storing climate data in variables
Am new to the climate module and running firmware 4.2.3, which is pointing to the new HamWeather service. I'd like to store some climate data in a variable so I can track changes/max/min and send some of the data by email. I don't see an action that allows me to choose it. I also looked in the "variable" action but didn't see anything there. My search of the wiki didn't provide the answer. I know the data is available through a REST call but don't think I can have ISY make that call to itself and store it in a variable, can I?
Is there a way to do this using ISY (without another computer)?
Not until 5.x when Variables and Programs are expanded. Not sure if what you want will be in that image since the details in the image have not been released but not before then.
  • 1 year later...
Dredging up an old topic.  I am writing a program to monitor wind speed and I has hoping to store the climate module's wind and wind gust speeds in a variable.
I want to send an SMS warning when wind or gusts are >= 15 MPH.  I then want to avoid sending the sms message again until the climate module's wind or wind gust speed is greater than the last reported high value (stored in a variable).
Is this feature coming soon?
Here is the start of my program without waits and variable checking:
Weather - High Winds - [iD 0014][Parent 000D]
        Module 'Climate' Wind Speed >= 15 mph Or Module 'Climate' Gust Wind Speed >= 15 mph
        Send Notification to 'Rick's Phone SMS' content 'Weather Alert - High Wind
Wouldn't this work for you?
Have this running constantly.  Having it check the wind speed however often as you'd like.
WindSpeedCheck - [ID 03C3][Parent 0052][Not Enabled]
        Repeat Every  5 minutes
           $WindSpeedLast  = $WindSpeed
           Run Program 'WindSpeed1' (If)
           Run Program 'WindSpeed2' (If)
           Continue from WindSpeed3 through WindSpeed15.......
           Run Program 'CheckWindSpeedDifference' (If)
You'd need 15 programs like this
WindSpeed1 - [ID 03C2][Parent 0052][Not Enabled]
        Module 'Climate' Wind Speed is 1 mph
        $WindSpeed  = 1
Second Program
WindSpeed2 - [ID 03C4][Parent 0052][Not Enabled]
        Module 'Climate' Wind Speed is 2 mph
        $WindSpeed  = 2
And finally the notification program
CheckWindSpeedDifference - [ID 03C5][Parent 0052][Not Enabled]
        $WindSpeed >= $WindSpeedLast
        Send Notification to 'ISY Alert E-Mail'
Edited by zerop
Thank you for taking the time to post your solution zerop. I give that a try.
Michel, looking forward to 5.x.
Rick
Rick
You're not the only one!   :)
Jon...
