New Climate module
JeffWLeach
How do I configure the location?
If I go to Climate tab in the configuration tab in the Universal Devices Console. The Information still says WeatherBug. The location ID does not work. In Location ID I put in my zip code of 60004 and a screen popup asking me to make a selection but the choices are blank. I am on the latest beta release insteon_4.2.4.
JeffWLeach-
The new weather module does not work with Zipcodes. Enter your City/Town name then hit find and select the station that best suits your needs.
  • 3 weeks later...
The firmware and UI match v.4.2.5 and I cleared the Java Cache.
The climate tab has
Weather provider
a check box for enabled is not checked
Location ID is blank
Unit is English (F)
Polling Interval (sec) is 300
What do I do?
Firmware documentation says "you will need to reconfigure your Climate Module to point to HAM Weather Stations instead of WeatherBug"
how do I do that?
Is there documentation?
This takes some effort. From reading another thread on this forum you need to use the nearest airport. I live in Arlington Heights, IL the find point to Mount Prospect. The weather data is not correct for example humidity was 0% when it is 65%. I need to select the nearest airport where the weather comes from and that is palwaukee airport. Once I did that it works.
What about this "Climate Module to point to HAM Weather Stations instead of WeatherBug". This was requested on the firmware page.
I don't see any place to do that.
      376.7k
