Foscam Alarm and ISY Variable?
ferdies
One option I am thinking of is by using ISY Variable, triggered by Foscam alarm directly to ISY.
Setting Variable to ON.
http://192.168.1.4/set_alarm.cgi?user=test&pwd=password&motion_armed=1&http=1&http_url=http://admin:password/192.168.1.2/rest/vars/set/2/88/1
My issue is on how to reset variable to ZERO once alarm has timed out. Is there a way to best possibly do this? Or should I wait for the bi-directional feature of ISY?
BTW - I am thinking of a simple way to do this instead of having a server in between. See this thread.
http://forum.universal-devices.com/viewtopic.php?f=51&t=8666&start=30
Did this work for you? I cannot get the camera to work with alarm URLs containing a username and password.
Oh, and it would be better to set the cam to trigger a program. Then you could set your own timeout.
I haven't done this yet, but I would probably have a program (ProgramA) that triggers off the variable (VariableA) being set to 1 by the camera.
ProgramA immediately sets the variable back to 0, and starts another program, ProgramB.
ProgramB immediately sets VariableB to 1, then waits some set amount of time, and then sets VariableB back to 0.
Then you can key other programs off VariableB.
If motion happens and keeps happening, VariableB will be set to 1 and remain 1. When motion stops, after say 60 seconds, VariableB will go back to 0. In the meantime, the camera may set VariableA some number of times, but motion programs will only trip once.
That's an even more elegant solution! That bypasses my ProgramA, and essentially encompasses ProgramB.
Yes, I was able to do with Foscam on the URL and did not receive any error message. Checking the get_params.cgi, I got the results as per below. I am using FOSCAM with Device Firmware Version 11.37.2.56.
However, my ISY variable is not changing. Are you having the same issue?
Yes, It shows the URL as I want, but nothing actually happens (wireshark trace). The Foscam seems to be ignoring what it considers to be an invalid URL.
I was never able to get this working either after trying many options... http://foscam.us/forum/post44644.html#p44644
Don,
Thanks for trying to help with this, but it was acknowledged on the foscam forum link, and through many tests by myself and others on the other udi forum link I listed that the foscam firmware does not allow having a username and password embedded in the URL, and that is the only way the ISY will do authorization with the rest interface. So we are stuck with using a proxy.
I went one further - wireshark on a monitor port on my switch. The Foscam works as expected when a simple URL is present, however when the URL contains a username and password it does not even establish a TCP connection with a SYN packet. The camera just send to think the URL is invalid and refuses to use it.
Yes, you were the one I was referring to that did a lot of testing on this subject viewtopic.php?p=111432#p111432
Don,
Here is my point.
First. Please remember that I have absolutely no idea of what you do or don't have access to.
Whatever HTTP URL you use could be used to pass that information to the URL you would like to use.
Meaning the HTTP URL launches some php/script URL that in fact actually does the formatting for the real URL.
So, when you say proxy. I think of a proxy as being located on another system vs. calling a URL on the same system that uses a the real URL that is failing directly from the camera.
I have no idea of what the ISY series supports.
Don
The ISY does not support what you suggest. It has to be done by a proxy as detailed in the other post.
Please see these:
http://wiki.universal-devices.com/index ... ver_Module
http://wiki.universal-devices.com/index ... er_Example
Your saying that what I am suggesting can't be implemented by using one of the above solutions?
Don
Yes that is what I am saying. The webserver does not have a way to do it, and the Rest interface requires username and password which is the original problem.
I agree. I don't think the Foscam will follow a 3xx redirect presented by the server. Nor do I think you can have the ISY username and password passed to the REST api of the ISY as parameters.
That is correct. If we could send username and password as parameters that would also solve the original problem. I think I requested UDI to support that...
Have you tried that? It contains Javascript which has to be run on the client side, which in this case is the camera, so I don't see how that will work.
My point is. That even using Java, please see the link I provided in my prior post. You should be able to launch something that can go to the "Real" URL without any need to included the User Id and Password in the HTTP URL in the camera.
I know absolutely "Nothing" about ISY hardware. That said. Even the Java example shown in my last link seems capable to do this. Without the need of a proxy.
Maybe some other ISY users with programming experience using the web/java interfaces has better suggestions on what methods should be used. But most likely there are methods that can be used. Without the need of a proxy.
Don
It's not Java. It's Javascript, which is very different... Neither the camera or ISY support Javascript so it's not possible the way you suggest. I appreciate you trying to help, but if you don't know the hardware/software supported by the ISY then it's not really helpful.
That's fine, but the Foscam can't run that.
The Foscam can only call a simple URL without a username or password, and a simple GET request.
Not much the ISY can do without a correctly supplied username and password. Hence the need for an intermediate script.
Sorry if I offended you, it was not meant that way. I only a have a few decades of programming experience so you obviously know more than me. But I do have a few years of ISY experience.. I will leave this discussion now.
An understanding of your intentions you mentioned above would have been helpful. Both MWareman and myself are seasoned ISY user/programmer types along with others in the posts I mentioned above. It was confirmed by UDI that there didn't seem to be a way to do this without a proxy.
The easiest fix for this is for the foscam set_alarm to allow the URL with embedded username/password, or have the ISY REST interface allow passing the username/password as parameters.
It would be awesome to have a cleaner interface between foscam and ISY so any help you can provide would be appreciated.
We know that using a proxy like you mentioned with Google works, examples using a web server on a nas device were posted. To do it with Google opens a lot of security issues that I don't want to get into. I have requested a change for the ISY firmware, of course it is possible, but it was given low priority by UDI.
Sent from my Nexus 5 using Tapatalk
Those are instructions to create a client to talk with the ISY. There may be a way to create a ISY module to accomplish this, but that is a lot of work for a simple fix. I've asked UDI to chime in on this subject...
Hi jimsearle,
If you are trying to have the camera call ISY, the camera will need to include the HTTP Authentication header otherwise ISY will refuse it.
The format of the Authorization header is:
Authorization: Basic Base64(userid:password)
Where, base64 converts the string representation of userid followed by ‘:’ and followed by the password.
As an example, the Authorization header for userid=admin , password= admin is:
Base64(admin:admin) YWRtaW46YWRtaW4=
Therefore the Authorization header shall be:
Authorization: Basic YWRtaW46YWRtaW4=
      37.8k
      377.3k
