Watchdog
cslee
Does ISY have any watchdog built-in which can reset the PLM is it's no longer responsive? Several times now I have to unplug the PLM and it's no longer working....
Usually prior to it dying I see devices with no status "On/Off" in the "devices" page.
If ISY can reset the PLM, it will be a great feature to ensure reliability.
How old is your PLM? What version? If it's locking up, you might consider calling SmartHome and having them replace it under warranty. It should not be locking up under normal use.
That is a fairly current version (though I have seen a v2.8). In any case, it shouldn't be locking up. I would consider calling SmartHome for a warranty replacement.
cslee,
Please do be kind enough to replace your PLM. Also, I am sure this is a new PLM, as such I must ask if followed the replacement with File->Restore PLM (Modem)?
My PLM version is 2.75
