2486D LEDs
I have an older 2486 KeypadLinc, 6 button. I cannot get the A - D LEDs to light via the ISY994i. Any Suggestion? I just purchased the ISY994i and so far it is great! Thanks for your help.
Hi Michael, I have them in various programs but not scenes.
This is an example:
If From Sunset -30 minutes
To 11:14PM (same day)
Then Set Family Room Lamp On
Set Master Bathroom - C on 15 / off 0 (backlight level)
Else No Actions
Master Bathroom C in a 6 button KeypadLinc
The Family Room lamp operates as requested but the KeyPadLinc does not
Thank you for your patience!
Princerichy-
As Michel said above, secondary KPL buttons need to be placed in a scene and the scene used to turn them On/Off. Setting the backlight level (usually done on the primary node) affects the On and Off brightness levels for ALL buttons of the KPL. It does not turn on/off individual buttons - only sets the KPL's 2 brightness levels globally.
-Xathros
I will set it up properly. Thank you for the enlightenment!
