Install IOLINC and Foscam FI9828W
Hello All.. I recently installed multiple Foscam FI9828W outdoors...and just ordered IOlinc modules to install..
Question...On the Camera there is an I/O alarm terminal block that has 2 inputs and 2 outputs..
On the IOLINC there is
• Ground – Used with Sense terminal for detecting sensor status
• Sense – Used with Ground terminal for detecting sensor status
• Normally Close
• Normally Open –
• Common –
Using 22guage wire.. Has anyone wired this up successfully and configured this on the ISY?
I'm thinking the 2 Output of the Camera Terminal to the N/O and Command ?
Any help would be appreciated!
thanks
Normally Open Output of the cam to Sense and Ground on the IOLinc.
-Xathros
