zwave antenna
Hello,I just purchased the zwave dongle and external antenna for my isy994i,I think I installed the antenna correctly but when I go into the isy admin console it doesn't show that you can pick internal or external antenna,have I not installed the external antenna correctly?
I have 4.2.2 installed I will install 4.2.3,
Thank you
I updated to 4.2.3 still have no option for the zwave antenna ,what might I try?
Select Help / About
What is shown for the UI line?
If not 4.2.3, then you need to clear your java cache including applications and then load a new admin console from:http://isy.universal-devices.com/994i/4.2.3/admin.jnlp
-Xathros
Here is a video showing the process......
Xathros that did thanks!
Excellent! Happy ZWaving...
-Xathros
