How to make lights flash?
Is there a way to have the lamp module flash on and off several times in response to a motion sensor instead of just on/off?
Thanks..
 Control MotionSensor is Switched On
  Repeat 3 Times
  Set Light On
  Wait 1 Sec
  Set Light Off
  Wait 1 Sec
Hope this helps
-Xathros
Thanks..
Sure. Just turn it on and off several times
Control 'motion sensor' is switched ON
Set 'lamp' On
wait 1 second
Set 'lamp' Off
wait 1 second
Set 'lamp' On
wait 1 second
Set 'lamp' Off
wait 1 second
Set 'lamp' On
else
Or use a loop.
Repeat 4 times
. Set 'lamp' On
. wait 1 second
. Set 'lamp' Off
. wait 1 second
Or, especially if you have a few items, Scenes may be faster. They are setup/defined in your devices and multiple devices can be treated like one device.
Repeat 4 times
. Set Scene 'lamp_scene' On
. wait 1 second
. Set Scene 'lamp_scene' Off
. wait 1 second
  Repeat 3 Times
  Set Light On
  Wait 1 Sec
  Set Light Off
  Wait 1 Sec
Hope this helps
-Xathros
Thanks, but when I try this apparently the motion sensor is set to turn off automatically after 30 seconds and cant be set to less than that, so when I set the above code it doesn't work, just stays on for 30 seconds then goes off. Also I don't see an option for Control MotionSensor, just for "bedroom Light". Do I have to do something else to identify the motion sensor?
Like should I remove the lamp as a responder from the MotionSensor, then run the program?
espann
The -Sensor node is the node that should be used with If Control 'xxxx' is switched On
The -Sensor node turning Off has no effect on the If Control ..... is switched On
Yes, the LampLinc cannot be a Responder to the Motion Sensor.
espann
[attachment=0]MSSensor.JPG[/attachment]
But where do I find the "Sensor node"? The only thing in the dropdown list in "Then" statements that makes any sense is "Insteon". I cant find a "If
Control MotionSensor is Switched On" statement anywhere..
I mean my MotionSensor is not listed as a "control", only my lamps are listed under the control list!
The Motion Sensor Sensor node is used in the If section
If Control 'MS-Sensor' is switched On
do something
But I don't have an "MS-Sensor" option under my If Control. All that's there for me is 'Office lamp' and 'Bedroom Lamp' under If Control..
Has the motion sensor been added to the ISY device list?
-Xathros
As per Xathros, it sounds like you have the motion sensor linked directly to the lamp rather than running through ISY. You need to enroll the motion sensor in ISY just like any other device.
How do I do that? Enroll it? I thought linking it from the "Link a motion sensor" button on Link Management would do that.
Yes. The motion sensor needs to be placed in linking mode via its button per its manual. Then use the link a motion sensor menu in the ISY. 3 nodes should be added to the device tree in the ISY for the sensor as shown in LeeG's post above.
Once the sensor is properly added to the ISY you will be able to select the motion node from the list of devices in the if section.
-Xathros
To further other's advice above...
Remember that in battery operated Insteon devices the ISY cannot talk to them (configure) until they are in linking mode. This is a security and battery saving thing.
Get the manual for each device from the smarthome.com website. The paper that comes with them is almost useless and sometimes doesn't match the device's version and operation style.
-Xathros
Thanks! It turns out I wasn't correctly linking the motion sensor. I wasn't putting in the mac address. Now I do see the sensor in the tree, but the program still doesn't flash; the lamp just comes on and stays on, for 30 seconds. I've got a new motion sensor coming tomorrow and I'll try from scratch with that one.
You should be able to invoke your program manually by right clicking your mouse on the name in the directory and selecting "Run Then" in the menu. The flashing is done by ISY, not the MS. Your lamp controller may not be linked in properly either.
I have been advised many times, and I will repeat it, to do a factory reset on every device you receive before your do anything else with them. I have found most of these devices act really weird until you factory reset them.
Ok, right clicking the program and clicking "Run Then" does run that program, but how do I make that program run whe the "If" condition is invoked? Here is the program:
IF
Control '26.5C.2F-Sensor' is switched on
Repeat 3 times
Set 'office lamp' On
Wait 2 seconds
Set 'office lamp' Off
Wait 2 seconds
But when the Sensor detects motion it just comes on and stays on for 30 seconds.
IF
Repeat 3 times
Wait 2 seconds
Wait 2 seconds
I suspect that the Sensor is still manually linked to the lamp module. You should remove both the lamp module and the sensor from the ISY, factory reset both then add them back to the ISY. You should not manually link devices together outside of the ISY.
I also suspect that the ISY is not in range of the motion sensor as that program should still have flashed the lights if the sensor had triggered the program. The fact that it didn't tells me that the ISY's PLM did not hear the sensor On message.
How far from the PLM is the sensor located? Was it added to the ISY from that location? Does the Admin console show the sensor status changes?
-Xathros
-XathrosYou should be able to invoke your program manually by right clicking your mouse on the name in the directory and selecting "Run Then" in the menu. The flashing is done by ISY, not the MS. Your lamp controller may not be linked in properly either.
Ok, right clicking the program and clicking 'Run Then' does run that program, but how do I make that program run whe the "If" condition is invoked? Here is the program:
IF
Repeat 3 times
Wait 2 seconds
Wait 2 seconds
-Xathros
Thanks Xanthros. I factory reset both the lamp module and the sensor and the Run THEN program runs but the IF program does not run, and now if motion is detected the office lamp does not even come on. The other lamp module (bedroom lamp) does still respond to motion and comes on.
This time I did not link the office lamp outside of ISY.
Again, when motion is detected by the sensor, the office lamp does not come on, the bedroom lamp does come on(which I have not reset). And the office lamp, which has the program, does not come on or flash if motion is detected.
If the bedroom lamp is responding to motion then the sensor and the bedroom light are manually linked outside of the ISY. Remove the bedroom lamp from the ISY, factory reset the bedroom lamp module then add it back to the ISY. That should break the linkage between the two.
When you run the program, does the Office lamp flash?
When you move in front of the motion detector, does the admin console show the motion sensor change status? Here I suspect we still have an issue.
Double check the program and make sure the sensor and the lamp module are still referenced in the If and Then sections.
-Xathros
-Xathros
Ok, I removed the lamp from ISY, rreset it to factory reset, and added it back to ISY. Now either lamp will flash if I run their THEN program. But when I move in front of the motion detector nothing happens for either lamp and the admin console does not change status. But this is different from before, because before I reset the bedroom module they both did respond to the motion sensor. Both the sensor and the lamp module are referenced rrespectively..
OK. Making progress.
First, not sure I understand what you said above...
Do any lights flash when you RunThen the program? If not, edit the program and reselect the light(s) in the Then section, Save the program and then test again with a RunThen.
The fact that the admin console does not see the sensor status changes could indicate that the sensor is not communicating with the ISY's PLM. If the sensor added ok, this may simply mean that the sensor's current location is out of range of the PLM or other Dual band devices.
To Diagnose: Open the Event Viewer (Tools / Diagnostics / Event Viewer). Click the Clear Button, then go move around in front of your sensor. You should see activity in the event viewer. If not, the Sensor is not communicating with the PLM. Temporarily move the sensor close to the PLM and test some more. Do you see event activity? Does your program run? Can you turn On/Off both lamps via the admin console?
Post results.
Do you have any Insteon access points/range extenders? Other dual band devices? It is generally recommended tthat you have a pair of access points bridging the phases (legs) of your electrical panel to provide communication between the 2 pahses and also to provide RF coverage for wireless only devices like motion sensors amd door/window sensors.
-Xathros
Post results.
-Xathros
Thanks Xanthros. Yes both lamps flash when RUN THEN program is run. And I can turn both lamps on/off via the console. And I have attached the event log.
ISY-Events-Log.v3.3.10__Fri 2014.06.13 03.08.39 PM.txt
OK. Good that the lights respond. Bad that the log shows no sign of the motion sensor. We should see activity in there from 26.5C.2F but I see none. This means that the Motion sensor is not in communication with the ISY. Move the sensor close to the PLM and rerun the event viewer test.
-Xathros
-Xathros
Ok, I moved the motion sensor right on top of the PLM and re-ran the event log and attached it here. Could the battery in the sensor be a problem? I'll replace it later.
ISY-Events-Log.v3.3.10__Fri 2014.06.13 03.31.53 PM.txt
Thts possible. I'm still seeing no traffic from the sensor.
-Xathros
