014 08:42:48 AM : [ 20 44 74 2] ST 255 Sat 04/26/2014 08:42:48 AM : [D2D EVENT ] Event [20 44 74 1] [CLIHCS] [2] uom=0 prec=-1 Sat 04/26/2014 08:42:48 AM : [ 20 44 74 1] CLIHCS 2 Sat 04/26/2014 08:42:48 AM : [D2D EVENT ] Event [20 44 74 2] [DON] [0] uom=0 prec=-1 Sat 04/26/2014 08:42:48 AM : [ 20 44 74 2] DON 0 Sat 04/26/2014 09:05:16 AM : [D2D EVENT ] Event [20 44 74 2] [DOF] [0] uom=0 prec=-1 Sat 04/26/2014 09:05:16 AM : [ 20 44 74 2] DOF 0 Sat 04/26/2014 09:05:16 AM : [D2D EVENT ] Event [20 44 74 2] [sT] [0] uom=0 prec=-1 Sat 04/26/2014 09:05:16 AM : [ 20 44 74 2] ST 0 Sat 04/26/2014 09:05:16 AM : [D2D EVENT ] Event [20 44 74 1] [CLIHCS] [1] uom=0 prec=-1 Sat 04/26/2014 09:05:16 AM : [ 20 44 74 1] CLIHCS 1 Sat 04/26/2014 09:05:17 AM : [D2D EVENT ] Event [20 44 74 2] [DOF] [0] uom=0 prec=-1 Sat 04/26/2014 09:05:17 AM : [ 20 44 74 2] DOF 0 Sat 04/26/2014 09:07:51 AM : [D2D EVENT ] Event [20 44 74 1] [sT] [152] uom=0 prec=-1 Sat 04/26/2014 09:07:51 AM : [ 20 44 74 1] ST 152 Sat 04/26/2014 09:08:15 AM : [D2D EVENT ] Event [24 5 B5 2] [DOF] [0] uom=0 prec=-1 Sat 04/26/2014 09:08:15 AM : [ 24 5 B5 2] DOF 0 Sat 04/26/2014 09:08:15 AM : [D2D EVENT ] Event [24 5 B5 2] [sT] [0] uom=0 prec=-1 Sat 04/26/2014 09:08:15 AM : [ 24 5 B5 2] ST 0 Sat 04/26/2014 09:08:15 AM : [D2D EVENT ] Event [24 5 B5 1] [CLIHCS] [1] uom=0 prec=-1 Sat 04/26/2014 09:08:15 AM : [ 24 5 B5 1] CLIHCS 1 Sat 04/26/2014 09:08:15 AM : [D2D EVENT ] Event [24 5 B5 2] [DOF] [0] uom=0 prec=-1 Sat 04/26/2014 09:08:15 AM : [ 24 5 B5 2] DOF 0 Sat 04/26/2014 09:34:04 AM : [D2D EVENT ] Event [24 5 B5 2] [DON] [0] uom=0 prec=-1 Sat 04/26/2014 09:34:04 AM : [ 24 5 B5 2] DON 0 Sat 04/26/2014 09:34:04 AM : [D2D EVENT ] Event [24 5 B5 2] [sT] [255] uom=0 prec=-1 Sat 04/26/2014 09:34:04 AM : [ 24 5 B5 2] ST 255 Sat 04/26/2014 09:34:04 AM : [D2D EVENT ] Event [24 5 B5 1] [CLIHCS] [2] uom=0 prec=-1 Sat 04/26/2014 09:34:04 AM : [ 24 5 B5 1] CLIHCS 2 Sat 04/26/2014 09:34:04 AM : [D2D EVENT ] Event [24 5 B5 2] [DON] [0] uom=0 prec=-1 Sat 04/26/2014 09:34:04 AM : [ 24 5 B5 2] DON 0 Sat 04/26/2014 09:41:58 AM : [D2D EVENT ] Event [24 5 B5 2] [DOF] [0] uom=0 prec=-1 Sat 04/26/2014 09:41:58 AM : [ 24 5 B5 2] DOF 0 Sat 04/26/2014 09:41:58 AM : [D2D EVENT ] Event [24 5 B5 2] [sT] [0] uom=0 prec=-1 Sat 04/26/2014 09:41:58 AM : [ 24 5 B5 2] ST 0 Sat 04/26/2014 09:41:58 AM : [D2D EVENT ] Event [24 5 B5 1] [CLIHCS] [1] uom=0 prec=-1 Sat 04/26/2014 09:41:58 AM : [ 24 5 B5 1] CLIHCS 1 Sat 04/26/2014 09:41:58 AM : [D2D EVENT ] Event [24 5 B5 2] [DOF] [0] uom=0 prec=-1 Sat 04/26/2014 09:41:58 AM : [ 24 5 B5 2] DOF 0 Sat 04/26/2014 09:45:10 AM : [D2D EVENT ] Event [24 5 B5 1] [CLIHUM] [47] uom=0 prec=-1 Sat 04/26/2014 09:45:10 AM : [ 24 5 B5 1] CLIHUM 47 Link to comment
jamesx0 Posted April 26, 2014 Share Posted April 26, 2014 I'm seeing the same issue with both my Venstar and Insteon thermostats. Sent from my SCH-I605 using Tapatalk Link to comment
LeeG Posted April 26, 2014 Share Posted April 26, 2014 Were the actual Insteon messages not included? UDI has added additional interpretation of each message, D2D for example, of the actual Insteon messages. Some day UDI may explain these additional messages. For now seeing the actual Insteon message from which these additional information messages were generated would be very helpful. Sat 04/26/2014 12:21:15 PM : [iNST-SRX ] 02 50 1D.6C.D6 00.00.01 CB 11 00 LTONRR (00) Sat 04/26/2014 12:21:15 PM : [std-Group ] 1D.6C.D6-->Group=1, Max Hops=3, Hops Left=2 Sat 04/26/2014 12:21:15 PM : [D2D EVENT ] Event [1D 6C D6 2] [DON] [0] uom=0 prec=-1 Sat 04/26/2014 12:21:15 PM : [ 1D 6C D6 2] DON 0 Sat 04/26/2014 12:21:15 PM : [D2D EVENT ] Event [1D 6C D6 2] [sT] [255] uom=0 prec=-1 Sat 04/26/2014 12:21:15 PM : [ 1D 6C D6 2] ST 255 Sat 04/26/2014 12:21:15 PM : [D2D EVENT ] Event [1D 6C D6 1] [CLIHCS] [2] uom=0 prec=-1 Sat 04/26/2014 12:21:15 PM : [ 1D 6C D6 1] CLIHCS 2 Sat 04/26/2014 12:21:16 PM : [iNST-SRX ] 02 50 1D.6C.D6 00.00.01 CB 11 00 LTONRR (00) Sat 04/26/2014 12:21:16 PM : [std-Group ] 1D.6C.D6-->Group=1, Max Hops=3, Hops Left=2 Sat 04/26/2014 12:21:16 PM : [D2D EVENT ] Event [1D 6C D6 2] [DON] [0] uom=0 prec=-1 Sat 04/26/2014 12:21:16 PM : [ 1D 6C D6 2] DON 0 Link to comment
Tunaman Posted April 26, 2014 Share Posted April 26, 2014 I'm seeing similar issues with 4.2.1 (both client and server). Current State is 73, heat setpoint is 60, cool setpoint is 74. Heat/Cool state is shown as Heating -- this is not correct, neither heat or AC are currently on. I see similar behavior in Mobilinc. Link to comment
barrygordon Posted April 26, 2014 Author Share Posted April 26, 2014 Thanks guys; misery loves company!. Hopefully UDI will get this fixed/resolved quickly or recommend I go back to firmware 4.1.2 Tunaman do you have either the PRO or network modules installed? It should be easy enough for me to revert. I am also seeing mismatches on temperature, off by a degree. I am going to revert to 4.1.2. I assume the new modules (Network and PRO) will be unaffected. Lee; are you asking for a full level 3 event log? Link to comment
barrygordon Posted April 26, 2014 Author Share Posted April 26, 2014 Reverting back to firmware 4.1.2 resolved the issue. The ISY now properly reports the system state as cooling. What I really would like to see (perhaps when they fix this issue in 4.2.x) is their being able to send the Master state, i.e. which of a set of wired plus wireless thermostats is the current master The thermostats do pass all the information between them as each shows which is Master and the temperature of the other unit. That is the wired thermostat will show the temperature of the wireless unit and Vice versa. I guess the issue may be the PLM which may not be putting that info on the Ethernet port so the ISY can get it. Anybody know for sure? As I said the Smarthome people have indicated that their HUB knows which is master so at least that should be able to be picked up by the ISY. It would really be nice if all the data were available in the ISY and broadcast as it changed. Link to comment
Tunaman Posted April 26, 2014 Share Posted April 26, 2014 I have pro version, with network module installed. Sent from my Nexus 7 using Tapatalk Link to comment
barrygordon Posted April 26, 2014 Author Share Posted April 26, 2014 I guess 4.2.1 has a few bugs, that is why it is beta. Link to comment
LeeG Posted April 26, 2014 Share Posted April 26, 2014 The earlier post only has the interpretation of an Insteon message without the actual Insteon message itself. To understand what the D2D EVENT lines indicate for example the Insteon message they are analyzing is needed. Below the DON is simply interpreting the ON command (11) code in the Insteon message. The Heat/Cool State (CLIHCS 2) indicates Cool State if my memory is correct. The various thermostat values (CLIHCS) can be found in this WIKI section. http://wiki.universal-devices.com/index ... _Variables The "uom=0 prec=-1" are new interpretations that UDI has recently added to the LEVEL 3 trace. I could guess that uom= is Unit of Measure maybe, the prec= is Precision maybe. These I have not seen any doc as to what they actually mean being they are new. There are new D2D CMP lines that interpret a Program trigger from the Insteon message Sat 04/26/2014 05:51:44 PM : [D2D-CMP 004F] CTL [11 B6 BC 1] DOF op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Trying to evaluate the interpretations without the original Insteon message is difficult. The previous message is a Program trigger showing Program ID (004F), type of trigger (CTL = Control), etc. Without looking at the Program itself it is more difficult to evaluate what the information being presented actually means.l Sat 04/26/2014 12:21:15 PM : [iNST-SRX ] 02 50 1D.6C.D6 00.00.01 CB 11 00 LTONRR (00) Sat 04/26/2014 12:21:15 PM : [std-Group ] 1D.6C.D6-->Group=1, Max Hops=3, Hops Left=2 Sat 04/26/2014 12:21:15 PM : [D2D EVENT ] Event [1D 6C D6 2] [DON] [0] uom=0 prec=-1 Sat 04/26/2014 12:21:15 PM : [ 1D 6C D6 2] DON 0 Sat 04/26/2014 12:21:15 PM : [D2D EVENT ] Event [1D 6C D6 2] [sT] [255] uom=0 prec=-1 Sat 04/26/2014 12:21:15 PM : [ 1D 6C D6 2] ST 255 Sat 04/26/2014 12:21:15 PM : [D2D EVENT ] Event [1D 6C D6 1] [CLIHCS] [2] uom=0 prec=-1 Sat 04/26/2014 12:21:15 PM : [ 1D 6C D6 1] CLIHCS 2 To get an accurate evaluation of the D2D EVENTs the Insteon message that generated those messages would be helpful Link to comment
barrygordon Posted April 26, 2014 Author Share Posted April 26, 2014 LeeG I think I understand it a bit better. I will do a full level 3 trace and send it to you tomorrow.I will also look at the wiki. Thanks for your assistance I just looked at the wiki you mentioned and I knew all of those variables in the main section from my work writing an ISY driver/interface for the iPad using the CommandFusion iViewersystem. Link to comment
MaddBomber83 Posted April 28, 2014 Share Posted April 28, 2014 I'm have the same issue on 4.2.2 Below I have several logs and programs / status changes. The short version is as follows: 25.17.5C.1 CLIHCS Value = 0 (Not Calling for Anything) 25.17.5C.1 CLIHCS Value = 1 (Calling for Heat) 25.17.5C.1 CLIHCS Value = 2 (Calling for Cool) 25.17.5C.2 Cooling Controller 25.17.5C.3 Heating Controller Problem 1: Heating should change the status of node 3 and change the value of node 1 to 1. Heating ONLY changes the status of node 3 and does not change anything on node 1. Problem 2: When no heating / cooling is present, node 1 should change to a value of 0, right now it changes to 1. Note 3: Cooling appear to be functioning correctly. It changes the status of node 2, and the value of node 1 to 2. --------------------------------------------------------------- Please note I have several programs not filtered in code that changes the state of the Fan from Auto to On. Starting Conditions: Setpoints: 67 Heat, 75 Cool State: 71.5 Cool - Ctl: Off Heat - Ctl: Not Displayed ISY Heat/Cool State: Heat On (This is what is wrong) 25.17.5C Changed Cooling SP to 70: Setpoints: 67 Heat, 70 Cool State: 71.5 Cool - Ctl: On Heat - Ctl: Not Displayed ISY Heat/Cool State: Cool On Mon 04/28/2014 03:01:42 PM : [ Time] 15:01:43 2(0) Mon 04/28/2014 03:01:45 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6C 8C 00 00 00 00 00 00 00 00 00 00 00 00 00 08 Mon 04/28/2014 03:01:45 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6C 8C 00 00 00 00 00 00 00 00 00 00 00 00 00 08 06 (8C) Mon 04/28/2014 03:01:45 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6C 8C (8C) Mon 04/28/2014 03:01:45 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:45 PM : [D2D EVENT ] Event [25 17 5C 1] [CLISPC] [140] uom=0 prec=-1 Mon 04/28/2014 03:01:45 PM : [ 25 17 5C 1] CLISPC 140 Mon 04/28/2014 03:01:46 PM : [D2D-CMP 0036] STS [25 17 5C 1] CLISPC op=1 Event(val=140 uom=0 prec=-1) is Condition(val=140 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:46 PM : [VAR 2 9 ] 70 Mon 04/28/2014 03:01:47 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.01 CB 11 00 LTONRR (00) Mon 04/28/2014 03:01:47 PM : [std-Group ] 25.17.5C-->Group=1, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:47 PM : [D2D EVENT ] Event [25 17 5C 2] [DON] [0] uom=0 prec=-1 Mon 04/28/2014 03:01:47 PM : [ 25 17 5C 2] DON 0 Mon 04/28/2014 03:01:47 PM : [D2D EVENT ] Event [25 17 5C 2] [sT] [255] uom=0 prec=-1 Mon 04/28/2014 03:01:47 PM : [ 25 17 5C 2] ST 255 Mon 04/28/2014 03:01:47 PM : [D2D-CMP 0075] STS [25 17 5C 2] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:47 PM : [D2D-CMP 007C] STS [25 17 5C 2] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:47 PM : [D2D-CMP 000F] STS [25 17 5C 2] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:47 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.01 CB 11 00 LTONRR (00) Mon 04/28/2014 03:01:47 PM : [std-Group ] 25.17.5C-->Group=1, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:47 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 40 11 01 LTONRR (01) Mon 04/28/2014 03:01:47 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Mon 04/28/2014 03:01:47 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:01:47 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 41 11 01 LTONRR (01) Mon 04/28/2014 03:01:47 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:01:47 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:01:48 PM : [iNST-SRX ] 02 50 25.17.5C 11.01.01 C7 06 00 (00) Mon 04/28/2014 03:01:48 PM : [std-Group ] 25.17.5C-->11.01.01, Max Hops=3, Hops Left=1 Mon 04/28/2014 03:01:48 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:01:48 PM : [iNST-SRX ] 02 50 25.17.5C 11.01.01 CB 06 00 (00) Mon 04/28/2014 03:01:48 PM : [std-Group ] 25.17.5C-->11.01.01, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:48 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:01:48 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 41 07 Mon 04/28/2014 03:01:48 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D Mon 04/28/2014 03:01:48 PM : [iNST-ACK ] 02 62 28.AA.98 0F 41 07 06 (07) Mon 04/28/2014 03:01:48 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 41 07 (07) Mon 04/28/2014 03:01:48 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:49 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D 06 (08) Mon 04/28/2014 03:01:49 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6B 08 (08) Mon 04/28/2014 03:01:49 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:49 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIHCS] [2] uom=0 prec=-1 Mon 04/28/2014 03:01:49 PM : [ 25 17 5C 1] CLIHCS 2 Mon 04/28/2014 03:01:49 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=2 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:49 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=2 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:49 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=2 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:49 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=2 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:49 PM : [D2D-CMP 0089] STS [25 17 5C 1] CLIHCS op=1 Event(val=2 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:49 PM : [D2D-CMP 0042] STS [25 17 5C 1] CLIHCS op=1 Event(val=2 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:49 PM : [D2D-CMP 000D] STS [25 17 5C 1] CLIHCS op=1 Event(val=2 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:49 PM : [D2D EVENT ] Event [25 17 5C 2] [DON] [0] uom=0 prec=-1 Mon 04/28/2014 03:01:49 PM : [ 25 17 5C 2] DON 0 Mon 04/28/2014 03:01:49 PM : [D2D EVENT ] Event [28 AA 98 8] [sT] [0] uom=0 prec=-1 Mon 04/28/2014 03:01:50 PM : [ 28 AA 98 8] ST 0 Mon 04/28/2014 03:01:50 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:50 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:50 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 41 07 Mon 04/28/2014 03:01:50 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIFS] [8] uom=0 prec=-1 Mon 04/28/2014 03:01:50 PM : [ 25 17 5C 1] CLIFS 8 Mon 04/28/2014 03:01:50 PM : [D2D-CMP 0075] STS [25 17 5C 1] CLIFS op=1 Event(val=8 uom=0 prec=-1) is Condition(val=7 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:50 PM : [iNST-ACK ] 02 62 28.AA.98 0F 41 07 06 (07) Mon 04/28/2014 03:01:50 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIFS op=1 Event(val=8 uom=0 prec=-1) is Condition(val=7 uom=0 prec=-1) --> false Mon 04/28/2014 03:01:50 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIFS op=1 Event(val=8 uom=0 prec=-1) is Condition(val=8 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:50 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 41 07 (07) Mon 04/28/2014 03:01:50 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:51 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 41 07 Mon 04/28/2014 03:01:51 PM : [VAR 2 11 ] 1 Mon 04/28/2014 03:01:51 PM : [iNST-ACK ] 02 62 28.AA.98 0F 41 07 06 (07) Mon 04/28/2014 03:01:51 PM : [VAR 2 10 ] 0 Mon 04/28/2014 03:01:51 PM : CLI-WBug: Connecting to datafeed.weatherbug.com Mon 04/28/2014 03:01:51 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 41 07 (07) Mon 04/28/2014 03:01:51 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:51 PM : CLI-WBug: Successfully Processed WBug Response Mon 04/28/2014 03:01:51 PM : FYP: Connecting to http://flexyourpower.s3.amazonaws.com/banners/status.xml Mon 04/28/2014 03:01:51 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 01 71 46 (46) Mon 04/28/2014 03:01:51 PM : [std-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:01:51 PM : [ZWAVE-TX ] ACK Mon 04/28/2014 03:01:52 PM : [ZWAVE-RX ZW008_1] [0114000400080E32]... Mon 04/28/2014 03:01:52 PM : [ZWAVE-TX ] ACK Mon 04/28/2014 03:01:52 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 01 70 03 (03) Mon 04/28/2014 03:01:52 PM : [std-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:01:52 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 Mon 04/28/2014 03:01:52 PM : [iNST-ACK ] 02 62 25.17.5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06 (02) Mon 04/28/2014 03:01:53 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 2E 02 (02) Mon 04/28/2014 03:01:53 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:01:53 PM : [iNST-ERX ] 02 51 25 17 5C 22 FF 06 11 2E 02 01 02 0C 22 1E 10 46 29 00 E1 A1 43 4E FB Mon 04/28/2014 03:01:53 PM : [Ext-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:01:53 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIHUM] [41] uom=0 prec=-1 Mon 04/28/2014 03:01:53 PM : [ 25 17 5C 1] CLIHUM 41 Mon 04/28/2014 03:01:53 PM : [D2D-CMP 0021] STS [25 17 5C 1] CLIHUM op=2 Event(val=41 uom=0 prec=-1) < Condition(val=50 uom=0 prec=-1) --> true Mon 04/28/2014 03:01:53 PM : [ Time] 15:01:54 2(0) Mon 04/28/2014 03:01:54 PM : [ Time] 15:01:55 2(0) Mon 04/28/2014 03:01:54 PM : [iNST-TX-I1 ] 02 62 00 00 1A CF 11 00 Mon 04/28/2014 03:01:54 PM : [iNST-ACK ] 02 62 00.00.1A CF 11 00 06 LTONRR (00) Mon 04/28/2014 03:02:00 PM : [ Time] 15:02:00 2(0) Changed Cooling SP back to 75: Setpoints: 67 Heat, 75 Cool State: 71.5 Cool - Ctl: Off Heat - Ctl: Not Displayed ISY Heat/Cool State: Heat On (This is what is wrong) Mon 04/28/2014 03:02:07 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6C 96 00 00 00 00 00 00 00 00 00 00 00 00 00 FE Mon 04/28/2014 03:02:07 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6C 96 00 00 00 00 00 00 00 00 00 00 00 00 00 FE 06 (96) Mon 04/28/2014 03:02:07 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6C 96 (96) Mon 04/28/2014 03:02:07 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:07 PM : [D2D EVENT ] Event [25 17 5C 1] [CLISPC] [150] uom=0 prec=-1 Mon 04/28/2014 03:02:07 PM : [ 25 17 5C 1] CLISPC 150 Mon 04/28/2014 03:02:07 PM : [D2D-CMP 003B] STS [25 17 5C 1] CLISPC op=1 Event(val=150 uom=0 prec=-1) is Condition(val=150 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:07 PM : [VAR 2 9 ] 75 Mon 04/28/2014 03:02:09 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.01 CB 13 00 LTOFFRR(00) Mon 04/28/2014 03:02:09 PM : [std-Group ] 25.17.5C-->Group=1, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:09 PM : [D2D EVENT ] Event [25 17 5C 2] [DOF] [0] uom=0 prec=-1 Mon 04/28/2014 03:02:09 PM : [ 25 17 5C 2] DOF 0 Mon 04/28/2014 03:02:09 PM : [D2D EVENT ] Event [25 17 5C 2] [sT] [0] uom=0 prec=-1 Mon 04/28/2014 03:02:09 PM : [ 25 17 5C 2] ST 0 Mon 04/28/2014 03:02:09 PM : [D2D-CMP 0075] STS [25 17 5C 2] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:09 PM : [D2D-CMP 007C] STS [25 17 5C 2] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:09 PM : [D2D-CMP 000F] STS [25 17 5C 2] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:02:09 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.01 CB 13 00 LTOFFRR(00) Mon 04/28/2014 03:02:09 PM : [std-Group ] 25.17.5C-->Group=1, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:09 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 40 13 01 LTOFFRR(01) Mon 04/28/2014 03:02:09 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Mon 04/28/2014 03:02:09 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:02:09 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 41 13 01 LTOFFRR(01) Mon 04/28/2014 03:02:09 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:02:09 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:02:09 PM : [iNST-SRX ] 02 50 25.17.5C 13.01.01 C7 06 00 (00) Mon 04/28/2014 03:02:09 PM : [std-Group ] 25.17.5C-->13.01.01, Max Hops=3, Hops Left=1 Mon 04/28/2014 03:02:09 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:02:10 PM : [iNST-SRX ] 02 50 25.17.5C 13.01.01 CB 06 00 (00) Mon 04/28/2014 03:02:10 PM : [std-Group ] 25.17.5C-->13.01.01, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:10 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:02:10 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 41 07 Mon 04/28/2014 03:02:10 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6B 07 00 00 00 00 00 00 00 00 00 00 00 00 00 8E Mon 04/28/2014 03:02:10 PM : [iNST-ACK ] 02 62 28.AA.98 0F 41 07 06 (07) Mon 04/28/2014 03:02:10 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 41 07 (07) Mon 04/28/2014 03:02:10 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:11 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6B 07 00 00 00 00 00 00 00 00 00 00 00 00 00 8E 06 (07) Mon 04/28/2014 03:02:11 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 23 41 07 (07) Mon 04/28/2014 03:02:11 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Mon 04/28/2014 03:02:11 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 23 41 07 (07) Mon 04/28/2014 03:02:11 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Mon 04/28/2014 03:02:11 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6B 07 (07) Mon 04/28/2014 03:02:11 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:11 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIHCS] [1] uom=0 prec=-1 Mon 04/28/2014 03:02:11 PM : [ 25 17 5C 1] CLIHCS 1 Mon 04/28/2014 03:02:11 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:02:11 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:11 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:02:11 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:11 PM : [D2D-CMP 0089] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:11 PM : [D2D-CMP 0042] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:02:11 PM : [D2D-CMP 000D] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:02:11 PM : [D2D EVENT ] Event [25 17 5C 2] [DOF] [0] uom=0 prec=-1 Mon 04/28/2014 03:02:11 PM : [ 25 17 5C 2] DOF 0 Mon 04/28/2014 03:02:11 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIFS] [7] uom=0 prec=-1 Mon 04/28/2014 03:02:11 PM : [ 25 17 5C 1] CLIFS 7 Mon 04/28/2014 03:02:11 PM : [D2D-CMP 0075] STS [25 17 5C 1] CLIFS op=1 Event(val=7 uom=0 prec=-1) is Condition(val=7 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:11 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIFS op=1 Event(val=7 uom=0 prec=-1) is Condition(val=7 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:11 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIFS op=1 Event(val=7 uom=0 prec=-1) is Condition(val=8 uom=0 prec=-1) --> false Mon 04/28/2014 03:02:12 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 40 07 Mon 04/28/2014 03:02:12 PM : [VAR 2 11 ] 0 Mon 04/28/2014 03:02:12 PM : [iNST-ACK ] 02 62 28.AA.98 0F 40 07 06 (07) Mon 04/28/2014 03:02:12 PM : [VAR 2 10 ] 1 Mon 04/28/2014 03:02:12 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 40 87 (87) Mon 04/28/2014 03:02:12 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:12 PM : [D2D EVENT ] Event [28 AA 98 8] [sT] [255] uom=0 prec=-1 Mon 04/28/2014 03:02:12 PM : [ 28 AA 98 8] ST 255 Mon 04/28/2014 03:02:12 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Mon 04/28/2014 03:02:12 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:02:12 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 40 07 Mon 04/28/2014 03:02:12 PM : [iNST-ACK ] 02 62 28.AA.98 0F 40 07 06 (07) Mon 04/28/2014 03:02:13 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 40 87 (87) Mon 04/28/2014 03:02:13 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:13 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 01 71 4B (4B) Mon 04/28/2014 03:02:13 PM : [std-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:02:14 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 01 70 13 (13) Mon 04/28/2014 03:02:14 PM : [std-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:02:14 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 Mon 04/28/2014 03:02:14 PM : [iNST-ACK ] 02 62 25.17.5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06 (02) Mon 04/28/2014 03:02:14 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 2E 02 (02) Mon 04/28/2014 03:02:14 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:02:15 PM : [iNST-ERX ] 02 51 25 17 5C 22 FF 06 11 2E 02 01 02 0C 22 34 11 4B 29 00 E1 A0 43 C3 0A Mon 04/28/2014 03:02:15 PM : [Ext-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Changed Heating SP to 75, Cooling SP to 78: Setpoints: 73 Heat, 78 Cool State: 73.0 Cool - Ctl: Off Heat - Ctl: On ISY Heat/Cool State: Heat On (This is now right) Mon 04/28/2014 03:20:11 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6D 96 00 00 00 00 00 00 00 00 00 00 00 00 00 FD Mon 04/28/2014 03:20:11 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6D 96 00 00 00 00 00 00 00 00 00 00 00 00 00 FD 06 (96) Mon 04/28/2014 03:20:11 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6D 96 (96) Mon 04/28/2014 03:20:11 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:11 PM : [D2D EVENT ] Event [25 17 5C 1] [CLISPH] [150] uom=0 prec=-1 Mon 04/28/2014 03:20:11 PM : [ 25 17 5C 1] CLISPH 150 Mon 04/28/2014 03:20:12 PM : [D2D-CMP 009F] STS [25 17 5C 1] CLISPH op=1 Event(val=150 uom=0 prec=-1) is Condition(val=150 uom=0 prec=-1) --> true Mon 04/28/2014 03:20:12 PM : [VAR 2 14 ] 75 Mon 04/28/2014 03:20:13 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.02 CB 11 00 LTONRR (00) Mon 04/28/2014 03:20:13 PM : [std-Group ] 25.17.5C-->Group=2, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:13 PM : [D2D EVENT ] Event [25 17 5C 3] [DON] [0] uom=0 prec=-1 Mon 04/28/2014 03:20:13 PM : [ 25 17 5C 3] DON 0 Mon 04/28/2014 03:20:13 PM : [D2D EVENT ] Event [25 17 5C 3] [sT] [255] uom=0 prec=-1 Mon 04/28/2014 03:20:13 PM : [ 25 17 5C 3] ST 255 Mon 04/28/2014 03:20:13 PM : [D2D-CMP 0075] STS [25 17 5C 3] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:13 PM : [D2D-CMP 007C] STS [25 17 5C 3] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:13 PM : [D2D-CMP 000F] STS [25 17 5C 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:20:13 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.02 CB 11 00 LTONRR (00) Mon 04/28/2014 03:20:13 PM : [std-Group ] 25.17.5C-->Group=2, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:13 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 40 11 02 LTONRR (02) Mon 04/28/2014 03:20:13 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=2, Max Hops=0, Hops Left=0 Mon 04/28/2014 03:20:13 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:20:13 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 41 11 02 LTONRR (02) Mon 04/28/2014 03:20:13 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=2, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:20:13 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:20:14 PM : [iNST-SRX ] 02 50 25.17.5C 11.01.02 CB 06 00 (00) Mon 04/28/2014 03:20:14 PM : [std-Group ] 25.17.5C-->11.01.02, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:14 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:20:14 PM : [iNST-SRX ] 02 50 25.17.5C 11.01.02 CB 06 00 (00) Mon 04/28/2014 03:20:14 PM : [std-Group ] 25.17.5C-->11.01.02, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:14 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:20:14 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 41 07 Mon 04/28/2014 03:20:14 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D Mon 04/28/2014 03:20:14 PM : [iNST-ACK ] 02 62 28.AA.98 0F 41 07 06 (07) Mon 04/28/2014 03:20:15 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D 06 (08) Mon 04/28/2014 03:20:15 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 41 07 (07) Mon 04/28/2014 03:20:15 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:16 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6B 08 (08) Mon 04/28/2014 03:20:16 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:16 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIHCS] [1] uom=0 prec=-1 Mon 04/28/2014 03:20:16 PM : [ 25 17 5C 1] CLIHCS 1 Mon 04/28/2014 03:20:16 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:16 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:20:16 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:16 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:20:16 PM : [D2D-CMP 0089] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> true Mon 04/28/2014 03:20:16 PM : [D2D-CMP 0042] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:16 PM : [D2D-CMP 000D] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:16 PM : [D2D EVENT ] Event [25 17 5C 3] [DON] [0] uom=0 prec=-1 Mon 04/28/2014 03:20:16 PM : [ 25 17 5C 3] DON 0 Mon 04/28/2014 03:20:16 PM : [D2D EVENT ] Event [28 AA 98 8] [sT] [0] uom=0 prec=-1 Mon 04/28/2014 03:20:16 PM : [ 28 AA 98 8] ST 0 Mon 04/28/2014 03:20:16 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Mon 04/28/2014 03:20:16 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:16 PM : [ZWAVE-RX ZW008_1] [0114000400080E32]... Mon 04/28/2014 03:20:16 PM : [ZWAVE-TX ] ACK Mon 04/28/2014 03:20:16 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 41 07 Mon 04/28/2014 03:20:16 PM : [iNST-ACK ] 02 62 28.AA.98 0F 41 07 06 (07) Mon 04/28/2014 03:20:16 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIFS] [8] uom=0 prec=-1 Mon 04/28/2014 03:20:16 PM : [ 25 17 5C 1] CLIFS 8 Mon 04/28/2014 03:20:16 PM : [D2D-CMP 0075] STS [25 17 5C 1] CLIFS op=1 Event(val=8 uom=0 prec=-1) is Condition(val=7 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:16 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIFS op=1 Event(val=8 uom=0 prec=-1) is Condition(val=7 uom=0 prec=-1) --> false Mon 04/28/2014 03:20:16 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIFS op=1 Event(val=8 uom=0 prec=-1) is Condition(val=8 uom=0 prec=-1) --> true Mon 04/28/2014 03:20:17 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 41 07 (07) Mon 04/28/2014 03:20:17 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:17 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 01 72 4B (4B) Mon 04/28/2014 03:20:17 PM : [std-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:20:17 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 41 07 Mon 04/28/2014 03:20:17 PM : [iNST-ACK ] 02 62 28.AA.98 0F 41 07 06 (07) Mon 04/28/2014 03:20:18 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 27 41 07 (07) Mon 04/28/2014 03:20:18 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Mon 04/28/2014 03:20:18 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 07 70 03 (03) Mon 04/28/2014 03:20:18 PM : [std-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Mon 04/28/2014 03:20:18 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 Mon 04/28/2014 03:20:18 PM : [iNST-ACK ] 02 62 25.17.5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06 (02) Mon 04/28/2014 03:20:19 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 2E 02 (02) Mon 04/28/2014 03:20:19 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:20:20 PM : [iNST-ERX ] 02 51 25 17 5C 22 FF 06 11 2E 02 01 02 0C 34 3A 10 4E 29 00 E1 A2 4B D9 D5 Mon 04/28/2014 03:20:20 PM : [Ext-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Returned Heating SP to 70: Setpoints: 70 Heat, 78 Cool State: 73.0 Cool - Ctl: Off Heat - Ctl: Off ISY Heat/Cool State: Heat On (Back to Wrong) Mon 04/28/2014 03:21:15 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6D 8C 00 00 00 00 00 00 00 00 00 00 00 00 00 07 Mon 04/28/2014 03:21:15 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6D 8C 00 00 00 00 00 00 00 00 00 00 00 00 00 07 06 (8C) Mon 04/28/2014 03:21:16 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6D 8C (8C) Mon 04/28/2014 03:21:16 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:16 PM : [D2D EVENT ] Event [25 17 5C 1] [CLISPH] [140] uom=0 prec=-1 Mon 04/28/2014 03:21:16 PM : [ 25 17 5C 1] CLISPH 140 Mon 04/28/2014 03:21:16 PM : [D2D-CMP 009A] STS [25 17 5C 1] CLISPH op=1 Event(val=140 uom=0 prec=-1) is Condition(val=140 uom=0 prec=-1) --> true Mon 04/28/2014 03:21:16 PM : [VAR 2 14 ] 70 Mon 04/28/2014 03:21:17 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.02 CB 13 00 LTOFFRR(00) Mon 04/28/2014 03:21:17 PM : [std-Group ] 25.17.5C-->Group=2, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:17 PM : [D2D EVENT ] Event [25 17 5C 3] [DOF] [0] uom=0 prec=-1 Mon 04/28/2014 03:21:17 PM : [ 25 17 5C 3] DOF 0 Mon 04/28/2014 03:21:17 PM : [D2D EVENT ] Event [25 17 5C 3] [sT] [0] uom=0 prec=-1 Mon 04/28/2014 03:21:17 PM : [ 25 17 5C 3] ST 0 Mon 04/28/2014 03:21:17 PM : [D2D-CMP 0075] STS [25 17 5C 3] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:21:17 PM : [D2D-CMP 007C] STS [25 17 5C 3] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:21:17 PM : [D2D-CMP 000F] STS [25 17 5C 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:21:17 PM : [iNST-SRX ] 02 50 25.17.5C 00.00.02 CB 13 00 LTOFFRR(00) Mon 04/28/2014 03:21:17 PM : [std-Group ] 25.17.5C-->Group=2, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:17 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 40 13 02 LTOFFRR(02) Mon 04/28/2014 03:21:17 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=2, Max Hops=0, Hops Left=0 Mon 04/28/2014 03:21:17 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:21:18 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 41 13 02 LTOFFRR(02) Mon 04/28/2014 03:21:18 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=2, Max Hops=1, Hops Left=0 Mon 04/28/2014 03:21:18 PM : [iNST-DUP ] Previous message ignored. Mon 04/28/2014 03:21:18 PM : [iNST-SRX ] 02 50 25.17.5C 13.01.02 CB 06 00 (00) Mon 04/28/2014 03:21:18 PM : [std-Group ] 25.17.5C-->13.01.02, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:18 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:21:18 PM : [iNST-SRX ] 02 50 25.17.5C 13.01.02 CB 06 00 (00) Mon 04/28/2014 03:21:18 PM : [std-Group ] 25.17.5C-->13.01.02, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:18 PM : [iNST-INFO ] Previous message ignored. Mon 04/28/2014 03:21:19 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 40 07 Mon 04/28/2014 03:21:19 PM : [iNST-ACK ] 02 62 28.AA.98 0F 40 07 06 (07) Mon 04/28/2014 03:21:19 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 40 87 (87) Mon 04/28/2014 03:21:19 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:19 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6B 07 00 00 00 00 00 00 00 00 00 00 00 00 00 8E Mon 04/28/2014 03:21:19 PM : [iNST-ACK ] 02 62 25.17.5C 1F 6B 07 00 00 00 00 00 00 00 00 00 00 00 00 00 8E 06 (07) Mon 04/28/2014 03:21:20 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 2B 6B 07 (07) Mon 04/28/2014 03:21:20 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:20 PM : [D2D EVENT ] Event [25 17 5C 1] [CLIHCS] [1] uom=0 prec=-1 Mon 04/28/2014 03:21:20 PM : [ 25 17 5C 1] CLIHCS 1 Mon 04/28/2014 03:21:20 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:21:20 PM : [D2D-CMP 008A] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:21:20 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:21:20 PM : [D2D-CMP 008B] STS [25 17 5C 1] CLIHCS op=6 Event(val=1 uom=0 prec=-1) != Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 03:21:20 PM : [D2D-CMP 0089] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> true Mon 04/28/2014 03:21:20 PM : [D2D-CMP 0042] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:21:20 PM : [D2D-CMP 000D] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:21:20 PM : [D2D EVENT ] Event [25 17 5C 3] [DOF] [0] uom=0 prec=-1 Mon 04/28/2014 03:21:20 PM : [ 25 17 5C 3] DOF 0 Mon 04/28/2014 03:21:20 PM : [D2D EVENT ] Event [28 AA 98 8] [sT] [255] uom=0 prec=-1 Mon 04/28/2014 03:21:20 PM : [ 28 AA 98 8] ST 255 Mon 04/28/2014 03:21:20 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Mon 04/28/2014 03:21:20 PM : [D2D-CMP 0075] STS [28 AA 98 8] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:21:20 PM : [iNST-TX-I1 ] 02 62 28 AA 98 0F 40 07 Mon 04/28/2014 03:21:20 PM : [iNST-ACK ] 02 62 28.AA.98 0F 40 07 06 (07) Mon 04/28/2014 03:21:21 PM : [iNST-SRX ] 02 50 28.AA.98 22.FF.06 2B 40 87 (87) Mon 04/28/2014 03:21:21 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 04/28/2014 03:21:21 PM : [iNST-SRX ] 02 50 25.17.5C 22.FF.06 01 72 46 (46) Mon 04/28/2014 03:21:21 PM : [std-Direct ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Link to comment
MaddBomber83 Posted April 28, 2014 Share Posted April 28, 2014 Also note, as a result of this I have had to change a few programs from using Is Calling For Nothing/Heat/Cool to Status CTRL Heat/Cool On/Off. Next up for testing, I've created the following program: If Status 'Main - Thermostat' is Calling for Cool And Status 'Main - Thermostat / Main - Cool Ctl' is On And Status 'Main - Thermostat' is Calling for Nothing And Status 'Main - Thermostat' is Calling for Heat And Status 'Main - Thermostat / Main - Heat Ctl' is On When I save the program: Cooling On Mon 04/28/2014 03:39:12 PM : [D2D-CMP 0072] INI [] op=1 Event(val=0 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:39:12 PM : [D2D-CMP 0072] INI [] op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 03:39:12 PM : [D2D-CMP 0072] INI [] op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Mon 04/28/2014 03:39:12 PM : [D2D-CMP 0072] INI [] op=1 Event(val=0 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> false Mon 04/28/2014 03:39:12 PM : [D2D-CMP 0072] INI [] op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Cooling and Heating Off Mon 04/28/2014 03:43:06 PM : [D2D-CMP 0072] INI [] op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:43:06 PM : [D2D-CMP 0072] INI [] op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:43:06 PM : [D2D-CMP 0072] INI [] op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Mon 04/28/2014 03:43:06 PM : [D2D-CMP 0072] INI [] op=1 Event(val=1 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> true Mon 04/28/2014 03:43:06 PM : [D2D-CMP 0072] INI [] op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Heating On Mon 04/28/2014 03:44:22 PM : [D2D-CMP 0072] INI [] op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 03:44:22 PM : [D2D-CMP 0072] INI [] op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 03:44:22 PM : [D2D-CMP 0072] INI [] op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Mon 04/28/2014 03:44:22 PM : [D2D-CMP 0072] INI [] op=1 Event(val=1 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> true Mon 04/28/2014 03:44:22 PM : [D2D-CMP 0072] INI [] op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Link to comment
MaddBomber83 Posted April 28, 2014 Share Posted April 28, 2014 So a few things that the test program points out. Condition 1: Calling for Cool Condition 2: Cooling Control On Condition 3: Calling for Nothing Condition 4: Calling for Heat Condition 5: Heating Control On When I am COOLING: Condition 1 should be TRUE, it is not Condition 2 should be TRUE, it is Condition 3 should be FALSE, it is not Condition 4 should be FALSE, it is Condition 5 should be FALSE, it is When I am not COOLING and not HEATING: Condition 1 should be FALSE, it is Condition 2 should be FALSE, it is Condition 3 should be TRUE, it is not Condition 4 should be FALSE, it is not Condition 5 should be FALSE, it is When I am HEATING: Condition 1 should be FALSE, it is Condition 2 should be FALSE, it is Condition 3 should be FALSE, it is Condition 4 should be TRUE, it is Condition 5 should be TRUE, it is Link to comment
MaddBomber83 Posted April 28, 2014 Share Posted April 28, 2014 Now with Program 0072 having our status, a filtered event list (Level 2) for changing states is as follows: Starting Condition is: Cool: OFF Heat: OFF Cool: ON Heat: OFF Mon 04/28/2014 04:06:00 PM : [D2D-CMP 0072] STS [25 17 5C 2] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Mon 04/28/2014 04:06:04 PM : [D2D-CMP 0072] STS [25 17 5C 1] CLIHCS op=1 Event(val=2 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> true Mon 04/28/2014 04:06:04 PM : [D2D-CMP 0072] STS [25 17 5C 1] CLIHCS op=1 Event(val=2 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Mon 04/28/2014 04:06:04 PM : [D2D-CMP 0072] STS [25 17 5C 1] CLIHCS op=1 Event(val=2 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> false Cool: OFF Heat: OFF Mon 04/28/2014 04:07:51 PM : [D2D-CMP 0072] STS [25 17 5C 2] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 04/28/2014 04:08:05 PM : [D2D-CMP 0072] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=2 uom=0 prec=-1) --> false Mon 04/28/2014 04:08:05 PM : [D2D-CMP 0072] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Mon 04/28/2014 04:08:05 PM : [D2D-CMP 0072] STS [25 17 5C 1] CLIHCS op=1 Event(val=1 uom=0 prec=-1) is Condition(val=1 uom=0 prec=-1) --> true Cool: OFF Heat: ON Mon 04/28/2014 04:09:52 PM : [D2D-CMP 0072] STS [25 17 5C 3] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Cool: OFF Heat: OFF Mon 04/28/2014 04:12:27 PM : [D2D-CMP 0072] STS [25 17 5C 3] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Link to comment
MaddBomber83 Posted April 28, 2014 Share Posted April 28, 2014 So we have 3 nodes. 25.17.5C.1 CLIHCS Value = 0 (Not Calling for Anything) 25.17.5C.1 CLIHCS Value = 1 (Calling for Heat) 25.17.5C.1 CLIHCS Value = 2 (Calling for Cool) 25.17.5C.2 Cooling Controller 25.17.5C.3 Heating Controller Problem 1: Heating should change the status of node 3 and change the value of node 1 to 1. Heating ONLY changes the status of node 3 and does not change anything on node 1. Problem 2: When no heating / cooling is present, node 1 should change to a value of 0, right now it changes to 1. Note 3: Cooling appear to be functioning correctly. It changes the status of node 2, and the value of node 1 to 2. Link to comment
Michel Kohanim Posted April 29, 2014 Share Posted April 29, 2014 Hello maddbomber83, Thanks so very much for the details. We are looking into it! With kind regards, Michel Link to comment
andyf0 Posted April 29, 2014 Share Posted April 29, 2014 Add me to list of folks who's ISY is reporting Heat On after the AC is turned off. Link to comment
barrygordon Posted April 29, 2014 Author Share Posted April 29, 2014 Could you please state the version of the ISY firmware you are using. Link to comment
andyf0 Posted April 29, 2014 Share Posted April 29, 2014 Could you please state the version of the ISY firmware you are using. I'm running 4.2.2. Firmware & UI. For me it's a display issue. My programs and scenes use the Heat & Cool nodes which don't seem to be affected, but then I'm not running the heating anymore. Link to comment
