Leak Sensor Not Linking
Make sure the Leak Sensor is near a Dual Band device. It must be manually put into linking mode as all battery devices require. Double check Insteon address for things like 5 & 6 or 6 & 8 being misread.
I checked the address its 23.33.67 and correctly entered. I press the set button for about 5 sec. and it flashes green so I think its in the right mode. I have placed next to an IO link about 2 feet from the sensor and about 3 inches from the ISY 944i and still no luck. I wonder if its not working
  • 4 weeks later...
I'm having exactly the same problem.  I'm certain the I'm in wireless range (remotelinc 2 works from same location) yet I get an error trying to add the leak sensor.
Any suggestions on how to get this going?
thanks for the help!
Run Tools | Diagnostics | Event Viewer at LEVEL 3.   Put the Leak Sensor into linking mode with its Set button.   Using New INSTEON Device, enter Insteon Address, Name of choice, leave Device Type set to default Auto Discover.   Post the event trace of the inability to add Leak Sensor.
Thanks for the quick response!  Here you go:
Tue 07/22/2014 09:30:38 PM : [iNST-TX-I1  ] 02 62 0E 18 77 0F 11 FF
Tue 07/22/2014 09:30:38 PM : [iNST-ACK    ] 02 62 0E.18.77 0F 11 FF 06          LTONRR (FF)
Tue 07/22/2014 09:30:38 PM : [28 4f f4    ] Added to list of devices to link to ISY
Tue 07/22/2014 09:30:38 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 0D 00
Tue 07/22/2014 09:30:38 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 0D 00 06                 (00)
Tue 07/22/2014 09:30:38 PM : [iNST-SRX    ] 02 50 0E.18.77 0F.43.4B 27 11 FF    LTONRR (FF)
Tue 07/22/2014 09:30:38 PM : [std-Direct Ack] 0E.18.77-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 09:30:38 PM : [D2D EVENT   ] Event [E 18 77 1] [sT] [255] uom=0 prec=-1
Tue 07/22/2014 09:30:38 PM : [   E 18 77 1]       ST 255
Tue 07/22/2014 09:30:39 PM : [iNST-SRX    ] 02 50 0E.18.77 0F.43.4B 23 11 FF    LTONRR (FF)
Tue 07/22/2014 09:30:39 PM : [std-Direct Ack] 0E.18.77-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 07/22/2014 09:30:39 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 23 0D 02           (02)
Tue 07/22/2014 09:30:39 PM : [std-Direct Ack] 28.4F.F4-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 07/22/2014 09:30:39 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 10 00
Tue 07/22/2014 09:30:39 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 10 00 06          ID-REQ (00)
Tue 07/22/2014 09:30:39 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 23 10 00    ID-REQ (00)
Tue 07/22/2014 09:30:42 PM : [iNST-TX-I1  ] 02 62 0E 18 77 0F 11 FF
Tue 07/22/2014 09:30:42 PM : [iNST-ACK    ] 02 62 0E.18.77 0F 11 FF 06          LTONRR (FF)
Tue 07/22/2014 09:30:42 PM : [std MH      ] Unexpected Ack imCmd=62 cmd1=LTONRR 0x11
Tue 07/22/2014 09:30:43 PM : [iNST-SRX    ] 02 50 0E.18.77 0F.43.4B 27 11 FF    LTONRR (FF)
Tue 07/22/2014 09:30:43 PM : [std-Direct Ack] 0E.18.77-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 09:30:47 PM : [iNST-TX-I1  ] 02 62 0E 18 77 0F 11 FF
Tue 07/22/2014 09:30:47 PM : [iNST-ACK    ] 02 62 0E.18.77 0F 11 FF 06          LTONRR (FF)
Tue 07/22/2014 09:30:47 PM : [std MH      ] Unexpected Ack imCmd=62 cmd1=LTONRR 0x11
Tue 07/22/2014 09:30:47 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 10 00
Tue 07/22/2014 09:30:48 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 10 00 06          ID-REQ (00)
Tue 07/22/2014 09:30:49 PM : [iNST-SRX    ] 02 50 0E.18.77 0F.43.4B 27 11 FF    LTONRR (FF)
Tue 07/22/2014 09:30:49 PM : [std-Direct Ack] 0E.18.77-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 09:30:49 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 27 10 00    ID-REQ (00)
Tue 07/22/2014 09:30:49 PM : [std-Direct Ack] 28.4F.F4-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 09:30:52 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 10 00
Tue 07/22/2014 09:30:52 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 10 00 06          ID-REQ (00)
Tue 07/22/2014 09:30:54 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 27 10 00    ID-REQ (00)
Tue 07/22/2014 09:30:54 PM : [std-Direct Ack] 28.4F.F4-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 09:30:58 PM : [28 4F F4 0  ] Cannot determine device type
Tue 07/22/2014 09:30:58 PM : [28 4F F4 0  ] Failed to add device, reason 2
Tue 07/22/2014 09:30:58 PM : [All         ] Writing 0 bytes to devices
Stop the activity to 0E.18.77 that is being done at the same time 28.4F.F4 is being added to the ISY.   Multiple requests were sent to 0E.18.77 during the device add process.
The issue is 28.4F.F4 did not respond to the device type request.   When 28.4F.F4 does respond to commands the Hops Left count is 1.   This means it is not communicating directly with the PLM.
Thanks again for the help.  Put the leak sensor right next to the plm and re-tried... same results:
Tue 07/22/2014 10:46:28 PM : [28 4f f4    ] Added to list of devices to link to ISY
Tue 07/22/2014 10:46:28 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 0D 00
Tue 07/22/2014 10:46:28 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 0D 00 06                 (00)
Tue 07/22/2014 10:46:29 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 27 0D 02           (02)
Tue 07/22/2014 10:46:29 PM : [std-Direct Ack] 28.4F.F4-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 10:46:29 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 10 00
Tue 07/22/2014 10:46:29 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 10 00 06          ID-REQ (00)
Tue 07/22/2014 10:46:29 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 27 10 00    ID-REQ (00)
Tue 07/22/2014 10:46:38 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 10 00
Tue 07/22/2014 10:46:38 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 10 00 06          ID-REQ (00)
Tue 07/22/2014 10:46:39 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 27 10 00    ID-REQ (00)
Tue 07/22/2014 10:46:39 PM : [std-Direct Ack] 28.4F.F4-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 10:46:42 PM : [iNST-SRX    ] 02 50 0E.20.94 00.00.01 C3 11 00    LTONRR (00)
Tue 07/22/2014 10:46:42 PM : [std-Group   ] 0E.20.94-->Group=1, Max Hops=3, Hops Left=0
Tue 07/22/2014 10:46:42 PM : [D2D EVENT   ] Event [E 20 94 1] [DON] [0] uom=0 prec=-1
Tue 07/22/2014 10:46:42 PM : [   E 20 94 1]      DON   0
Tue 07/22/2014 10:46:42 PM : [D2D EVENT   ] Event [E 1F C4 4] [sT] [255] uom=0 prec=-1
Tue 07/22/2014 10:46:42 PM : [   E 1F C4 4]       ST 255
Tue 07/22/2014 10:46:42 PM : [D2D EVENT   ] Event [E 1F C1 3] [sT] [255] uom=0 prec=-1
Tue 07/22/2014 10:46:42 PM : [   E 1F C1 3]       ST 255
Tue 07/22/2014 10:46:42 PM : [D2D EVENT   ] Event [E 20 94 1] [sT] [255] uom=0 prec=-1
Tue 07/22/2014 10:46:42 PM : [   E 20 94 1]       ST 255
Tue 07/22/2014 10:46:42 PM : [D2D EVENT   ] Event [1A C8 B2 1] [sT] [255] uom=0 prec=-1
Tue 07/22/2014 10:46:42 PM : [  1A C8 B2 1]       ST 255
Tue 07/22/2014 10:46:43 PM : [iNST-SRX    ] 02 50 0E.20.94 0F.43.4B 43 11 01    LTONRR (01)
Tue 07/22/2014 10:46:43 PM : [std-Cleanup ] 0E.20.94-->ISY/PLM Group=1, Max Hops=3, Hops Left=0
Tue 07/22/2014 10:46:43 PM : [iNST-DUP    ] Previous message ignored.
Tue 07/22/2014 10:46:52 PM : [iNST-TX-I1  ] 02 62 28 4F F4 0F 10 00
Tue 07/22/2014 10:46:52 PM : [iNST-ACK    ] 02 62 28.4F.F4 0F 10 00 06          ID-REQ (00)
Tue 07/22/2014 10:46:52 PM : [iNST-SRX    ] 02 50 28.4F.F4 0F.43.4B 27 10 00    ID-REQ (00)
Tue 07/22/2014 10:46:52 PM : [std-Direct Ack] 28.4F.F4-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 07/22/2014 10:46:56 PM : [28 4F F4 0  ] Cannot determine device type
Tue 07/22/2014 10:46:56 PM : [28 4F F4 0  ] Failed to add device, reason 2
Tue 07/22/2014 10:46:56 PM : [All         ] Writing 0 bytes to devices
This is what the trace should look like in the begining  ....
Wed 07/23/2014 02:03:14 AM : [21 7A CC    ] Added to list of devices to link to ISY
Wed 07/23/2014 02:03:14 AM : [iNST-TX-I1  ] 02 62 21 7A CC 0F 0D 00
Wed 07/23/2014 02:03:14 AM : [iNST-ACK    ] 02 62 21.7A.CC 0F 0D 00 06                 (00)
Wed 07/23/2014 02:03:14 AM : [iNST-SRX    ] 02 50 21.7A.CC 22.80.0B 2B 0D 02           (02)
Wed 07/23/2014 02:03:14 AM : [std-Direct Ack] 21.7A.CC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 07/23/2014 02:03:14 AM : [iNST-TX-I1  ] 02 62 21 7A CC 0F 10 00
Wed 07/23/2014 02:03:14 AM : [iNST-ACK    ] 02 62 21.7A.CC 0F 10 00 06          ID-REQ (00)
Wed 07/23/2014 02:03:15 AM : [iNST-SRX    ] 02 50 21.7A.CC 22.80.0B 2B 10 00    ID-REQ (00)
Wed 07/23/2014 02:03:15 AM : [std-Direct Ack] 21.7A.CC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Wed 07/23/2014 02:03:15 AM : [iNST-SRX    ] 02 50 21.7A.CC 10.08.3E 8B 02 00           (00)
Wed 07/23/2014 02:03:15 AM : [std-Broadcast] 21.7A.CC-->10.08.3E, Max Hops=3, Hops Left=2
Wed 07/23/2014 02:03:15 AM : [21 7A CC 0  ] Calibrating engine version
The Hops Left should be 2 but most important the Broadcast message (in Red) indicating the device type is not in your trace.  The Leak Sensor appears not to be using the Dual Band aspects of the 2413 PLM.
Hi FlyingFish,
Please contact our tech support (links below) and we'd be delighted to help.
Hi LeeG, thanks as always for your expert and 100% accurate information.
      37.3k
      373.4k
