ISY994i "System Busy" after IOLinc "Options" select
Today, I got a notification 12 hours off from when the program should have run (11PM). I logged in to the admin console and selected the IOLinc controller to check its settings. However, the flag when yellow in the bottom left corner and changed from "ready" to "system busy" and the console locked up. I closed, restarted and the same thing occured. I noticed my Z-Wave lock had changed from a lock to an insteon light. I closed restarted and the same. The lock was showing "100%" in the brightness box. there was no lock or status box. Any thoughts why my system is locked up or what I can do? I am relatively new to ISY/insteon.
Thanks, Jeff
Michael,
Thank you. That worked, although I thought I had also cleared the cache even though I didn't post that. I must not have.
